I have a 47 inch Toshiba Regza Tv model number 47HL167 and the problem is it keeps turning off and on....while I'm watching tv it will turn off then come back on.....please tell me what the problem is? Thank you
    Problem Solver:
  • 12 Answers
There could be a timer on it check menu
Posted on Nov 09, 2014
  • Brandi Nov 09, 2014
    Thanks Patricia for commenting but, I checked the timer and it was off....still trying to figure out what's wrong with it. :-( do you have any other suggestions?
5 Suggested Answers
SOURCE: TV turned itself off, won't turn back on
I had the same issue with my 42HP95 after about two and a half years. Same symptom, red flashing power light, reset doesn't work and most of all, the last day of the Ryder Cup starts in 3 hours. Any other time (with exception of SuperBowl Sunday). I frantically searched the web for like symptoms and came across someone that posted the fix was to bypass the Seine Module but I had no clue what that was! So what do you do? Tear off the back of the TV and look for something that says Seine on it... Right! After that failed and 500 screws later, I decided to look for a Service Manual online. Nothing like RTFM (Google it!). I paid my $11.99 for a download Service-Manual.Net and found what appeared to be the Seine Module (SEIN). Through a little trial and error, here is what I came up with. The pic below shows the location of the said Module in the red rectangle.
78c6772.jpg I ultimately found that if I unplugged the connector from the module (in red circle) and put it in the cable management loop (other red circle), the TV would power on and has been working ever since.
According to the post I read (grains of salt) the SEINE Module is only needed if you are using coaxial type (rabbit ear) antenna. I personally don't know but it works for me. Granted, this is my experience and may not work for you but for $12, I am a happy camper. BTW, what a Ryder Cup!!! USA USA USA!!!
Posted on Sep 22, 2008
  • 115 Answers
SOURCE: 47" Toshiba Regza 47HL167 - No picture but with sound
My guess would be to suspect the inverter. but from what i can tell that model had two possile inverter types used during production.
toshiba P/N 75008432 Rev C3
AND
75008433 V470H1-L
Posted on Oct 06, 2009
Testimonial: "Thank you.. I will look into that."
vinnyq
  • 157 Answers
SOURCE: Toshiba Regza 40XV645U garbled sound
There is an issue with the audio processor. Most likely it is the main board needs to be replaced in order to fix the issue. You will need to remove the back cover in order to get access to it.
There could also be an issue with the power supply supplying the right voltage to the processor. This can be checked by seeing if the 18V DC is present at pins 3 and 4 of CN90 on the power supply. If the voltage is present, then replace the main board. If it is not, replace the power supply.
Posted on Nov 09, 2009
tvhelp-Dave
  • 178 Answers
SOURCE: I have a Toshiba Regza 42 inch LCD flat screen tv.
I suggest you do firmware update first, then you can use another source such as a DVD plug in to the same HDMI input when the problem appear, to make sure where is the problem, if it is the on the TV, replace the main board.
Part # 75012465 cost approx $300.
Knowledge obtain from: Repair experience on same symptom.
Parts reference: Andrews electronics, 800 289 0300.
Posted on May 02, 2010
REGZA 47HL167 TV is difficult to turn on. when powered on the amber lite flashes 3 times then pauses for 1 second then repeats the 3 amber flashes. If I keep pushing the power button on the side,...
3 flashes of the led light at the front panel is means that the unit is in booting process. The symptoms you've mentioned is caused by faulty electrolytic capacitor in the power supply section.
Look for faulty capacitor with bulged, dome at the top and then replaced it with same ratings. If you have a capacitor checker, it will make you more easy to identify the faulty capacitor without a physical indication of fault.
http://www.youtube.com/watch?v=oDGjWOabJ2E&feature=related
http://www.youtube.com/watch?v=YCSNWi3UHf4&NR=1&feature=fvwp
Oct 07, 2011 | Toshiba REGZA 47HL167 TV
Toshiba regza 47" flat screen last night i was
Check your power cable. Unplug it from both ends and plug it back in
Mar 05, 2011 | Toshiba REGZA 47HL167 TV
How to remove tbl stand from toshiba tv
Usually table stand fixing/ removal is written in related user manual of tv, please check user manual of tv, if you need more info, let me know tv model number of your tv.
Thanks.
May 28, 2010 | Toshiba REGZA 47HL167 TV
No backlights
The T-Con board is dead.This board sit right in the middle in the bottom of the LCD screen panel.This board is dead,require replacement.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish T-Con board for the replacement.
May 24, 2010 | Toshiba REGZA 47HL167 TV
47 inch Toshiba LCD REGZA TV - screen has what looks like water stain or "woodgrain-like" shadows/artifacts. They go sort of vertical but are not straight, (look like wood grain shadows). Not real obvious...
The only way might solved this problem,to replaced the Tuner Signal board.If the board is replaced have same problem,then ur tv have some kind of dead pixels burns in.Tries Shopjimmy.com,Ebay.com for the board part.
Feb 04, 2010 | Toshiba REGZA 47HL167 TV
AND
75008433 V470H1-L
Oct 06, 2009 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
The TV will not turn on. Has flashing orange light
It sound like you have a bad capictor on the power supply. If you take the back off your tv, you will see little round componets. These are the capictors. The tops should be completely flat. You may need to put your finger on the top to feel if they are bubbled at all. Find the one that is bubbled and replace it.
Aug 27, 2009 | Toshiba REGZA 47HL167 TV
Can't remove base-mount from Toshiba REGZA 46" TV, anyone had this problem and had it solved?
Go to http://www.youtube.com/watch?v=rWAJqNVTqug.
The secret is locating a total of four hex (or in some models - 5) screws located at either side near the bottom at the back of the unit.
Jun 28, 2009 | Toshiba REGZA 47HL167 TV
Tv won't turn on at all
Hi
the best thing you do is to go back the unit where it you buy because this is under warranty
Thanks!
Jun 09, 2009 | Toshiba REGZA 47HL167 TV
Televison & Video Logo
521 people viewed this question
Top Televison & Video Experts
Electro Med Services...
