Question about Garden
Hw many turns do i need to do to reset the hi and low tuning screws on a husqvarna 265 scrubbar
  • 1,169 Answers
You start at 1-1/2 turns from seating and adjust from there for best mixtures.
Posted on Nov 09, 2014
3 Suggested Answers
  • 149 Answers
SOURCE: need initial carb adjustments for both high and low adj.
start at 1turn out on both that should grt it running from there..
Posted on Jan 31, 2009
dontbother10
  • 2220 Answers
SOURCE: on the husqvarna se266 carborater, what is the low
Initial setting for a Husqvarna; "H" and "L" screws at 1 turn CCW form lightly seated. Then tune for performance like this:
Carburetor Adjustment by Madsens.com
http://www.madsens1.com/saw%20carb%20tune.htm
CW is leaner; to lean will destroy the saw. If over tightened closed (CW) the adjustment screw faces are easily marred; marred adjustments are difficult to impossible to set properly.
Clean the air filter; adjusting with a dirty filter can cause a run lean condition once cleaned and the saw run.
There are 2 wav (sound - idle & full – may not be highlighted) files that I find most helpful, I think you will too. HTH
Lou
Posted on Feb 23, 2010
Where can i find a tool to adjust the high and low on the carb of a model 141 husqvarna chain saw
Stihl have a small orange screw driver- a tuning screw driver, it has an arrow on the end to show how many turns you have done when tuning your saw
Sep 04, 2013 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Keeps cutting out
More than likely its a tuning issue, needles and jets can get gummed up if the engine has sat round for a while with fuel in it. The fuel tends to evaporate and leave behind the 2 stroke oil residue.
Unscrew both H and L tuning screws (not all the way out, just a few turns) You may need to purchase the tuning screwdriver as Husqvarna blowers are fitted with Walbro carbs that have tooth edged tuning screws.
Once you have unwound them a few turns, Pull the blower over (a few times. It may fire up, it may not) Then to reset them to factory settings Screw them both all the way in and then turn them each out anticlockwise 2 & 1/2 turns.
If its still not running right it may need more investigation but it definately sounds like a fueling problem.
Jun 12, 2013 | Husqvarna Garden
My Husqvarna 335LS runs rough and will not run at full speed
Check the exhaust, the muffler contains a gauze which can deteriorate and restrict gas flow through the exhaust. Have you stripped the carb down and checked the diaphrams/gaskets, removed high and low tuning screws, cleaned and reset to standard settings.?
Mar 30, 2013 | Husqvarna 335LS
Hi. I inherited a 1998 Husqvarna 265 rx. Got new plug and new fuel and it fires ok. Wouldn't stop so I added a washer under the 'earth' screw and it now stops. Problem is poor acceleration
To set the throttle, start by slackening the cross head screw securing the cable in the handle and pull completly out, now slacked the three allen headed screws securing the handle, twist the handle to the best position for your use ( at full throttle your thumb should not be straining ) now slacken the lower cross head screw and turn the silver clamp to tention the spring underneath, when correctly adjusted the throttle trigger should spring back to the idle position readily, now re fit the cable up through the clamp, turn the cable so as it is just about to open the carb throttle spindle, lock the cross head screw and test to make sure you are getting full throttle, if not slacken the screw and turn cable a little more.
Sep 19, 2012 | Husqvarna 531004054 Throttle Wire
How many turns do i need 2 start at for the high and low 4 51 husqvarna
Lightly seat the screws (all the way in) then back out 1 1/4 turns on both screws will put you in the ballpark....tune from here.
Dec 08, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
On the husqvarna se266 carborater, what is the low and high screw settings or how many turns is the screws supposed to be at?
Lou
Feb 22, 2010 | Garden
How do you set the mixture screws
I'd start at 1.5 turns CCW from lightly seated. Then tune for performance. It is probably fitted with tamper resistant fittings mandated by the EPA. I contact my local Stihl dealer when my saw needs adjustment. HTH
Lou
Nov 17, 2009 | Husqvarna Chain Saw 20" Bar
Settings for low and high speed screws for carb for husqvarna 136
turn them both in , gently, till they bottom out and then back them out 1 1/2 turns. This will get you real close and then fine tune them from there. hope this helps.
Sep 10, 2009 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
What is fuel air mixture screw settings on husqvarna 371k
I will admit that I am not particularly familiar with this manufacturers specific models, but I will state that for most small 2 stoke motors I seem to find that 1.5 turns out seems to be a great place to start for both the high and low speed mixture screws. From there it is all fine tuning to get the most out of the engine while still keeping it rich enough to prevent damage.
May 06, 2009 | Husqvarna Garden
Garden Logo
37 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
