Question about Vacuums
My Bissel Proheat 2x leaks water thru the spray nozzles above the brushes. How do you change the solenoid?
  • 2,861 Answers
Before changing the solenoid, I'd simply clean the valve out.... Easier and more likely to be successful.
Posted on Nov 09, 2014
3 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: water does spray out when using floor bissel proheat
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that will give you all the information you need to fix your Bissell Proheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
Posted on Sep 04, 2010
heatman101
  • 43501 Answers
SOURCE: water will not spray from floor nozzle but will
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
heatman101
dhjjd
Posted on Sep 30, 2010
After cleaning the heater, my unit now leaks when it's turned on.
Hi there. Sorry to hear you're having difficulty with your ProHeat 2X leaking. You may want to contact one of our Authorized Service Centers to have a qualified technician inspect your machine.
Here's a quick link to help you locate one: http://www.bissell.com/service-centers/?cid=ccsocial
Aug 11, 2013 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissel pro2 carpet cleaner stopped sraying how to fix
Hey Diane! Sorry you're having difficulty with the spray on your ProHeat 2X. Here's a quick link to troubleshooting steps to assist you.
http://www.bissell.com/FAQDetail.aspx?id=1122&cid=ccsocial
Jan 15, 2013 | Bissell 2X Proheat 9200 rug cleaner
The water in my bissel pro 2X heat will not spray water
front tank is warped and not seating properly or solenoid bad. solenoid most probable.
May 05, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
I can't get the brushes to rotate and the water to spray on the bissel pro heat 2x.
I have a Proheat 2X and had the same problem. I tried the Water Rinse setting and found water came out and was suctioned properly, but on the Light Clean, Normal Clean, and Heavy Traffic settings, the unit failed to do anything. Problem may be with leaving the soap dispenser in-place, which might scum up the tubing.
SO, an alternative to throwing out my unit and buying somethign else was to put one capful of the Bissell soap in the water resevoir and keep the unit on Water Rinse. IT WORKS BEAUTIFULLY NOW. Don't know if this will help, but at least I didn't have to buy a new unit. Rinse everything after using and there's been no problem.
Apr 24, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
No cleaning fluid or water comming out of cleaner
not sure of your model but on most of the bissell's ( except there new style) the belt drives the pump and the brush on the bottom. no pump action then no spray action. you probably need a new belt.
Sep 03, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell Proheat does not spray water along cleaning brush. Seems to spray just down either side only.
Are the brushes turning? If not then that could be your problem. If they are, check the spray nozzles, they may be partially clogged. Try water a mix of vinegar and water thru it to see if it will unlog your kines and spray nozzles.
May 06, 2008 | Vacuums
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
