Question about Ipcw 2000 Chevy Impala - All Impala models - Headlights
My boyfriend pulled something out of my impala so I wouldn't be able to start it , do you have any idea what he took
When I put the key in my car there isn't any power it's dead my boyfriend pulled something out so I couldn't drive it, do you have any idea what he did
    Problem Solver:
  • 15 Answers
Get a new boyfriend and then check battery cables
Posted on Nov 09, 2014
This is about to be rather lengthy, so I apologize in advance. I traded for a 98 Firebird on April 19th. Already broke down. The problem doesn't lie within the engine or transmission however. What...
Sounds like the electrical part of the ignition switch, not the lock cylinder that needs replacing.
Possible also that cutting that wire to the security module immobilized it.
May 09, 2013 | Cars & Trucks
1988 lxi honda accord battery drains overnight
Just a couple problems I've had. dome light left on due to faulty door open switch, spot light charger or equipment left plugged or wired to battery, lately I thought I had a bad battery but I just need to clean the terminal connections. One more thing if your car is running you can pull the negative cable off the battery. If the car dies your alternator could be the problem. If you have a light in the trunk or under the hood you could pull the bulb out to make sure you don't have a faulty switch turning them on. These are kind of simple and that is the way I start out.
Jul 04, 2017 | 2007 Honda Accord Sedan
2008 Chevy Equinox would not start, turn key and nothing happened, replaced battery, ran just fine for a week. Tried to start one week later it acted like it wanted to start but wouldn't. Had ju
Usually a sign of something draining the battery.
The machine test probably showed the battery could hold a charge and the alternator was charging the battery.
You may need to have someone check for a power drain.
When the key switch is off, there may be a weak short to ground or a relay or component that is using power.
Jan 22, 2013 | 2008 Chevrolet Equinox
1993 nissan pick up won't start
Possibly a bad connection on the positive side coming from the battery or a weak ground. Check where the leads join the terminal clamps. Has the battery been verified as good? It doesn't take a lot of amps to run lights but it does to turn over the engine. Jump starting it does not require a fully charged battery.
May 01, 2017 | 1993 Nissan Pickup
What could be causing my 2005 mazda 6 to keep dying while I am driving it?
Have the codes read with a scan tool. Most auto parts stores will do it free.
Jul 01, 2017 | 2005 Mazda 6
I have a 1996 Chevy Blazer 6 cylinder 4.3 Vortex engine. The check engine light has been on for a few weeks but it was running just fine. Until all of a sudden it wouldn't start last night. I had...
My first thought would be: If you repaired an emissions hose, take the car back to Auto Zone (or another parts supplier) and let them tell you what code comes up now. You eliminated one problem, now you have to find another.
I wouldn't do a fuel pump without more information.
Gary
Jul 20, 2011 | 1998 Chevrolet Blazer
Went to start my car, wouldn't start, key was stuck, wouldn't shift, battery wasn't working, heard a clicking noise in the door, radio flashed once, console light up several times. Help! ...
The most commonly diagnosed component is the shifter and/or shifter solenoid on your Impala.
GM issued a bulletin on this problem. Contact your dealer, they are aware of the problem and you could be covered under warranty. Below is a copy of the bulletin.
#08-07-30-007A: EI08045 - Key Cannot be Removed from Ignition with Gear Selector in Park, Shifter Cannot be Moved From Park Position (Engineering Information) - (Apr 8, 2008)
Subject: EI08045 -- Key Cannot Be Removed from Ignition with Gear Selector in Park, Shifter Cannot Be Moved From Park Position (Engineering Information)
Models: 2007-2008 Chevrolet Impala
Good luck, i hope this helps.
Jun 28, 2011 | 2008 Chevrolet Impala
I have a 2008 Impala. I cannot put the car in drive. The gear shift is totally locked. I have checked the emergency brake, checked for anything that would be an interference, and it will not disengage....
Is the car parked on a steep hill? Sometimes things just don't line up and will cause all sorts of problems.
Since you didn't say it wouldn't start, are you getting any error codes? Have you checked the entire length of the transmission linkage and make sure that something hasn't come loose?
Jun 05, 2011 | 2008 Chevrolet Impala
My boyfriend pulled something under the dash and now my truck wont atart, it turns over but acts like it isnt getting any fuel
Why not just have him put something back? He probably pulled the ECM fuse. Do you have the owners manual for it? Look for an empty spot in the fuse box and put a fuse in it until it starts. When you turn the key to run, just before the start position, does the check engine light come on?
Jan 15, 2011 | 1998 Ford Expedition
Open Questions:
See all Ipcw 2000 Chevy Impala - All Impala models - Questions
Ipcw 2000 Chevy Impala - All Impala models - Headlights Logo
89 people viewed this question
Top Ipcw Office Equipment & Supplies Experts
Robert McCall
Robert McCall
 Russ Hill
Russ Hill
Bill Boyd
Are you an Ipcw Office Equipment and Supply Expert? Answer questions, earn points and help others
