Question about Fisher and Paykel Washing Machines
Fisher and paykel gw711 balance reset - Fisher and Paykel Washing Machines
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 70 Answers
Normally if u unplug the appliance for a few minutes then plug back in , it should reset everything? not sure bout Pykels though
Posted on Nov 09, 2014
  • 12 Answers
SOURCE: Fisher & Paykel GW711 Washer
If you brought this machine new, then you should find a service manual under the display panel
You will need to remove the panel, Next to inlet valves you should find a maual in a plastic cover...
Posted on Jul 18, 2008
SOURCE: service manuals and diagnostic codes with results/reset code
http://www.aars.com.au/F&P%20Service%20manual%20517735.pdf
Posted on Feb 06, 2009
  • 205 Answers
SOURCE: fisher and paykel out of balance switch fault
Machine should reset when it has regained "balance". It is possible the the OOB switch lever is stuck on the tub ( it is under the top in the right corner and hangs parallel to the tub ). Move tub around and reset load. Sometimes the OOB switch get corroded or breaks and needs to be replaced in order to clear the fault. Call F/P.
Posted on Jul 21, 2009
PSITECHNICAL
  • 71 Answers
SOURCE: my fisher and paykel top loader washing
Disconnect the washer for few minutes (5min) then connect it again and press cancel, before you start any cycle, good luck
Posted on Jan 06, 2010
SOURCE: I have a Fisher & Paykel 5.7kg GW711 smart
usually it is the Motor bearing that goes, but not always, Smart drives are notorious, for these motor problems. But sometimes, it can be something caught, in the drum.
Posted on Mar 14, 2010
Fisher & Paykel gw711 excellence keeps filling and overflowing
the clear pressure tube is blocked,
you need to blow air down the clear pressure tube hose.
Jan 30, 2013 | Fisher and Paykel GWL11 Top Load Washer
Fisher and paykel GW711
Replace the water inlet valve. That will fix the problem. No need to replace anything else.
Mar 06, 2018 | Fisher and Paykel GWL11 Top Load Washer
F & P washer does not start
These 11 series machines all have this problem
When power supply gets warm it stops.
You will need a technician to fix the power supply in the brown board.
Mar 13, 2012 | Fisher Washing Machines
Fisher and paykel GW711 stops and starts when filling then beeps continuosly
43. (00101011) Phase 1 to 6 - OOB Switch Fault
The Motor Controller module has found that the signal returning from the out of
balance switch indicates that the switch is permanently on or the harness to it is
disconnected.
Primary Source: Mechanical.
Action:
1) Check that the out of balance switch is free to move.
2) Check that no harnesses are blocking switch movement.
3) Check that the switch operates correctly when activated. Replace the switch
if suspect.
4) If the out of balance micro switch shows signs of corrosion, replace the
switch and switch harness, and fit a condensation kit to the console area if
not incorporated in the top deck.
5) Check the level of the machine and also the bias spring.
Secondary Source: Wiring.
Action:
Check the harness to the switch is connected correctly. The terminals should be
connected to the normally closed position. If the harness terminals show signs of
corrosion, then fit a new harness.
Tertiary Source: Motor Controller module.
Action:
Replace Motor Controller module.
Jan 14, 2012 | Fisher and Paykel GWL11 Top Load Washer
Top loader.recently had sesor replaced after machine went off balance. has gone off balance again, now water pumps for a second then stops and sarts then light sequence comes on.
David, exactly what combination of lights come on, top row. There are 8 leds 5 green, 2 orange, 1 red. Show the code with an X for led on & 0 for light off. EG:
0000X00X
This will indicate F9, sizing issue. (Code is actually read Right - L)
Also is model # GW711 What is product code. Both available on back panel or behind control panel.
Aug 07, 2010 | Fisher and Paykel GWL11 Top Load Washer
We have a fisher and paykel gw711 washing machine that continues to fill with water while it is in the rinse and spin cycle
Hi Robbie just read your posting.Now just a couple of questions.Does the machine keep filling and flood?Can you manually select the amount of water for the wash --eg-- low, medium,or high?Or does the machine drain and fill at the same time?Please reply with additional information on the questions and I am sure I can rectify this fault for you.
Jul 16, 2010 | Fisher and Paykel GWL11 Top Load Washer
Washing Machines Logo
Top Fisher and Paykel Washing Machines Experts
Gerry Harvey
Gerry Harvey
michael_t919
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
