Question about Honeywell PRO 4000 5-2 Day Programmable Thermostat - TH4110D1007
I installed a Pro Th4000 for heat only. I only have 2 wires, one white and one black. Does the white wire go to the W and the black to the R
    Problem Solver:
How can i tell if my hot and ground are are hot with out haveing to put meter on wires?
Posted on Dec 03, 2014
I lost my Leviton 6230M 30 mins timer installation sheet.
Switch has 2 black wires. One black is hot wire. One black is wire going to fan. Turn off power. Remove wires from switch and separate. Turn power back on. Using ordinary tester, test each black wire to bare copper ground wire. Only one of the black wires will test hot. The other black wire goes to fan.
Timer black wire connects to black hot
Timer blue wire connects to black wire going to fan
Timer white wire connects to white neutral (in absence of white neutral, connect Timer white wire to bare ground)
Timer green connects to bare ground wire
May 24, 2010 | Leviton 1000W / 20A 1HP-120V - 6230M-I -...
Just had a honeywell th4000 installed but the heat won't cut off? The temp keeps rising had to cut it off just so I wouldn't burn up? Tried setting the temp down to about 67 but the temp just kept rising
Sounds like they either wired wrong or they got the white wire touching the red wire. Take the cover off the thermostat and see if you can tell if the white wire is touching the red wire. Installers are bad about leaving tag ends on the wires and they end up touching other wires. Good luck
Nov 30, 2009 | Honeywell Heating & Cooling
No Auxiliaty heat with new thermostat
The Vision Pro is a great t-stat and I have installed many of them with great results. I am wondering though if it is set up correctly. Did you go in and make sure that it is set for heat pump and for 2 stage heating? Look on the instructions how to get into the advance installer options. Go through that meanu and make sure that everything ig set correctly for your type of heating system and that it is set for 2 stage heating. From what you have here and I can tell the wiring should be okay that is why I think that it is in the t-stat programming.
Nov 15, 2009 | Honeywell Electronic Programmable...
Replacing Oxygen sensor on 2004 Hyundai Elantra VE 2.0L
yes it will work it is a uiversal 02 sensor place the black and gray wires together and connect to one black wire connect the white to white and the yellow to white this has a heated 02 sensor so twist them together to make sure it's right before you crip them together. the 02 sensor has a signal wire that is black and a heated wire that is black the two white wires are ground hope this helps and if you need more help post back here. the car only needs the heated part to warm it up faster to go into closed loop and the other white and black wire is the signal from the sensor telling the computer how much voltage you are getting from the 02 sensor.
Apr 19, 2009 | Lisle Pneumatic Oxygen Sensor Remover...
Wiring diagram to connect programmable Thermo to Heat Pump
I don't know if this will be helpful or not, but I just installed a new Honeywell and the Honeywell customer service guy helped me get the wires done correctly. The number is 800-468-1502.
Jan 05, 2009 | Honeywell Programmable Thermostat Heater
Heater is not heating up.
First, is this a 120 VAC or 240 VAC heater? 120 VAC heater will usually have one Black & one White wire and 240 VAC heater will usually have two Black wires or one Black & one Red wire. If it is a 120 VAC heater then you need to supply the white wire at the heater with a neutral (white) wire from the breaker panel. If it is a 240 VAC heater then you need to verify that you have 240 VAC at the heater from Black lead to Red lead. If you are not sure about how to do this please have an experienced electrician look at it so you don't get electrocuted and/or burn up your new heater. Hope this helps!
Dec 09, 2008 | Fahrenheat Electric Convector Baseboard...
Honeywell PRO 4000 5-2 Day Programmable Thermostat - TH4110D1007 Logo
124 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
paulcarew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
