Washing Machines Logo
V
Valerie Fox Posted on Nov 09, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Resmed Elite S9 does not start properly the company that sold me my machine has moved away I live in Albion Park where can I go for assistance am not able to breathe
  •  Bob S
    Bob S Apr 22, 2016
    Not sure why the question about a CPAP machine is listed under washing machines but ...
    Valerie, you didn't say what your CPAP is or isn't doing on start-up. Whether you received the RESMED S9 through Medicare, Medicaid or other insurance. The machine is covered and can be repaired or replaced by taking it to your Respiratory Therapist (RP) or the clinic that prescribed the S9 for you.
David Payne
Level 3:
Top Expert:
  • Washing Mach... Master 14,162 Answers
  • Posted on Nov 09, 2014
David Payne
Level 3:
Top Expert:
Answers
14162
Questions
0
Helped
2998381
Points
455836
Call sears home services at 1-888-266-6317 and get a quote for a service call and possible repair. the website is www.searshomeservices.com
I have ResMed s9 with voltage fault.
Since that unit is a medical device and it is not made any longer, you need to contact the supplier to see what can be done to replace it.
Mar 17, 2020 • Cell Phones
What buttons do i push to fix resmed s9 error: settings reset to default values
I fixed my machine with this error by doing the following.
You need a T8 torx screwdriver and a thin flat blade srewdriver plus a replacement CR2032 button cell. Ensure that the S9 is disconnected from its power adapter. First pry up on the setting rotary knob at the top of the S9 and remove. Next remove the T8 torx screw from the bottom corner of the machine. There are then four slots located on two of the sides. Insert the flat blade screwdriver into one of the slots and gently push inward to unlatch that finger while also lifting/prying up the bottom cover. You should then be able to work your way around to each of the fingers and lift the bottom cover off. This then exposes the circuit board. There are two more T8 torx screws holding the circuit board in place. Remove them and carefully lift the board slightly. You can then see the button cell in it's holder at the corner which can now be removed and replaced with the new CR2032. The S9 can now be reassembled in the reverse order. Once reassembled, connect the power adapter but do not power on yet or you'll get the same error message as before. Hold down the power button and then while still holding it down power up the machine. Good luck, hope this helps.
2answers
I just got my resmed AirSense10.I got the set-up figured out,except for how to connect the air supply to the Resmed10. Can you help me?
The small tubing is for connecting to an oxygen concentrator or oxygen tank You might not have that requirement.
2answers
Displays a reset to default error. How do I reset the machine?
Remove the SD card and power off and on with the card still removed from the machine. It probably won't help, but it's worth a try.
How to adjust pressure on resmed s9
I think you are talking the the RESMED S9 CPAP Machine. If so,
1.Press the Setup button and the Push Dial (see first image below) for 3 seconds.
2. Turn the Push Dial until you see the Options Screen (see second image below).
3. Press the Push Dial once to select the Option Screen.
4. Turn the Push Dial until Set Pressure is highlighted in blue.
5. Press the Push Dial once. The highlight should now be orange.
6. Press the Push Dial once. The selection should change from orange to blue.
7. If finished, turn the Push Dial until <8. Done!
1helpful
Lack of stock on shelfs
This is FixYa. FixYa is a worldwide community of volunteers who answer questions asked by other users. We do not have any stores in Shellharbour or Albion Park or anywhere else in the world. Please direct your comment to whatever store you're referring to.
Top Washing Machines Experts
john h
