Question about Air Lift 1995 Oldsmobile 98 On Board Air System Air Suspension Compres
Does a 1995 Oldsmobile 98 have a air suspension system?
  • 603 Answers
It is possible. If you want to find out look in the area where shock absorbers are mounted. If you see small plastic lines going to the shocks, then you have air suspension. GOOD LUCK FRIEND.
Posted on Nov 09, 2014
Air suspension
LEAK IS AIR LINE FROM COMPRESSOR TO REAR SUSPENSION
OR...REAR SUSPENSION COMPONENT FAILURE
Jul 21, 2013 | 2003 Oldsmobile Bravada
Where is the a/c low side service port for a 1995 Oldsmobile 98 located?
You can't connect the chaging can adapter to the wrong side it will not fit.
Jun 08, 2012 | 1995 Oldsmobile Ninety Eight
Where is the fuel filter located on a 1995 Olds. 98?
For 1995 Oldsmobile 98 3.8L SFI OHV 6cyl the Fuel Filter is located under vehicle, passenger side, below seating area, front of fuel tank, mounted on frame in fuel line
Hope helps (remember rated and comment this).
Aug 15, 2010 | 1995 Oldsmobile Ninety Eight
I have a 1995 Town Car Signature Series. The rear
Sadly, there is no way to turn the light off. I had the air suspension on my Lincoln replaced with the spring kit, and the light is still on. I had a friend take the instrument panel apart and place a small piece of electrical tape over the "check suspension" light. Also, be certain to turn the air suspension pump switch off. It is located in the trunk on the right side.
May 29, 2010 | 1995 Lincoln Town Car
Hi. I have a 1985 Oldsmobile 98 Regency. I have two questions. 1. There is a device, located near the engine, that raises the height of the rear of the car. What is the device called? 2. The rear raising...
It is an air suspension system. If it keeps giving you problems try connecting a switch in between the "hot" wire that comes from the battery.
Oct 07, 2009 | 1985 Oldsmobile 98
Air-spring suspension 1995 Mark Vlll Lincoln Continental.When car is turned off fornt air-springs stay inflated but sometimes rear air-springs slowly lose air but inflate after ignition switch is turned to...
Save your self the hassle and expence of troubleshooting and replacement parts, install a suspension retrofit kit which changes the rear bags to coil springs and the front to struts. A car this old you might as well start over for less than $500.00......
Sep 20, 2009 | 1995 Lincoln Mark VIII
98 Olds LLC - AC works but fan air does not blow
If you have a late model GM car and the system is controlled electronically the blend door actuator becomes weak. When this situation occurs it will not move the air direction door inside of the heater/air conditioner plenum. in your case not to the vents Replace the actuator with new and recheck the system. i hope this helps
Jul 24, 2009 | 1995 Oldsmobile Cutlass Ciera
1995 lincoln town car Rear air suspension problem
probably a leak in the system. check the switch in the trunk, make sure it is on.
Jan 10, 2009 | 1995 Lincoln Town Car
Air suspension motor running
If you have a hole or crack in your airbag the compressor has to work extra hard to try to blow it up (like blowing up a balloon with a hole in it) I would recommend checking out strutmasters.com they have some great kits for the Ninety Eight. There kits will eliminate any problems with the suspension. It is a permanent fix. these convert you from the airbag to a powder coated American made steel coil spring that is guaranteed to last the life of the car. And for a very affordable cost. I added the link below so you can check it out.
http://www.strutmasters.com/oldsmobile-suspension-parts-s/85.htm
Hopefully this will help
Good Luck!!!
Dec 27, 2008 | 1992 Oldsmobile Ninety Eight Regency
Air Lift 1995 Oldsmobile 98 On Board Air System Air Suspension Compres Logo
66 people viewed this question
Top Air Lift Air Tools & Compressors Experts
John Trevino
Lawrence Oravetz
Are you an Air Lift Air Tool and Compressor Expert? Answer questions, earn points and help others
