Question about Home
How do I get outside temp on screen? I have tried everything I could read.
I have changed the batteries several times and waited as instructed but never shows up.
  • 137 Answers
SOURCE: outside temp stuck on -40
when its at -40 usually its because the ambient temp sensor is not sending the proper signal to the controller.. it may just be disconnected.. the sensor it behind the grille.. it has a 2 wire connector to it ... itf its connected it may havea broken wire from body damage in an accident... its rare that the sensor fails..
Posted on Feb 04, 2009
SOURCE: I have a skyscan atomic
This is a very common problem that is most frequently caused by the outdoor transmitter going bad. They are surprisingly delicate and don't like getting wet.
You can order replacement transmitters from http://skyscan.info/content/
They only cost $11 and that includes shipping and handling.
Posted on Feb 07, 2009
SOURCE: Wireless thermo clock not reading outside temp
I've had a similar problem with another model, an Oregon Scientific Model IWA-80055 Wireless Thermo Clock, in which when I replaced the batteries in the remote sensor, the clock would not read the temperature from the remote sensor.
I found it fairly consistent to solve this by taking a battery out of place in the clock and putting it back in.  Unfortunately this also messed up the clock's time and date.  This is also in the instructions catalogue for the device, check and see if yours gives a similar solution.
Posted on Apr 13, 2009
  • 108 Answers
SOURCE: my skyscan model 87800 will not show outside temp.
Look in the manual, There should be a section on remote sensors, they usualy have a "sync" button on them. and hit main unit first then remote.
Posted on Nov 09, 2009
SOURCE: Model-WS-7013U...changed all batt. inserted in
I have the 7013, where do I put the temp transmitter, I have never use this on, I am replaceing an old one that has awire from out side that plug into transmitter, your mode dosn't. Placing the transmitter out sideside? Help
Posted on Jan 30, 2010
The indoor temp on my acurite model 02086 weather stn. constantely reads 26c how do I get it to read the correct indoor temp?
The manual of unit will tell you how to change reading from Centigrade to Fahrenheit. Read it carefully for details.
Oct 02, 2016 | Measuring Tools & Sensors
Can't get outside temp on my atomic clock
If you still have the instructions read up on pairing the transmitter to the clock. You'll need to do that every time you change batteries on the outside transmitter. If you don't have those instructions , go to the clock's web page to get the manual for your model of clock.
Sep 23, 2014 | Home
Radio Shack 63-1090 indoor/outdoor temperature unit. Won't give outdoor readings. Temps are cold, -5F but it always worked before. Put in new batteries in the inside and outside units, wiped outdoor sensor...
According to instructions for similar systems, you have to replace batteries in the outdoor unit first, then the indoor unit and wait 10 minutes without pressing any buttons for the indoor unit to begin displaying the outdoor temperature.
Dec 31, 2013 | Heating & Cooling
Outside temp
Remove all batteries. Reinstall batteries (or new ones) in the outside unit. Install batteries in the console. DO NOT TOUCH ANYTHING! Wait until the outside temperature displays on the console. Make any adjustments necessary.
Nov 05, 2013 | Davis Instruments Davis Vantage Vue...
Envirastation model dws 170
Usually it is due to bad batteries or remote is too far away from home unit. Put units next to each other and press the channel button on front of the home unit. It will start a search to find the remote. If it finds it with a temp reading press the channel button again and you should hear a beep. Channel is locked in. If you still do not get a temp reading try changing batteries in both units and try again. Another try is to unplug the home unit and wait several minutes with no batteries in either house unit or remote. Replace batteries in remote then in house unit and plug back into power. Set all settings and see if you get the reading. If not try step one again. Weak batteries will do the same thing as well as remote to far away from unit.
Oct 06, 2013 | Measuring Tools & Sensors
After changing batteries in both the outside sensor and the inside clock I no longer receive a reading for outside temp.
I have a thermometer with an outside sensor. It's necessary to remove both batteries, wait a few minutes, then replace batteries - sensor first. It may take a few minutes for the inside clock to pick up the signal. If it doesn't, try again with new batteries.
Dec 21, 2010 | SkyScan 86742 Digital Atomic Wall Clock
Thermo clock RAR312 not picking up outdoor transmitter temperature. Replaced battery but still nothing.
take a paper clip and reset the reset button located in the battery compartment. Then, try each of the 3 channels until you get a reading in the outside temp field. Wait a good couple of minutes at each channel setting before determining the units are not pairing. Do this with the units side by side for signal acquisition, then once acquired, move the remote sensor outdoors. Hope this helps!
Sep 24, 2010 | Office Equipment & Supplies
The outside temp sender won't work. We put new batteries in it, but it does not send a signal. It will not put an outside temp on the clock.
Simple, the instructions state that when changing the batteries on the outside temp. sensor, you must also change the batteries on the main clock unit. I had same problem when I changed the sensor batteries until I pulled the batteries from the clock and it reset fine. ( Sensor batteries first, then clock batteries. ) The clock will reset to atomic time overnight so don't worry if it doesn't read correctly at first.
Aug 18, 2009 | SkyScan 86709 Atomic Wall Clock
Dec 30, 2008 | Oregon Scientific Lwb0997110113004...
Outside temp on skycam atomic clock
Try changing the battereis in the CLOCK. When the batteries in the clock start getting low, the clock does not pick up the outside transmitter.
Nov 10, 2008 | SkyScan 86742 Digital Atomic Wall Clock
Home Logo
48 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
