My TV/ DVD combo when turned on will only go to the dvd screen. I can't get it to any other like tv or aux or av. It's like th DVD player takes over anything else
    Top Expert:
  • Televison & ... Master
  • 74,634 Answers
Input selector IC fault. Contact any service technician. Electro help
Posted on Nov 09, 2014
How to play a dvd
Press either tv/av or press input and press input 2 i think the one next to antenna. Then turn on dvd player and put in a DVD
Nov 22, 2015 | Panasonic new 27 flat screen tv / dvd...
How do I hook up my Toshiba DVD player to my old Daewoo Tv /vcr combo
what inputs does the old Daewood / VCR combo use is it RCA and Video cable on an AV input? How many Av inputs are there in TV ? Does the DVD player have AV out audio out (Yellow) RCA (Red and White). If you do not have enough AV inputs on the Tv use an AV switch box . and Switch two AV RCA inputs /DVD and VCR and into one output to the TV. You may be able to feed the AV out RCA out into the VCR AV in and switch the input on the VCR.
May 25, 2015 | Toshiba Televison & Video
How do I hook up a combo vhs dvd player/recorder to my tv?
The AV OUT on your DVD player must go into the corresponding AV IN[PUT] on your TV.
Jan 19, 2015 | Panasonic Televison & Video
Will a dvd player work with a Panasonic PV-M2023 combo TV VCR, built in 1993? We connected a DVD player but haven't been able to get it to work. We have the original remote control.
I see that it does have RCA input (Yellow, white, red) on the reverse of the TV. Connect the DVD via RCA cable to the corresponding color connection, place the TV in "Vido" or "aux" mode. this is usually done on the remote from an "input" button, or it can also be called "game," "video," or "aux."
Upon putting it to this after connection of the DVD player, you should see the DVD players home screen. You should be set to enjoy the DVD player.
Jun 28, 2011 | Panasonic Televison & Video
I would like to connect a DVD player to my Quasar TV/VCR combo. No clue.....
Look in the back or the front of ur tv have a (Video Audio holes In).Look in ur DVD player in the back or the front have a (video Audio holes Out).Used a component AV video cable hook both devices together.Find the Video Mode in ur tv 1 or 2,now play the DVD player with a dvd disc.Now u should be playing the content of the dvd disc.If u don't have a AV video cable,tries websites like Amazon.com,Ebay.com to buy a set of AV video cable.
Dec 10, 2010 | Quasar VV-1302 13 in. TV/VCR Combo
I can't find the dvd input for my hitachi tv
DVD has AV out pins at rear, hook AV cable between DVD player out and TV AV input (yellow-red-white RCA pins) and select that AV input in TV by remote that you hooked DVD.
That will switch TV to that input and TV will show you DVD player picture.
Sep 20, 2009 | Hitachi 46W500 46 in. TV/DVD Combo
How do i/can i record tv to a DVD ]
If your using RCA cables (thats the red, white & yellow leads) you need run yellow RCA from the 'VIDEO (or) TV OUTPUT' at the back of your tv, to the 'VIDEO (or) TV INPUT' in the back of your DVD/VCR combo unit, & do the same with the red & white 'AUDIO' leads only run them from AUDIO OUTPUT(tv) to AUDIO INPUT(dvdrecorder). Now set the mode of the dvd recorder to TV IN or AUX IN. Now it should record whatever you see on the tv screen. But if your tv has an S VIDEO OUTPUT option, using an S VIDEO cable would be much easier & produces a better copy! Hope this helps!
Jun 19, 2009 | Symphonic WF803 DVD Player/VCR
No picture
Look under your tv settings for the pal ntc settings if you are using the av wire, if not please tell my what yoiu are using, also mak sure that youve pluged the av wire in the yello conecter av out on dvd/vhs and @ the tv AV in
Jan 03, 2009 | Panasonic DMR-EH75VS DVD Recorder/VCR/HDD...
Connecting dvd/vcr combo with tv and digital cable box.
You trying to put the DVD/VCR combo between the cable box and the TV? OK, cable out goes to vcr in, vcr out goes to tv, I think you got that. Now there should be a tv/vcr button on the vcr/dvd, you need to press that when the unit is on. Also, make sure you are on the correct input on both the vcr and the tv, usually video 1 or AUX and choose line in or L1 on the vcr/dvd. If the tv/vcr button is toggled, itll completely bypass the vcr/dvd player.
Mar 03, 2008 | Toshiba 32A41 32" TV
DVD operation
scroll down on the channel button from channel 2. the different aux inputs should be there.there may also be a video/line in/source button on the front of the tv.if there isn't, you can buy a cheap universal remote for under $10 [even in some dollar stores for $1]
wg
Feb 16, 2008 | Symphonic SC319C 19 in. TV/VCR Combo
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
Electro Med Services...
