Question about Edifier M1360 2.1 Multimedia Speaker System
My Edifier M1360 speakers will only work when plugged into the headphone jack and I can't get all three speakers working at the same time. What can I do?
I am trying to get my new speakers working correctly but I can only get the front two satellites working without the subwoofer, or only the subwoofer to work at any one time. The speakers will only work when plugged into the green output. Don't know much about speakers please help!
    Top Expert:
  • 14,161 Answers
The sub woofer green 1/8 inch plug goes into the audio card either the front or the back of the pc. the jack it plug into is normally the green one. the two speakers normally join together on one card and plug into the subwoofer. also look for a on/off know to the speakers for power. normally on one of the little speakers. make sure it is on.
Posted on Nov 09, 2014
Connect my BA7800 to my laptop that only has a headphone jack
As you stated in your question there are 3 3.5mm headphone jacks connected to the speakers. Green is for headphones, red is for microphone, and black is probably just a line in connector.
plug the green connector from the speakers into your headphone port on your laptop and it should work.
because the speakers are self powered and have a few adjustment knobs on them, you will have to tinker with the volume coming from the laptop and from the speakers, so you don't have distorted, scratchy sound from the speakers when playing music at loud levels.
my suggestions is turn the laptop volume down to a quater of the volume and then turn the speakers up, let the speakers do the hard work and not the laptop..
Jan 04, 2015 | Boston Acoustics Audio Players & Recorders
No sound playing from either speaker on the Edifier Multimedia Speaker M3300 setup.
Go to http://www.edifier.ca/french/speakers/m3300/m3300-EN-FR-manual.pdf and check the troubleshooting guide. I notice it says to check to make sure the mute button on the remote is off. Try it without the remote plugged in, also. Try hooking up another device with a headphone jack like an mp3 player. The only other thingI can think of would be a blown fuse, which sometimes lets a small signal through with some amps, but I don't see any fuse holder.
Dec 09, 2014 | Edifier Audio Players & Recorders
No side speakers
Make sure you test your wires and that they are running paralel, un wire and rewire, and make sure no speaker wire is exposed or touching.
Dec 12, 2013 | Edifier M1360
Edifier bar speaker,no sound
Reboot the computer. Is it connected to the headphones jack? Check the plug. Open the sound device, select the headphones.Open the Device Manager , check the audio is enabled. Re-install the driver for the audio.
Jan 05, 2013 | Computers & Internet
Dell D810 speakers do not work, but headphone jack does work
It seems as though you might have a bad plug, There is a set of tabs that tell the laptop whether to use the speakers or the headphones. This switch may of locked into the headphones position. This is probably a case of where you would need to replace or repair the headphones port. check to make sure there is nothing in the port to block it. You can also try applying some light oil on the end of a headphones jack and placing it in and out several times to break free a possible stuck part. It also may be a case that the solder mark on the board has disconnected itself from the headphones jack and needs reseating. This would be a difficult fix but not at all impossible.
Apr 26, 2010 | Dell Latitude D810 PC Notebook
Aspire 3680 headphone jack recognizes any headphone plugged in but no sound from the headphone jack, the internal speakers work but not the headphone, running vista
check first you headphone jack speaker. if its working well, then the line from phone jack male to speaker continuity.
Apr 02, 2010 | Acer Aspire 3680 Laptop
How to connect
It is important that you an RCA connector at the end of the input to the 2.1 . You will need to connect the input to the AUDIO OUT sockets in the TV. if you are having the headphone socket please try to get a conversion jack from headphone to RCA.
Mar 31, 2010 | Bose 901 VI Main / Stereo Speaker
Sound is working but internal speaker is not working
Connecting headphones to the system will disabled the internal speakers until the headphone jack is disconnected, at which such time the internal speakers should function again.
If you disconnect the headphones and the internal speakers are not re-activated, then there may be damaged to the microswitch in the jack. (Try rebooting after the headphones are disconnected too)
Mar 01, 2009 | Dell Latitude D410 Notebook
Headphone jack on Inspiron 1300 intermittent- suspect software
Check mixer on pc to ensure all levels are maxxed. Suspect moreso that plug on side of pc is bad. If this is helpful, please post as such
Jan 14, 2009 | Dell Inspiron 1300 Notebook
Edifier M1360 2.1 Multimedia Speaker System Logo
148 people viewed this question
Top Edifier Audio Players & Recorders Experts
David Payne
David Payne
Robert Graf
IT Solution
IT Solution
Are you an Edifier Audio Player and Recorder Expert? Answer questions, earn points and help others
