Question about Moultrie Feeders 12V Solar Panel
Do solar panels need direct sunlight to work?
Solar panels not charging battery enough does it need more sunlight?
    Top Expert:
  • 74,198 Answers
No. It will work in with diffused light too. Some sensitive ones will generate voltage even at moon-light.
Electro help
Posted on Nov 09, 2014
My Citizen echo drive does not hold a charge.It is 9-Months Old .
Place the watch in direct sunlight of sunrise or sunset for a few weeks and also bright light but not hot light. Wear as usual in direct sunlight as the occasion allows. Once these kind of batteries are discharged, they need quite some time to recharge. Wearing a new solar watch most of the time indoors with bright light only, is normally not enough but once the battery reaches full charge, the extra bright light conditions can be relaxed.
Sep 25, 2017 | Citizen Watches
The XC0369 weather station when used in the Southern hemisphere has the solar cell used to charge the batteries facing away from the sun when aligned north.
if you can --put the solar panel horizontal so that it doesn't matter where the sun is
the solar panel works from ultraviolet rays and not direction so if you are doing what you are there is another problem with assembly
May 26, 2017 | Sun Computers & Internet
Can I connect my UPS with my battery which is connected to a solar on the roof? what will the voltage output to appliances?
The UPS has a stated output, that does not change. It is most likely 115vAC. If the UPS does not have enough charge, it will warn you. If you are asking if you can connect your solar direct, no, do not! The UPS is not a charge controller or regulator which is what I think you are asking. Summary: Solar to UPS to appliance is ok. If you exceed the amperage of the UPS, again, an alarm will sound or not work at all. for instance, you will not power a microwave this way.
Aug 01, 2016 | Apollo 1650ETL Swing Gate Motor 20 Watt...
Panel will not put out more than 1.7 volts in direct sunlight
Jeff,
It sounds like the panel's tabs were wired incorrectly or incompletely. I recommend you get a new solar panel since it seems like only one cell is outputting voltage for you now (2v cell). If possible, have the manufacturer warranty it for you since it should be putting out in excess of 14 volts in direct sunlight on a cold day.
Let me know if you have any other questions.
Thanks!
Sep 04, 2013 | Wildgame Innovations Wild Game Innovations...
No charge, is it battery or solar panel, how do I tell
if the unit is not produceing a charge during daylight then it is the unit. the DF-SP-LI will produce full power under sunlight alone. test the unit with the fence unhooked.
Jun 01, 2012 | Parmak Solar Fence Charger
We bought a solar light a Westinghouse item # 37136608W It had a least 7 hrs of direct sunlight for over 7 hrs.but still does not work, We think we had it on. is it possible that the off switch shuts off...
For first time use solar light needs to charge in full sunlight for 8-12 hours with the switch in the "ON" position to allow the rechargeable battery to reach maximum capacity.
There is also a protective film on the solar panel that needs to be removed.
After doing that, fully charging the battery with the switch in the "ON" position, then if the light does not turn on, remove the 4 screws from the solar cell assembly, remove the battery, wipe both ends and reinstall battery. Make sure the battery is making secure contact with the terminals. I had a new one and the battery was loose inside, making the light go on and off. I reseated the battery and all is well.
However you should not have to replace the battery or the unit, it should still be under warranty if you just bought it. Westinghouse guarantees this unit for one year.
A description is here
http://www.westinghousesolarlights.com/products/solar/instructions/371366-08.pdf
Waranty information is here
http://www.westinghousesolarlights.com/products/solar/1yrwarranty.pdf
I would counsel you to just take the unit back for exchange or refund, as the warranty has an exclusion clause and one of the exclusions is if the unit has been opened. Opening the unit might invalidate the warranty.
Mar 20, 2011 | Garden
I have a solar pump kit using an OASE Aquaflow 1500 submerged unit .The pump will spin when connected to a car battery but when attached to my solar panel which is producing 21 v on open circuit it will...
Hello Phil, what is the size of your solar panel? This pump draws 17 watts so, your panel must be 17 watts or greater. Remember a solar panel only puts out full power when in direct sunlight and facing the sun directly. You can read 21 volts but your amperage may not be full and this is why your pump is not running, not enough amps. I would recommend a minimum of a 20 watt panel.
Feb 14, 2011 | Plumbing
New Battery???
Try to expose their solar panels to direct sunlight (10 or 15 minutes), just to see if they come back to life.
Hope it helps.
Jun 23, 2009 | Texas Instruments TI-15 Explorer...
Solar battery charger
Yes, but the efficiency of solar cells is terrible. Its one thing to use free sunlught to charge the cells, its another to have to pay the electric company to do it. If you can access the batteries in the solar rig easily and they are in the correct voltage range, I think you would be better off getting a battery tender (trickle charger). Just let the van sit outside until the batteries are fully charged, then connect the battery tender to keep it fully charged.
Jun 04, 2008 | 1992 Dodge Ram 250
Moultrie Feeders 12V Solar Panel Logo
931 people viewed this question
Top Moultrie Photography Experts
Tony
Are you a Moultrie Photography Expert? Answer questions, earn points and help others
