Question about Blazer S10 1998 98
My s-10 chevy blazer 98 will not engage in gear for reverse ands has no power in drive sounds like its free spiining noise is coming from what sounds like my drive line
Will not go in gear for reverse when piut in drive has almost no power afraid of giving gas for fear of further damage when given gas rpm is going up when no gas is given justy free spin
    New Friend:
    Problem Solver:
  • 9 Answers
Try to get it scanned if any check engine is on! If not your reverse clutches are fried or the reverse valve is shot basically you will need another rebuild trans or good used one. Good luck
Posted on Nov 09, 2014
Passing gear on 350 throttle body does not engage
is it wireless or hard wire? Or either sludged up until the solenoid cannot overcome the stickiness in which case look for the fuse
Jun 01, 2015 | 88-98 Chevy Pickup / 95-99 Chevy Suburban...
1997 chevy blazer drive doe not engage. 1 2 and reverse gears work fines
TO START HAVE A SCAN DONE TO PULL CODES FOR TRANS. IF NO CODES HIGH CLUTCHES ARE MOST LIKELY BURNED
Dec 09, 2014 | 1997 Chevrolet Blazer
How to fix 1998 2 Wheel Drive Chevy Blazer automatic transmission shifter that will not engage any of the gears
That sounds like the linkage (at the transmission end) has broken or loosened. Crawl underneath (wheels chocked) and watch closely while someone else shifts back & forth - you'll see the linkage move at the transmission end, and you should see how to correct the problem.
Aug 04, 2014 | GMC 98-04 Jimmy Sonoma Chevy S-10 Blazer...
98 chevy Blazer 4x4 front wheels not turning everything looks ok actuator ect. could something be wrong in the front differential?
Jack both front wheels up. Rotate one one way, the other should rotate the other way freely, and the drive shaft should spin if four wheel is engaged.
Nov 28, 2013 | GMC 98-04 Jimmy Sonoma Chevy S-10 Blazer...
99 chevy blazer transmission pumps work on it but will not engage into any gear
Damaged torque convertor probably.
Take the gearbox off and check your work.
Dec 06, 2017 | 1999 Chevrolet Blazer
2000 chevy blazer will not go into reverse, but all other gears work fine.
sounds like reverse let go you need to have trany rebuilt. soory for the bad news, good luck.
Nov 29, 2009 | 2000 Chevrolet Blazer
1998 chevy s-10 blazer. 4 wheel drive does not
do u have a lever control on floor if yes check adjustment of linkage if u have the dash switches check fuse and relay than check actuator for proper movement at transfer case actuator has a tendency to stick lube and or adjust
Oct 29, 2009 | 1998 Chevrolet Blazer
Transmission issue, when in reverse heard a clunk, then a whining sound....later there was no reverse...2001 chevy blazer
ok my truck done the same thing put it in reverse then to drive to check my universal joint and heard a pop and then i lost 2nd, 4th, and reverse all at one time it ended up being the sun-shell gear in the tranny cost me almost 500 to fix hope this helps out
Dec 20, 2008 | 1999 Chevrolet Silverado 1500
Blazer S10 1998 98 Logo
Top Blazer Car Audio & Video Experts
xxxxxx xxx
Are you a Blazer Car Audio and Video Expert? Answer questions, earn points and help others
