My vizio blue ray player will not open to insert disk though I can hear it trying
Look at the bottom of the unit, just below where the tray opens, look for a small hole. If its there, that's the manual release. Straighten a paperclip and push it into the small hole to release the tray lock.
Posted on Nov 09, 2014
  • 247 Answers
SOURCE: Problem with Wall-e Blue Ray movie
i would say the problems comes from the way the company formatted the movie onto the blu ray discs. and i would say that there will most likely be a recall on them. if anything connect the manufacturer of the movie. hope this helps you.
Posted on Dec 17, 2008
  • 3 Answers
SOURCE: blue ray player wont play blue ray ''Kung Fu Panda'' disc.
i fixed this exactly as previous posted solutions, however a couple of points.
a) recordable CDs work if you don't have a DVD burner.
b) I didn't have a CD burner that would do an "image burn", I downloaded a free copy of "Express Burn" and that worked fine. The disk needs to be "finalised" or "fixated", it should do this automatically, or it may be a tick box selection.
c) I got a "No DWLD 09" when I put the disk into the player. I found this was an incompatibility with the CD-R (Maxwell) I was using. I changed to JVC and it worked fine.
Posted on Dec 29, 2008
jan mczeal
  • 632 Answers
SOURCE: want to update my sharp blue ray disk player bd-hp21u
To obtain the software update file, please call 1-800-BE-SHARP (23-74277). Save the update file into a USB drive.
  1. Insert the USB memory device
    with the update file into the BD
    STORAGE/SERVICE terminal on
    rear of this player.
  2. Press SETUP to display the SETUP
    MENU screen.
  3. Press arrow keys to select
    “SETTINGS”, then press ENTER.
  4. Press UP/DOWN keys to select “SOFTWARE
    UPDATE”, then ENTER.
  5. Enter the 4-digit number using 0-9.
  6. Press ENTER to start checking data
    in the USB memory device.
  7. During the data checking,
    “Checking” blinks.
  8. The current version of this unit software
    and the version of the update file on the
    USB memory device are displayed. To
    update this player software with update
    file, select “YES”, and press ENTER.
  9. If the USB memory device is not
    properly installed or the correct update
    file cannot be found on the USB
    memory device, an error message is
    displayed.Check the file on the USB memory
    device, and then reinsert the USB
    memory device correctly.
  10. Press ENTER to start updating.The screen becomes dark for a
    while until the update screen can be
    displayed. Please wait for the update
    screen to appear. Do not unplug the AC
    cord
  11. When the software is successfully
    updated, a screen is displayed
    indicating that the update process is
    completed.If the update has failed, check the file
    in the USB device and try Software
    Update again.
  12. Press POWER to turn off the player.
  13. Remove the USB memory device.
Posted on Oct 18, 2009
  • 54 Answers
SOURCE: Toy Story 3 will not
Have you updated your Blu-Ray player recently? All BD players need to be updated from time to time because of the growing technology of Blu-Ray. Its always been a con of BD players. Best thing to do is have your player connect to the internet.
I hope this is the back of your player. Connect your Cat5 (Ethernet cable) to your BD player and than to your router or modem. The port should look like this on the back of your player.
Once you have this connected start your player and it will have a option in the menu to update. Once the update is complete Toy Story 3 and all new BD discs should work. If not, its possible that the disc is bad. More often you just need to update the player.
Posted on Nov 03, 2010
SOURCE: my sony blue ray player
I'm having the same problem. My BDP-S350 Blu-Ray Player used to play blu-ray DVD's but suddenly is unable to. Regular DVD's I can play. Please help!
Posted on Nov 25, 2010
My blue ray player quit playing any dvd/cd etc.apps still work.what could be the problem?
When you load a disc can you you hear it spinning? If not then the primary drive motor or drive mechanism is broken . If it is spinning can you hear the laser extract information as it boots up ?
If it spins and then comes up with disc error or any non compliance message then the laser may be out of sync or jammed. Be very carful if you decide to open it up on your own as obviously you run the risk of a fatal electricity shock.
blue ray disc players and especially temperamental if they are in say a ps3 or have a dual function.
my opinion is to have a professional look at it .
good luck
Mar 07, 2015 | Vizio VBR220 Blu-Ray Player
Error message when my Blue Rays reads dvds
It's a software issue. you need to ring the manufacturer to get files and instructions on how to upgrade your machine so it can play the newer blu ray movies. Quite a common problem.
Feb 25, 2014 | LG BD550 Blu-Ray Player
Is it normal when you turn on a visio dvd blue ray player, you hear a sound.
You might hear the disc drive spin to read if there is a disc and what kind of disc it is. Other than that it is fairly quiet.
Apr 19, 2011 | Vizio VBR220 Blu-Ray Player
While playing a dvd disk, the player stopped and displayed SYS ERR. cannot remove this disk
Some (not all) DVD players have a manual open mechanism on them. It's a tiny hole under or near the DVD drawer where you can insert a stiff wire (straightened paper clip) straight in and push gently to force it open. Most PC CDROM drives have these; not sure about Blue Ray players.
James
Apr 17, 2011 | Sony BDP-S560 Blu-Ray Player
Player reads "no disk" when
Try updating the firmware on your player and check to see if your player supports the disk type.
Mar 08, 2011 | Vizio Televison & Video
My dvd player says "wrong disc" for all dvds
Sounds like the DVD/Blue ray laser has gotten dust on it.
I would go to your local electronics store and purchase a cleaning disk. They are normally under $10. Insert it and run it though the player.
This sound no more serious than a dirty read laser.
Jan 29, 2009 | Coby DVD-224
Dec 17, 2008 | Samsung BD-P1400 Blu-Ray Player
Can't power on
try unplugging the dvd player then plug it back in as this treats it like a reset.
Mar 13, 2008 | Aspire Digital AD-8091 DVD Recorder
Televison & Video Logo
41 people viewed this question
Top Televison & Video Experts
Electro Med Services...
