Question about Maytag Washing Machines
<!-- from fixya rte -->Grinding noise and will not adjatate - Maytag Washing Machines
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 7 Answers
Sounds like the drum bearings have gone try turning the drum by hand if it still grinds then you will need a bearing kit tricky to dismantle and fix but no impossible .
Posted on Nov 09, 2014
GE Washer wds2080d8ww will not adjatate
Lid switch If the lid switch is defective, the washing machine may not agitate or function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Nov 22, 2011 | GE Washing Machines
Hi, I have a Kenmore 110.26832692, lately it's been making a loud grinding/thumping noise when agitating. The clothes end up wrapped around the agitator, sometimes even stuck underneath it. The basket...
Sounds like maybe the changing of the dogs might be the problem./The top section of your adjatator sould move freely one direction turn it the other way bottom section should move with it. If it does not do that then your dog install got messed up also you should not barely get fingers under botton section of adjatator/ Note the basket is not supposed to move when washing on this unit . see if unit is doing any of those things get back to us...Good luck
Feb 09, 2011 | Kenmore Washing Machines
When i get on the gas i hear a grinding noise
is it a grinding noise, or vibration noise, as sometimes the heat shields can produce a vibration noise that can be misheard as a grinding noise......does this grinding noise go away as you brake ????...do you hear it more whn you go left or right ???
Dec 20, 2010 | 1997 Jeep Grand Cherokee
52 grinding noise from under car . not sure if it
Hi, When a grinding noise is detected first locate the area of the car it is being generated from. Most grinding noises will be being generated while driving, if you are having a hard time detecting the location of the grinding sound, have a helper ride along in the rear seat to give a new perspective on the origin of the grinding noise. A grinding noise can be generated by many things from worn out brake pads to axle bearing failure. Once a grinding sound has been detected action must be prompt. Grinding in most cases is telling you something has failed or is failing. It can be as a result of worn out brake pads or shoes, check your engine and transmission mount, check for axle bearing failure, check your power steering system for leak...
Take care
Jul 23, 2010 | 2002 Jaguar X-Type
I have something stuck under the adjatator. How
Hi, depending how old you GE washer is will determine how difficult the agitator will be to remove. However, all GE made ( hotpoint, baycrest, some kenmore, moffat, mcClary, etc. ) washer's of the past 50 yrs. or so have agitator's that are pressed onto a drive block and need to be pulled off, sometime's by hand, sometimes by a greater force, i.e. "agi-tamer" or "hammer". ( of course the hammer method will require you to by a new agitator ). The "agi-tamer is a real tool which slides under the agitator and by way of being pressurized with "cold" water ( hot will burst it ) will push the agitator up off the spline/block...don't stand over it looking down or you'll potentially get "knocked out" ha ha ! Hope that help's. At least you know it does "pull off" and it isn't bolted in place. Good luck, macmarkus :)
Feb 16, 2010 | GE Washing Machines
Lexmark C510 is making grinding noises while printing large jobs
I found another posting stating that the culprit was the black toner cartridge. Sure enough I changed our black cartridge and the grinding noise has stopped. No wonder the grinding noise was not happening all the time only when the black cartridge got low. Thanks for the help!
Oct 15, 2009 | Lexmark C510 Laser Printer
My kenmore washer will not adjate.
You probably have a broken drive coupling. The part is cheap enough. here is a pdf:
http://appliancejunk.com/motorcoupler.pdf
Here is one from Jimbo:
http://repair2000.com/coupling.html
Here is one I made:
Direct drive coupling replacement by
TheMobilian
May 16, 2009 | Washing Machines
Washer will not empty
sounds like coupler is out but unit should still drain unless motor locked. remove cabinet (2 brass clips under console) and check pump (up front) and coupler (behind motor). set to spin and tub wont move with coupler out but pump will run
Apr 05, 2009 | Whirlpool Inglis IP4400 Washer
GE WJSR2070B won't agitate
There is a drive block under your adjator. You must pull the adjator off. Get your fingers ( Man Friend LOL ) under edge of adjator & pull. You will see a plastic pat with screw in it . if you can spin with hand , replace it .
Mar 01, 2009 | GE WJSR2070B Top Load Washer
Adjatator not turning
your pump or outlet pipe might be blocked if n ot then the pump will be faulty
Nov 19, 2008 | Hoover Washing Machines
Washing Machines Logo
46 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
