Question about Car Audio & Video
Why don't my amp have fuses in it?
Theres no fuses on my amp?
    Top Expert:
  • Car Audio & ... Master
  • 75,591 Answers
These type of amps won't have a fuse inside. We have to put it outside, by wiring. Contact any service technician. Electro help
Posted on Nov 09, 2014
My remote trunk button works but the interior trunk button doesn't any more. Is there a fuse for it? Where would that be? All my fuses look good and I don't see anything labeled for trunk.
Just go under hood, open fuse box and replace the red 10 amp fuse. Its blown. Go in the junction box under the hood, not the one in the cab. If the diagram isnt legible, simply check the little fuses until you find the blown one. Its in the same box as all the relays and the bigger fuses. Theres a few smaller fuses in the junction box that are just like the ones in the cab. Find the blown one, replace and enjoy.
Feb 25, 2013 | 2001 Chrysler Sebring
Driving lights dont come on
provied u check the baulbs n thyre good theres a drl relay in the fuse box under the hood
Sep 20, 2011 | 1999 Pontiac Grand Am GT
I'm buying a 1990 lincoln with 68,000 miles on it. Theres a problem with the power windows. The car sat for a while & wasnt driven. Could the problem be a fuse, the motor? What do you think? thanx Tom
Don't buy a 21 year old car. PERIOD
A vehicle like that, is a restoration project,
for those of us with the tools,knowledge &
lots of money to throw away at a hobby
It could be a window switch on door panel,
window regulator, window motor.
Half the windows probably each have different
issues.
That car is worth $500.00 at most
Apr 22, 2011 | Lincoln Continental Cars & Trucks
2003 dodge caravan radiator fan will not stop running.what is the problem?
Probely a bad relay in the fuse box on the driver side. Theres a map under the fuse box cover to find the RAD FAN relay. There the same as other relays that the van uses. Pull the fan relay & replace with same number thats on the top. Theres also a 40 amp for the fans.
Jan 23, 2010 | 2003 Dodge Caravan
Hello blew a fuse ??? somewhere ?? that
look in fuse box on inside , on your panel that tells you the order , theres a 10 amp with a blackcover on it . it says i.o.d on it thats the problem i was in the same problem , i changed it [it was blown] now everything works . happy to help
Jan 12, 2010 | 2000 Dodge Ram 3500
With the battery charged it will go dead sitting for 3 days. With the battery charged and the positive lead disconnected for 7 days the car will start fine when reconnected although there is some arcing...
theres a draw somewhere. these are sometimes hard to pinpoint.start by checking that all lights turn off,glovebox underhood light all lights,you will need a meter to meter the draw amps, then with key off doors closed look at the draw amount,.02 to.03 is allowable, start removing fuses and watch if amps drop,one fuse at atime, start with this to try and pin down a location of the draw.hope this helps.
Jan 04, 2010 | 2002 Oldsmobile Silhouette
Blowing of fuses
The reason your blowing fuses is the amp needs at the least a 150 amp fuse on the wire that runs to your bat. There are fuse blocks that you can put 4 40amp fuse and theres the high dollor ones that you can put all the way to 200amp. When you trun up your amp its drawing to much current for the little 40 amp fuse that you have and will blow it everytime. I recomend Running a 4 gage wire to bat and ground with same. Get you a 150 or above amp fuse from a car audio shop somewhere. anyway sounds like from what you decribed, theres nothing wrong with your amp just the wires and fuse are not big enouf to handle the current that your amp pulls.
Oct 21, 2008 | Lanzar OPTI 50c Car Audio Amplifier
Car Audio & Video Logo
32 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
