Question about Video Cameras
<!-- from fixya rte -->Where can i find the adaptor - Video Cameras
  • 3,506 Answers
For what make and model??
Posted on Nov 09, 2014
My karaoke machine won't work with the adaptor
Try changing your adaptor. The wires in a lot of the cheaper adaptors are small, and often break after too much flexing. You can buy a universal power adaptor quite cheaply, just make sure you set the polarity correct.
If that doesn't fix your problem, there may be an issue with the adaptor socket or the PCB board it mounts to. This will require disassembly to find the issue.
Nov 07, 2013 | Emerson SD512AC Karaoke System
What is network adapter mean
A network adaptor is an interface device that allows your PC to communicate with other computers and the internet. There are wireless and wired adaptors.
Wireless adaptors usually connect your PC to the network through a wireless router and modem. Wired adaptors (also known as ethernet adaptors) connect your PC to another computer, a router or a modem using a cable.
Regards,
Yavacotech
Jan 05, 2011 | Microsoft Wireless Network Adapter Xbox...
Laptop does not work off mains and battery does not charge
Just check the power connection from the AC going to your laptop if the power adaptor of your laptop are working. Note; you only know that the power adaptor was working if the LED (Light Emiting Diode) was light because the power adaptor are have the LED to see it that they are working normally. If the power adaptor working normally their was a problem of the power supply inside your laptop and need to be repair by the electronic service center. But if the power adaptor are not working the problem are in the power adaptor. I recommend that you replace your power adaptor and bring it to the computer store to check its type and model it is because only same type or model of that power adaptor to be replace.
May 19, 2010 | Dell Inspiron 6000 Notebook
Is there an adaptor that goes between the
yes some taptop use adaptor and don't use adaptor.
Jan 11, 2010 | IBM ThinkPad R40 2722 Notebook
LG latop adaptor wizzing
does it start with batteries...may be the adaptor is out...try borrow an adaptor from friend and try...
Dec 26, 2009 | Computers & Internet
Ac adaptor on my 32 Protron inch LCD TV no longer work
What is the current output of the adaptor? If it is AC and you use only the 12v to 3v it is ok. But if the current output of the adaptor is DC and you use both 24v to 6v and 12v to 3v there is some danger if use the new one. Remember that DC current have polarity.
Aug 29, 2009 | Protron PLTV-32 Television
Can 15 volt power adaptor be used on an 18volt scanner?
you dont have other choice, how about to buy an multi plug-in adaptor from 3V up to 23V can manage the voltage of your scanner, but if not this 15volts can support your scanner..
Jun 22, 2009 | HP ScanJet 2300C Flatbed Scanner
ACER ASPIRE LAPTOP 2920 NO DISPLAY
Ckeck if your adaptor has power on the connector to laptop.
Might be damaged power cord (to and from the adaptor) or broken adaptor.
While there was power in the battery, it was running, but not charging.
Now the battery is emty and can't be charged because of broken adaptor/cables.
If you find there is no power from the adaptor, bepair it or buy a new one.
Do not try to repair the adaptor by yourself if you are not a technician, it is DANGEROUS !
Either give it to a qualified servicer, or betteer, buy a new one.
Regards.
Mar 27, 2009 | Computers & Internet
Lightning strike ac adaptor is fried
Your phone did expirence a surge that probably blew the ac adaptor which happens most of the time, u can buy one of those universal adaptors and look on the back of the old adaptor for the output voltage it will usually read between 3 and 8 volts DC.Set the universal adAptor voltage to the setting right below the voltage output on the back of the ac adaptor.
Aug 04, 2008 | Uniden Cordless phone EXS9950
HP printer AC power adaptor 0950-4399
I want to purchace new HP printer AC power adaptor 0950-4399 from mumbai where shall i contact
Mar 26, 2008 | Office Equipment & Supplies
Video Cameras Logo
Top Video Cameras Experts
Are you a Video Camera Expert? Answer questions, earn points and help others
