My lap, top is stuck in Bios mode well not got back to Windows.what can I do
  • Computers & ... Master
  • 2,826 Answers
My first cure for laptop stuck issues is to first make sure it's not plugged into the charger, and then remove the battery for a minute. when you put it back in, your system should come up normally.
Posted on Nov 09, 2014
4 Suggested Answers
  • 238 Answers
SOURCE: My lap top won't get out of startup
hi, run a bootable disk(xp) run the initial setup procodure, at first options where it asks whether you want to repair previous version , say yes, proceed, it will take u to command prompt, then type :fixboot" press enter, then reboot, thisd should take care,,let me know...
Posted on Dec 20, 2007
  • 162 Answers
SOURCE: my averatec lap top os stuck in sleep mode
Hi. I suggest you try pressing the power button to wake it up or you could also try power draining it and turting it on. To powerdrain your computer you must remove first the battery and unplug the ac adapter then press and hold the power button for 20 seconds, after that you must place back the battery and plugin the ac adapter then turn on your computer. Hope This Helps
Posted on Jun 03, 2010
Sunnyrepairs
  • 808 Answers
SOURCE: my dell lap top is stuck in an endless round of
Repair and reinstall ur windows and use reg in out
Posted on Sep 06, 2010
Can I format my acer lap top in bios mode?
No but you could do it in DOS if you have any pre windows discs.
Feb 21, 2015 | Acer Computers & Internet
When i swicth on my lap top then my lap top hangd waht can i do
reboot while pressing ,which should send you into ROM BIOS SETUP.
Note that "" is the single key on your keyboard labeled F2, and may reside above the "2" key.
Execute any/all diagnostics you find, then, if it passes, try to boot into Windows SAFE MODE,
then if that works, let the system boot into full Windows.
Feb 01, 2011 | Computers & Internet
Battery indicator keep blinking
Try updating the BIOS.
The link for the latest BIOS is given below
http://global-download.acer.com/GDFiles/BIOS/BIOS/BIOS_Acer_v3.13_.zip?acerid=633740982981195132&Step1=Notebook&Step2=Aspire&Step3=Aspire 5100&OS=V10&LC=en&BC=Acer&SC=PA_7
To flash BIOS in Windows mode, please extract CW51313.zip and run the flash32.exe.
Jun 09, 2010 | Acer Aspire 5100 Notebook
My averatec lap top os stuck in sleep mode
Jun 02, 2010 | Toshiba Satellite M100 Notebook
Unable to install XP OS to MSI lap top
Insert your installer to the lap top then try to change the boot up priority by entering the bios. Try to press del key while your lap top boot. If these deosn't wok try F1 or F2 thesame process. If you have enter the BIOS, look for the boot priority which includes the First Boot, 2nd Boot and 3rd boot. Change the 1st boot to CDROM and the 2nd boot to hardisk. Then save the changes by pressing F10. your PC will reboot and it will direct you to the OS installation.
Mar 29, 2010 | Computers & Internet
Few days ago i swiched off my lap top and pul
Are you talking of the BIOS password? Well, turn the laptop upside down and unscrew the plates. Under one of then you will find a button cell about 1 inch in diameter. remove it and reinsert it after five minutes. Your BIOS password will be erased.
If you are talking of the Windows password then you will have to reinstall Windows unless you know thw administrator's password. If you do, then delete this user and recreate it after a reboot. If no, then you must reinstall Window in a directory other than \Windows. For more info read the link
Crashed Windows : No Problem
  • A VERY HAPPY NEW YEAR
Dec 31, 2009 | Toshiba Satellite L45-S7423 Notebook
This morning i got a update for windows.. well!! i updated it and then a error screen came on.. i tried to reboot the note book but its stuck in windows boot manager screen.. my lap top wont shut down.....
Boot into safe mode then go to system restore and restore it to before the update or go to control panel and uninstall the update.
To boot into safe mode:
Right after bios loads up and before windows starts loading start hitting the F8 key
Choose safe mode with or without networking doesn't matter
Nov 09, 2009 | Dell Inspiron 1525 Laptop
MY LOGIQ LABTOP .WILL NOT GO ON THE INTERNET I AM ON A DONGUL 3G .IT WILL NOT WORK SEM SOME IS BLOKING IT.
I assume you mean, Lap Top, because they sit on top of your lap. :).
Make sure your laptop's nic is enabled in BIOS, and that you have the driver installed, and that Windows has it enabled, and in DHCP mode. (call your ISP for settings). Also, make sure your pc security is allowing connection thru that port, and that your router or modem is working properly.
Nov 06, 2009 | Computers & Internet
At start no operating system found
By your description either the drive has died or somehow the BIOS has been changed to not be able to see the drive. Can you run setup on startup to get into the BIOS? From there you should be able to see if the BIOS is detecting the drive. Mose BIOS setups have a selection to automatically detect the drive. I would try that.
Mar 15, 2009 | Compaq Presario 1800T Notebook
Toshiba m35x-s161 won't do anything...
can you access the bios if so reset to default and restart if you cant start up to as far as you can get then try a soft boot (ctl,alt,del all together at once) failing this you could try insert system disk and try to reboot and see if it try to install new copy.if you can get to any of these positions you can reset bios by unplugging and reconnecting rtc,this requires dismantling laptop,i may have service repair manual for your pc ,have to check
Feb 22, 2008 | Toshiba Satellite M35X-S161 Notebook
Computers & Internet Logo
91 people viewed this question
David Payne
David Payne
