Question about Frigidaire Washing Machines
I NEED TO GET SCHEMATICS FOR PC BOARD 4246-99-100 MAGNETEK
I REPLACE DOOR LATCH AND DRAIN PUMP STILL DID NOT SPIN IN HIGH. I WANT TO REPAIR THE SPEED CONTROL BOARD.
  • 1,511 Answers
Too Late now.
Posted on Dec 10, 2014
  • 213 Answers
SOURCE: front load washer wont spin
yes. the solinoid or wax motor (depending on which switch you have) has fail and is not telling control that the door is locked. replacing the switch will fix it
Posted on Nov 20, 2007
ndguy2481
  • 251 Answers
SOURCE: Washer doesn't spin at high speeds
it is more then like the gear in the final spin is going out i suggest calling some one who services kenmore products
here to help
Shaun
Posted on Nov 17, 2008
SOURCE: Won't spin
I replaced the door switch/latch assembly. It works!
Posted on Sep 04, 2009
tunde007
  • 2382 Answers
SOURCE: FRIGDAIRE WASHER FRONT LOAD MODEL#GLTF1240ASO
Hi, are you sure your pump is operating properly any little thing caught in the impeller will stop these pumps. You also say there water still in the tub it will definitely not spin fast with water in the tub. Remove the pump and inspect the impeller sometimes there are things caught in it and other times the vanes are broken right off.
Posted on Apr 21, 2011
KevinWhite
  • 1902 Answers
SOURCE: FRIGDAIRE FRONT LOAD WASHER MODEL
Hello & Welcome to FixYa
The complete door lock-switch assembly needs replacement to solve this problem, replacing the switch only won't help as the control won't detect that the door is completely shut and so won't go to high speed spin. Please get back to me if you have any other questions.
Kevin
Frigidaire CRTR9300ASO won't spin replaced door latch switch and still does not work
Hi bitemejohne - Often when a unit does not spin, it is because the unit cannot properly drain and dispose of the water and detergent solution. Does the unit make a humming noise? If so, the drainage hose/pump may be clogged and needs to be cleaned. Since you have already replaced the door lock assembly then the washer may be experiencing other issues. It could possibly have a faulty pump, timer or control board not communicating correctly. Because it could be a number of any one of several underlying causes, I would recommend contacting a professional to properly diagnose and repair the unit.
Mar 09, 2013 | Frigidaire GLTF2940ES Front Load Washer
Machine will run through entire cycle and will not spin. It quits at the spin cycle. I checked the Black boot at the bottom. Removed and cleared out coins. Checked pump- it was turning freely. Reinstalled...
I had a similar problem and found out the "latch" on the washer door broke off. The machine won't run in spin cycle if the door is"open", but it would run through the wash cycle.
Feb 05, 2010 | Frigidaire Washing Machines
Maytag washer #MAH400AWW drains water fine but will not go into high speed spin cycle
Your washer uses a wax motor door latch assembly with a high failure rate that led to the filing of class suit against Maytag in 2004. The failure of the wax motor results in a no spin problem.
Verify first if the door lock light is on. If not, the wax motor failed and resistor R11 and transistor Q6 on the machine control board also failed. Replace the wax motor and R11 and Q6.
Most technicians will advise you to replace the machine control board and not just the wax motor. But replacing them is not a difficult task. You just need to know how to solder and desolder.
When you opt to ask a technician to repair your machine, insist that only the wax motor, R11 and Q6 must be replaced, not the entire control board. The service will cost you about $300.
Do not hesitate to inform me if you want to do the repair yourself for the complete disassembly and repair procedure.
Jan 13, 2010 | Maytag Washing Machines
E20 error message
replace the control panel or have it repaired,there is no e20 listed as a trouble code,so it needs to be replaced.
To clear latest stored error code:
Place the control into Diagnostic test Mode.
  • Turn the program knob clockwise 9 clicks from the Start Position. The control will signal the last error code.
  • Press and hold the Options and Pause Cancel buttons for 3 seconds. The code will be cleared.
  • Exit Diagnostic Mode to return the washer to normal operation.
Error code - Fault condition
E11 Fill time too long.
E13 Water leak in tub or air leak in air bell.
E14 Reed switch.
E21 Water not pumping out fast enough.
E23 Drain pump relay on control board failed.
E24 Drain pump relay on control board failed.
E31 Better models. Pressure sensor not communicating with control board.
E35 Better models. Pressure sensor indicates water overfill.
E41 Control board thinks the door switch is open.
E42 Door remains locked after cycle is completed.
E43 Control board problem.
E44 Control board problem.
E45 Control board problem.
E46 Control board problem.
E47 Board thinks the door PTC circuit is open in spin.
E48 Board thinks the door PTC circuit is closed.
E52 Bad signal from tacho generator.
E55 Motor overheating.
E56 High motor current.
E57 High current on inverter.
E58 High current on motor phase.
E59 No tacho signal for 3 seconds.
E5A High temperature on heat sink.
E5B High temperature on heat sink.
E5C High temperature on heat sink.
E5D Communication problem.
E5E Communication problem.
E5F Communication problem.
E67 Input voltage on microprocessor incorrect.
E75 Better models only. Water temperature sensor circuit.
E76 Better model only. NTC temperature for the cold water valve over the limits.
E95 Communication error.
EB1 Incoming power frequency out of limits.
EB2 Incoming line voltage above 130 VAC.
EB3 Incoming line voltage below 90 VAC.
EF1 Clogged drain pump.
EF2 Too much soap.
Apr 22, 2017 | Frigidaire ATF6000ES Front Load Washer
Front Load Frigidaire Won't Spin Out
I had the same problem listed above on my LTF2140ES3...the machine did everything but do a final spin. In diagnostics I could do the final spin and the machine kicked out an E43 which is the control board error.
Following the advice here I changed the door latch first and the problem went away and the unit runs as it should.
You'll get "experts" who say that the unit would not spin at all if the door latch was bad. I can tell you first hand that they are wrong. Again the unit did all the normal tumbling but didn't do the high speed final spin. Again, replacing the door latch fixed the problem. The door latch is part number 131763245 (AP3886713)
Jun 30, 2009 | Frigidaire ATF6000ES Front Load Washer
Front load pumps out water, DOESN'T SPIN, but DOES "tumble"
The pressure switch or pressure switch tube could be blocked tricking the machine that it still has water in it therefore not advancing into 'spin mode'.
Or the electronic card could be faulty and require replacing.
Jun 17, 2009 | Frigidaire GLTR1670A Front Load Washer
No spin cycle.
better chance that its the door latch assy, id change that befoer the timer
Jan 21, 2009 | Frigidaire FWTR445R
here to help
Shaun
Nov 17, 2008 | Washing Machines
Front load washer wont spin
Nov 20, 2007 | Kenmore 44102 Front Load Washer
Washing Machines Logo
180 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
