Question about Health & Beauty
I cannot get a reading and E comes up, I have checked the batteries which are ok
    Top Expert:
  • 74,377 Answers
"E" will be displayed due to an overflow [digital processor]. I mean; it is a fault with its counter IC inside. Please seek help of any technician.
Posted on Nov 09, 2014
1996 Honda Goldwing 1500 low amperage on volt guage reading 10 volts battery went dead inroute home last nite ok removed alternator ok it appears to have external regulator on outside rear of caseing
When one cell in the battery fails, (no fluid, or just worn out or a shortage) the voltage will drop 2 volt. when the cell is complete dry, you have 0 volt left, because nothing can come out. So also check the battery.
Oct 15, 2014 | 1996 Honda GL 1500 Aspencade Gold Wing
Engine and battery light comes on when riding
Hi Dolan, check your battery terminals for clean tight connections. Hook up a volt meter too your battery and run the engine up to 3600 RPM your meter should read 14.3 to 14.7 volts DC if it much lower you have a charging system problem. If it reads ok then do a load test on the battery or charge it overnight to get a reading of 12.5 to 12.8 Volts if much lower replace battery. Good luck
Mar 22, 2014 | 2009 Harley Davidson FXDF Dyna Fat Bob
Engine and battery light come on
Hi Anonymous, check your battery terminals for clean tight connections. Hook up a volt meter too your battery and run the engine up to 3600 RPM your meter should read 14.3 to 14.7 volts DC if it much lower you have a charging system problem. If it reads ok then do a load test on the battery or charge it overnight to get a reading of 12.5 to 12.8 Volts if much lower replace battery. Good luck
Mar 21, 2014 | 2009 Harley Davidson FXDF Dyna Fat Bob
How do u check 2 c if ur alternator is working right ?
ok! at the battery, car off. it should read at least 12.6 volts.this is battery voltage, with car running it should read 14.2-14.7 at the battery.if alt. is ok. thats if the belt is tight and ok. also make sure connections at the battery are clean and tight. good-day !!
Aug 16, 2011 | Ford Mustang Cars & Trucks
2005 magnum sxt lights come on but go dem when trying to start car only clicking sound
Could be several possibilities...First, check the voltage on the battery...at engine off, it should read around 12.50 Volt DC....any lower and you won't get start....if battery voltage is ok then you will need to check the connections...bad connections on the battery can cause the no start condition(but allow the lights to come on as they don't draw as much power as a starter)...if you are in doubt as to the condition of the connections, then you can remove each battery cable and clean each cable and post and reconnect....if connections are ok then you may need to remove the starter and take it to the auto parts store and have it tested to see if it is defective
May 26, 2011 | 2005 Dodge Magnum
93 lincoln towncar, 66k miles, replaced starter (was bad) now after crank-up, approx 10 min driving time, anti-lock light comes on then the a/c read-out goes crazy and then it dies. Then it won't start,...
I'd check those fuses for voltage, when problem is ongoing. Those fuses are hot all the time, use a test lite. Did you check voltage drop on cables and wiring? Battery has a full charge and charging system is working correctly?
Mar 17, 2017 | Lincoln Town Car Cars & Trucks
2001 Grand am Se battery light keeps coming on - replaced battery yesterday and had alternator checked - was told amp on alternator was fine?
Who told you the alternator is O.K.? How much voltage is it producing? Take a volt meter , start car & make sure the alternator is charging properly. Attach meter to the posts & see what it reads. All readings over 13.2 to 14.5 O.k. less means new alternator. Also make sure battery cable connections are clean & tight.
Jan 07, 2010 | 2001 Pontiac Grand Am SE
2005 boneville batery going bad, gauge reads 18
CHECK THE BATTERY CABLE AND CLAMPS FOR FOR CORROSION .
Nov 01, 2009 | 2005 Pontiac Bonneville
My car dont star, i check my ligths and averything is ok, i listen under de motor a little click click i hit in the starter whit a screw
If ur getting a clicking noise when u attempt to start it sounds like the starter drive ingaging into the flywheel but the starter isn't turning. Check ur battery to make sure it is fully charged and get a load test to make sure it is ok. Next check the connettions to the battery. Ur Problem wasn't complete--if crossing terminals at the starter the engine turns over it is the starter soloid, if it just clicks it is the battery or connections
Aug 03, 2009 | Nissan Pathfinder Cars & Trucks
Vivaro with no ignition lights battery reads 12 v all engine fuse
Did AAA jump your battery? if not hook a comercial battery charger up to; or, remove recharge; your battery: this should release the locks then: you have either short draining your battery or, a bad alternator or, battery
Mar 09, 2009 | 2002 Volkswagen Eurovan
Health & Beauty Logo
63 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
