Nextbook Premium 8 Se Android Logo
j
jim hall Posted on Nov 09, 2014
How to fix E:cant mount udisk factory update param.aml
Wont start
Will not boot-up or start
Hi there, If your tablet will power on, but won't boot up, then take a look through this:How to Factory Reset Your Android Phone or Tablet When It Wont Boot
If it won't power on at all, try out these instead:
What to Do When Your Android Phone or Tablet Wont Turn On
My Android Tablet Wont turn on Anymore And cant take the back off
If those do not help, then contact the manufacturer.
I post on behalf of HP.
My kurio wont finish loading how to fix
You cant factory reset it. That only works on apple.
3helpful
2answers
Proscan PLT8235G stuck on blue screen. Reset button just shuts tablet off, and problem still remains.
I have had the same issue with this tablet. After weeks of looking around on the net i have found a way to reset the tablet to factory settings when the power and vol down button will not work.
1. Download the firmware from the proscan website. http://www.proscanvideo.com/item.asp?itemnmbr=PLT8235G.
2. unzip the file and copy the files update.zip recovery.img and factory_update_param.aml to an external micro sd card.
3. Plug the tablet in and insert the sd card. Press the power button to see the battery icon then press the power button 5 times. Then let it run for 4 minutes and it should be set back to factory settings.
****NOTE***** If it fails to update then you still have the access to the recovery menu where you can do the factory wipe and still reset it.
Hope this helps.
2answers
Proscan 8 inch tablet with android 4.1 jelly bean
Sorry, I have no solution to offer. I am in the same situation and resets aren't working. Wondering if OS is deleted and if so, how to reinstall. So frustrating!
Why wont my camera work on my brand new zeepad 7.0?
could be corrupted data or bad app,going to settings and reset to factory default that should fix corrupted data, if it still persists check for firmware updates in the settings, then check for app updates. if it still exists after that return back to factory for warranty repair
Cant connect!!!
try to update firmware, keep reset button for several seconds
2answers
My android next book nx008hd8g will not go past the first screen I did the data wipe factory reset still nothing
nextbook cant pass talkback, wont allow me to enter pass word, how can fix this?????
I just bought a used sylvania 10" tablet but i can only use to search the web because i cant acces any apps, download anything, take pictures, nothing really and its really slow. what can be the problem...
do a factory reset, then do the updates. if the last owner "unlocked" it, a whole differant route needs to be taken. if you cant access anything, you got nothing to loose.
Top Nextbook Tablets & eReaders Experts
NOEL
NOEL
john h
Are you a Nextbook Tablet and eReader Expert? Answer questions, earn points and help others
