Question about Kitchen Appliances - Others
What do I do with the power cord (female end) hanging inside the popper?
  • Martelle Deeprose
    Martelle Deeprose Nov 09, 2014
    Ah! OK, just realized it plugs into the kettle ;).
    Champion:
  • 252 Answers
That should be plugged into the kettle.
Posted on Nov 25, 2014
Popcorn popper isn't popping popcorn
If it heats up, your popcorn may be old and dried out. If it doesn't heat up and the stirring rod does not turn, check your power cord for defects. Procedure: plug in the popper (check both ends of the cord!), turn it on, and gently wiggle the cord right at the plug or where it goes into the popper, and watch the stirring rod to see if it moves. If it starts and stops as you wiggle the cord, you've found the break in the cord. Repair it or replace it (West Bend lists it online for $5) and be more careful with the cord in the future (never unplug by yanking on the wire, always pull on the plug itself).
If the stirring rod turns and there is no heat, the thermostat or thermal fuse is probably open. This can happen in some poppers if the air vents are blocked on the bottom. Remove the obstruction from the vents, let everything cool off, and try again. If it does not heat up from a cold start, there may be a blown thermal fuse inside. If you decide to replace the thermal fuse or thermostat, it MUST have the same temperature and current rating as the original.
Jun 17, 2016 | West Bend Westbend Popcorn Popper Stir...
Can you use a power cord from a Samsung 39 inch flat screen on a Samsung 65 inch flatscreen
yes, most tv's that i know of take two types of power cords, both of which are ok to mixmatch. As long as the new tv uses a molded u ground cable (3 holes on female end) or the smaller ones (2 round holes on female end) which most do it is perfectly safe to do so. As long as the tv did not have the box attached to cord ( regulates wattage) if that is the case you need one that supplies the EXACT wattage to the tv but i have yet to run into a tv that uses a power cord like that.
Feb 21, 2015 | Samsung Televison & Video
Weird input cord for my comouter....It looks like usb cord with one end has a triangle end on it female plug with male flat part inside
This is NOT a USB plug, it is firewire. This is a similar but competing technology. Only plug firewire devices into firewire ports not USB.
Sep 03, 2012 | Shuttle XPC Computers & Internet
I want to replace the cord/plug is it easy?
Malibu power packs are 1-piece units that can't be taken apart.
However you can cut off the cord and leave about 4-6" of cord sticking out, and then splice into the cord that's sticking out.
Usually I buy heavy orange or black extension cord with male-female plugs on each end.
I cut off female end and use that end to splice into the cord that's sticking out.
How to splice wire.
Use knife and slice down the cord lengthwise... just cut through the outer plastic covering.
Pull the outer cover cover back to reveal black and white wires.
Cut off extra cover.
Cut back insulation on each black and white wire.
Now you have 2 black wires and 2 white wires/
Twist together the copper wire on whites and cover with plastic electrician tape.
Do the same with copper wires on blacks.
Now the blacks are joined/ and whites are joined, and each has tape over copper wire.
Wrap black tape around both sets of wires until all the black and white is covered with several wraps of tape.
That's it. Plug it in.
Nov 23, 2010 | Intermatic Malibu 300W Power Pack...
Power cord will not light up where it is inserted into the laptop unless you hold it steady. It will not charge unless it is held in a certain position. Is the male part on the cord bad or is it the female...
You'll need to get another power cord that is identical in power and polarity and plug. One can buy a generic power supply from Walmart that will power most laptops or Radio Shack (Walmart is probably cheaper).
Once the new power supply is obtained, try it, and if the same thing happens, then the problem is in the female plug connection to the motherboard of the Compaq Presario C762NR Notebook.
The Notebook will have to be disassembled and the female plug connection to the motherboard will have to be replaced.
If the male plug end shows any fraying or excessive bending signs, then I would definitely replace the cord.
It is difficult to determine which is bad, the male or female part without changing the easiest part... the power supply.
Also, you could go to your local Compaq dealer and ask to plug in one of their power supplies to your computer and tell them the problem that you are having, determining which is bad, the male or female part of your power supply.
Good luck on this repair.
Aug 17, 2010 | Compaq Presario C762NR Notebook
Where is the power source? Monitor came with no cord and cannot locate the power source input.
On the back of the monitor you should find three prongs that plug onto the female end of the power cord. The monitor power cord will look the same as your computer cord.
Oct 01, 2009 | View and View Technologies Computers &...
Power cord will not make consistent connection with computers
you must remove the mainboard completely from the laptop case to repair it .
Aug 01, 2009 | Averatec 3200 Notebook
My popcorn machine wont heat up
First, if you have another cord like this one (for example, a coffee pot cord) plug it into the popper and see if it works.
If it's not the cord, it's probably a blown thermal fuse inside the unit. Could be a heating element broken as well. If you don't have appliance repair experience, I would take it to a repair shop.
May 03, 2009 | Cretors Goldrush Popcorn Maker
Dont know how to turn on
The monitor has and adapter type power cord that plugs into the computer end of the VGA cable. Look for a small round hole at the PC end of the cable.
Jun 08, 2008 | KDS Radius RAD-7 17" Flat Panel LCD...
Kitchen Appliances - Others Logo
65 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
