Question about Boating
How can I troubleshoot the spark problem on my Yamaha 115txr outboard motor?
    Sergeant:
  • 456 Answers
You need special tester
Posted on Nov 17, 2014
I have no spark
Change plugs, check wires and coil
Nov 09, 2014 | Motorcycles
Yamaha f50 outboard motor
check fuel pump diaphrams ! primer bulb not sticking !
Jun 19, 2013 | Boating
50 hp yamaha outboard mid 1990's
2 stroke ?? choking up do you mean ? what oil make and mixture ratio ?
May 11, 2013 | Yamaha 40N/50N 40 and 50 HP Outboard Motor...
Yamaha 2.5 hp outboard motor spark plug gap
I Would Recommend a 0.8 Gap
Mar 10, 2013 | Boating
Yamaha 200hp 2001 manual
  1. Fuel
    • A common problem with an easy solution, Yamaha boat engine trouble could arise due to inadequate levels of fuel or engine oil. All Yamaha outboards take unleaded gasoline as a main fuel source with a pump octane rating of 86 or higher. The type of engine oil varies according to motor size and can be found in the "Specifications" section of a particular outboard's owner's manual (See Resources).
    Electrical
    • Problems with the electrical system can also prevent a Yamaha outboard's engine from working correctly. Troubleshoot the electrical system, first removing the main fuse that's located underneath the electrical panel on any electric-starting outboard. If the connection at the center of the fuse is broken, it must be replaced by a fuse of the same amperage. The battery should also be removed, cleaned and fully charged when troubleshooting the electrical system.
    Spark Plugs
    • Owners should also remove and inspect the spark plugs during the troubleshooting process. If the insulator tip of any plug is burned, that spark plug should be replaced. The number and type of spark plug depends on the specific outboard. Additionally, owners should ensure that each spark plug gap is set to the width stipulated in the owner's manual (see Resources).
Jan 20, 2013 | Motorcycles
Yamaha 4HP outboard - cannot pull starter cord - jammed.
Engine or gearcase seized...
Remove the recoil starter ( 3 bolts and the startingear link)
If you can turn the flywheel slightly: Gearcase seized
If you can't turn the flywheel at all: Engine seized.
In both cases: If you can't disassemble and have the job done yourself, forget that motor...
Dec 09, 2012 | Clymer Marine Maintenance and Repair...
Spark plug gap 150 hp Yamaha outboard
The correct gap is .035
Sep 29, 2009 | Boating
40hp 1987 yamaha outboard motor will run for 30-60
Sound like the fuel pump is not keeping up with the engine's demand. Check it out. Good luck. Hope this helps.
Apr 27, 2009 | Boating
Motor kills when put into gear
u have no spark in #2 cyl check for spark with plug if its week regap it
Feb 25, 2009 | Light Outboard Motor Boat Bass Fishing...
Boating Logo
75 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
