Question about Garden
HI Does anyone have a manual PDF for the Alien 50cc scooter?
I am looking for the manual for the above. I need information on the fuel inputs from the diaphragm attached to the tank and where the rubber tubes go to. There are two of these and the one that does not have the filter is really the one that has me stumped. I cannot see where it is supposed to go.Ant help much appreciated.
  • Garden Master
  • 14,406 Answers
#1 Taper
  • 1041 Answers
SOURCE: I have a weedeater barracuda sv30 blower had it
The longest, and sometimes smaller in diameter of the two fuel lines, goes from the carburetor to the bottom of the tank. Leave enough slack in this line so that the filter that attaches to the end will rest comfortably at the bottom of the tank.
The other fuel line goes from the primer bulb to just inside the tank, (about an inch). make sure that you get the right size fuel lines. The plastic coupling goes on the end of this line, inside the tank. This keeps the line from pulling out of the tank.
(HINT): When feeding the lines through the tank holes, cut the lines at an angle. They will feed much easier into the holes. You can than cut them off square, once you know that you have enough to work with.
If you need further assistance, just let me know.
Jim
Posted on Jun 28, 2009
canbruce75
  • 1776 Answers
SOURCE: The filter in the gas tank came off.
The filter should only fit in the end of one of the lines (probably the larger diameter one) The smaller line usually goes from the tank to the primer bulb and the larger one goes to the carburator. The filter just sticks in the end of the fuel line.
Posted on Jul 08, 2009
Dolfoff
  • 148 Answers
SOURCE: Trying to get my Poulan leaf blower to run again.
Open the carb back up. Directly under the inlet needle you will see a mesh screen. Remove and hold up to light. If it's clogged (and it's HIGHLY likely it will be) take the carb to a reputable dealer and buy a rebuild kit for it (not simply a diaphragm kit, the screen isn't in that one).
About 10 bucks for most kits.
Hope this helps.
Dolf-
Posted on Oct 06, 2009
vincob
  • 718 Answers
SOURCE: Replacement for broken fuel line tubing
Go to your local small engine repair shop. You should have at least one in your area. or maybe even ace hardware.
Posted on Nov 25, 2009
jonvtec
  • 7 Answers
SOURCE: replace fuel lines WeedEater FL 1500 Blower
On the FL1500:
  • The Smaller line goes on the Lower inlet tube on the carborater the other end goes to the gas filter inside the gas tank.
  • The Larger line goes on the upper outlet tube on the carborater the other end goes to a fitting that holds this tube from coming out on the gas tank .This tube is only for Air, it helps fill the primer bulb when pushed.
I hope this helps.
Mechs correct me if I have made a mistake.
Thaxs Jon
Posted on Jul 11, 2010
Working on QINGQI QM50QT 6N scooter and looking for service manual showing the carb, fuel sys, and engine but can only find 6/6a manual. Is the 6/6a manual used for 6n? If no is it available online?@
Hi, Sean the 6N will work fine it's just an updated version of the 6A your scooter falls in the CCGS class of scooters because there are at least 100 different brand names of the Classic Chinese Generic Scooter which all have the same body style and mostly run the 50cc-250cc Honda GY6 engines which mean's you can literally go to any shop that works on scooters for parts and repairs. This brings me to the main part of this answer, only the top 10 scooter manufacturers have service-parts-owners manuals that are easily available, CCGS scooters have no manuals available except for the occasional user guide so if I give you a link to a manual of a different brand name, despair not, for it will contain 99% of what you need or are looking for, regarding repairs or maintenance. For more information about your question and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
http://www.family-motorsports.net/GY6-50cc-150cc.pdf
Chinese Scooter Parts Diagrams
http://absolutelyscooterparts.net/pdf/CGEN_dawg_scooter_manual.pdf
Chinese Motorcycle Qingqi QM50QT 6A 50cc 06 09
Jinan Qingqi Wikipedia
Nov 10, 2017 | Qingqi Motorcycles
How to change my oil in 2014 typhoon 50cc
Hi, Connie for this scenario you will need your service, parts fiche, and owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
What Type of Engine Oil Should Use in My Scooter
How to change the motor oil in your scooter 50cc
Aug 20, 2017 | 2014 Piaggio Typhoon 50
Workshop manual 50cc scooter gas leak
Hi, Phillis for more information about your question and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Aug 10, 2017 | GAS Motorcycles
I have a 2008 Titan velocity 150cc scooter and the gas gauge is not working any ideas ?
Hi, Jeff and the usual suspects are:
1. Blown instrument fuse.
2. Faulty sending unit.
3. Faulty wiring between sending unit and gauge.
4. Faulty ground or power connection.
5. Bad fuel gauge.
For more information about your question and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
My gas gauge doesnt work on my scooter
One way to fix non responsive stuck gas gauge on 50cc gy6
https://www.scooterdomain.com/chinese-parts/full-size-scooter-parts/125-150cc-scooter-parts
http://www.49ccscoot.com/manuals/Baja_SC150_Owners_Manual.pdf
Mar 10, 2017 | GAS Motorcycles
SUPERBYKE POWERBAND R50 Where can I locate the battery on this bike ?
Hi, Corbet your scooter falls in the CCGS class of scooters because there are at least 100 different brand names of the Classic Chinese Generic Scooter which all have the same body style and mostly run the 50cc-250cc Honda GY6 engines which mean's you can literally go to any shop that works on scooters for parts and repairs. This brings me to the main part of this answer, only the top 10 scooter manufacturers have service-parts-owners manuals that are easily available, CCGS scooters have no manuals available except for the occasional user guide so if I give you a link to a manual of a different brand name, despair not, for it will contain 99% of what you need or are looking for, regarding repairs or maintenance. For more information about your question and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
battery removal
Kymco People 200 Scooter Battery Replacement How To
http://scooterunderground.ca/knowledge/manuals/documents/Metro_50_service_manual.pdf
Scooter Engines GY6 2 4 stroke 50cc 150cc PartsForScooters com
http://www.scooterloungeonline.com/files/1669893/uploaded/BuddyOwnersManual.pdf
Mar 02, 2017 | Motorcycles
My 50cc Scooter has a brand new carb but gas is leaking from overflow ???
Hi, Kim and the usual suspects are:
1. Damaged or restricted fuel tank venting system.
2. Loose float bowl screws.
3. Damaged float bowl o-ring.
4. improper fuel level in the float bowl.
5. Worn or dirty inlet valve or seat.
6. Damaged or leaking float assembly.
7. Particle contamination in inlet fitting cavity.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Carburetor is leaking gas out of overflow tube need help
Carburetor Carb Leaking Gas How to Fix Repair it Motorcycle Honda DIY...
http://www.49ccscoot.com/manuals/Hyosung_SF50_Service_Manual.pdf
50cc scooter parts QMB139 49cc 4 stroke parts moped parts QMB139
http://www.yamaha-motor.com/assets/service/manuals/2008/zuma_lit-11626-21-15_1548.pdf
Jan 04, 2017 | Motorcycles
How to use timing on my 2005gy6tank scooter
Hi, Joseph for more information about your question and free downloads that you need please visit the websites below. Good luck and have a nice day. gy6 valve adjustment
SunL Scooter Timing Check Slow GY6 50cc
http://www.49ccscoot.com/manuals/Tank_GY650-150_Service_Manual.pdf
Jan 07, 2016 | Motorcycles
Garden Logo
43 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
