Question about Building Materials
Can not operate with a remote when it is cold out. Of course the garage is cold too. Works fine if you push the (wired) button on the wall
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 76 Answers
Maybe try changing the battery in the remote. If that doesn't work, I would talk to a professional about it.
Posted on Nov 09, 2014
myob247
  • 1342 Answers
SOURCE: garage door remote won't open the garage door
The little button with a padlock on the wall control is a "vacation" lockout feature that disables the remotes. There should be a small LED on the wall control that is always on steady. When the padlock button is pressed and released the LED should be constantly blinking (indicating the vacation lockout mode is active) and your remotes should be disabled. The wall control will still operate the door. Pushing the padlock button again should make the LED stop blinking and restore the door to normal operation.
Posted on Jun 19, 2008
  • 476 Answers
SOURCE: Liftmaster 1280 LMC Motion Detector Garage Opener Push Button Pad Not Working
Have you tried to reprogram the chanel again?
Changed the battery?
Posted on Aug 02, 2008
SOURCE: The wall button has a green light that is blinking
this just happened to us today as well. the wall pad has three buttons: one large back-lit button pad to open it and a lock button and a light button. the open button was blinking quickly and would open the door, but the car remotes did not work. I found that by pushing both the "lock" and "light" button at the same time for about 3 or 4 seconds, the back-lit "open" pad stopped blinking and went to steady green. I went back to the cars and checked the remotes there. both opened the door.
hope this helps someone out there
Posted on May 03, 2009
  • 3197 Answers
SOURCE: garage door wont work with remote
If the small light in your wall control is blinking it is in the lock mode. Press and hold for 3 seconds the button with the icon of a lock. This will toggle the lock function off.
Posted on Aug 04, 2009
  • 3197 Answers
SOURCE: Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+: My craftsman 1/2 hp garage dood does not close whe...
If the main light flashes 10 times when you try to close the door it is a sensor problem. Make sure they are not flickering ever so slightly and that they are not loose on their brackets. Tweak them a little bit.
Posted on May 20, 2010
Wireless garage door opener works wired one doesn,t
Either the wall control has gone bad or you have a broken wire going to it.
Nov 18, 2011 | Sears Craftsman LiftMaster Chamberlain...
Intermittent remote trouble
Your wall control is hard wired and doesn't use the receiver portion of the logic board. The remotes do. Your receiver is going bad.
Jan 12, 2010 | Sears Craftsman LiftMaster Chamberlain...
Garage door opener remote won't work
look for a smashed wire between the motor unit and the wall button.
If the wire is smashed the insulation becomes so thin that power will leak thru the insulation.
Loosen the staples with a small screwdriver and slide the wire about ½ inch to move any areas of thin insulation away from the staples.
The second thing would be a bad wall button or a remote with a sticking button.
Or a remote in someone’s purse that gets the button pushed by other stuff in the purse.
The test is to disconnect the push button wires at the power unit. If the interference stops you have located the problem. If you reconnect the wires and disconnect the wire at the wall button this will tell you if the problem is the wire or the button.
HOPE THIS HELPS
Apr 19, 2009 | Sears Craftsman LiftMaster Chamberlain...
Remote not working
you will need to train (link) the remote to the garage door opener. to do this you will need to find the remote "train" button on the operator.
If you have the manual for the garge door opener this will show you where it is located.
push the train button on the operator, an LED light will start blinking. Then push one of the buttons on the remote. the LED light on the operator will stay on. push the button on the remote again and the light on the operator will turn off.
try the remote it should work now.
Apr 05, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sometimes the door opens with one push of the button
Anytime a door opens and/or closes randomly or doesn't work consistently I look for a smashed wire between the motor unit and the wall button.
If the wire is smashed the insulation becomes so thin that power will leak thru the insulation and activate the door or interfere with the remote signal.
Loosen the staples with a small screwdriver and slide the wire about ?½ inch to move any areas of thin insulation away from the staples.
Or a remote in someone's purse that gets the button pushed by other stuff in the purse.
The test is to disconnect the push button wires at the power unit. If the self operation / interference stops you have located the problem. If you reconnect the wires and disconnect the wire at the wall button this will tell you if the problem is the wire or the button is defective..
Dec 12, 2008 | Sears Craftsman LiftMaster Chamberlain...
REMOTE CONTROLS WILL NOT WORK-WALL BUTTON FLASHING RAPIDLY
Does your wall switch have a lock feature? By pressing the lock button, the remote control is disabled. A flashing light indicates this feature has been activated.
To deactivate, press and hold the lock button for 2 seconds. The flashing should stop and your remote should work again.
Dec 03, 2008 | Sears Craftsman LiftMaster Chamberlain...
Garage door remote won't open the garage door
Jun 18, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman Garage Door Premium Control Console Failure in Cold Weather
first guy has the mounting screws tp tight or the wire is preventing wall station for sitting flush against wall....second guy check your safety eyes...
Jan 23, 2008 | Sears Craftsman LiftMaster Chamberlain...
Building Materials Logo
Top Building Materials Experts
hpgwva
Tom Chichester
ray gallant
Are you a Building Material Expert? Answer questions, earn points and help others
