Question about Insignia NS-24LD120A13 24in 1080p LCD HDTV / DVD Combo
Auto Channel Search does not find any channels
No channels display. Just snow. Verified cable is working properly by hooking up another TV. Did a factory reset and ran Auto Channel Search again. Any ideas?
    Top Expert:
  • Insignia Master
  • 74,198 Answers
Do a hard reset to this set, and check. There are two types of reset to TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight; will be better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
If a hard reset do not help you, its main system control memory IC is faulty, and should be replaced. Contact any service technician.
Posted on Nov 09, 2014
jerryg50
  • 1667 Answers
SOURCE: insignia NS-LCD32 TV
The tuner section, and or the voltage regulator circuit that supplies it is probably failing. The service rep for your set may be able to order a new tuner module and install it. This is not a type of repair you can do yourself.
Jerry G.
Posted on Jun 28, 2008
panchal643Ja
  • 243 Answers
SOURCE: Aspect Ratio problems with Insignia 26
Keep your Auto Zoom Off set Full screen than only you will get proper picture
Posted on Jan 21, 2010
tthekraut
  • 374 Answers
SOURCE: 19" LED TV INSIGNIA HD
I have one of the same tvs. Start by going under menu,setup,tuning band and set it up for antenna. When you get that far put in auto channel search. To see how to get best reception where you live go to http://www.antennaweb.org
Comment if you need any further help
Posted on Mar 17, 2010
  • 8457 Answers
SOURCE: Cable picture is fuzzy
Ur standard DTV signal picture ok?Not than ur Main Tuner signal board is dead.Must replaced the Tuner signal board.
Posted on Apr 05, 2010
John-INSG
  • 312 Answers
SOURCE: I have a 32 in insignia and a universal remote was
Turn your TV off and unplug it for several minutes. Remove the batteries from any remote controls that you use for the TV, press all of their buttons, and install fresh batteries. Reset the TV to factory defaults. The universal remote control should not have caused any damage to the TV. If the problem persists, we recommend that you seek service by calling 1-888-237-8289 in the U.S or 1-866-237-8289 in Canada.
Posted on Jul 02, 2010
My tv won't find any channels on channel search mode. What do I do? I am replacing a tv that has been hooked up until we went to put the new one in. Model# ELEFW328
Is the cable connected properly? In settings of the TV have you told it which video input to use to auto find the signals?
Aug 17, 2014 | Televison & Video
Wont find channels on auto channel search
Ensure that you have a good connection to your antenna/cable/satellite, and that you have selected the proper signal type in your TV menu.
If you are using a cable box or satellite, you might need to search for an analog signal on channel 3 or 4. If your cable/satellite box outputs an HDTV signal, then search the digital channels. If you are using an antenna, search for digital channels and set it the TV to Air in the Channel menu.
Apr 07, 2014 | AOC Televison & Video
My Samsung TV model # TX62045 only displays one channel when hooked up to an antenna. Previously used cable.
Go into menu and switch from Cable to Air-Antenna. Then run auto programming.
Aug 13, 2011 | Televison & Video
My new HCT LCD TV is not getting my local channels
if your tv is hooked up with cable program as a source their might be problem with the cable provider try to contact for assistance.now if you just only using the areal antenna as a source try re orient first the proper position of the antenna to receive local channel. channel scan much better also either the manual search or through auto channel search . good luck hope this may help.
Jul 21, 2011 | Televison & Video
Auto search through
Tested and verified solution:
  1. Set Tuner Mode to "antenna".
  2. Run a channel scan. Should get zero channels found.
  3. Set Tuner Mode to "cable".
  4. Run another channel scan.
  5. Celebrate!
Aug 16, 2009 | Vizio VX37L Television
Auto Channel Search
sounds like the tuner section of the main pcb isn't working properly.
Jul 28, 2008 | Dynex 32 in. LCD Flat-Panel HDTV
No channels
i had the same damn problem for 3 long hours but i found a solution i have olevia 32 inch tv (720). all you gotta do is go to menu>setup>tv>auto channel search> cable> standrad search
Sep 21, 2007 | Olevia LT32HVE 32 in. LCD Television
No picture or sound
If you see only snow and the words "NO SIGNAL" are displayed, and you know that you have the set hooked up to a good signal and the TV is set to the right channel, it means that your tuner has stopped working and needs to be replaced. First, though, make sure your signal is good. A good way to test this is to hook the TV to a good VCR, put in a good pre-recorded tape and hit play. Tune the TV to channel 3 (or 4) and if it is still all snow, have the tuner replaced by a qualified tech.
Sep 03, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Can't get any tv reception
My friend, you need to hook up a signal source such as an antenna or cable . The channels wont come in and it will all depend on where you live and how close to a major city on what and how good you will get the stattions. then once an antennena is connected, do the auto programming again. Good Luck
Aug 18, 2006 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Insignia NS-24LD120A13 24in 1080p LCD HDTV / DVD Combo Logo
109 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
