What is wrong when there is a fuzzy line going across picture only when tape in vcr
  • 5,530 Answers
Tape bad! Try different tape!
Posted on Nov 09, 2014
  • 84 Answers
SOURCE: VHS Tape on Sanyo Doesn't play on other VCR's
the heads on the sanyo vcr may slightly be out of alignment from years of use.when playing a recorded tape from this vcr to another, the other vcr's alignment maybe right on track thus causing the poor quality.you can possibly try cleaning the heads with a head cleaner or a high grade blank tape,but i don't think this will solve the problem. but you can try.
good luck
wg
p.s also try higher quality tapes to record on.
Posted on Feb 04, 2008
  • 4234 Answers
SOURCE: how do I get my VCR to tape programs
Two things to check here. Lets verify the basic functioning of the unit. Have you tried playing back a pre-recorded tape? If so, please post the results here. I suspect that a pre-recorded tape will fail as well. If so, I'll post instructions on how to resolve the problem.
Please keep me posted.
Thanks,
Dan
Posted on Dec 31, 2008
jomabug76
  • 1148 Answers
SOURCE: We are trying to record a VCR tape to another tape
USE ANOTHER VCR,,2 OF THEM
Posted on May 15, 2009
  • 284 Answers
SOURCE: My VCR player plays a fuzzy picture.
its a tracking problem or just needs a good clean
Posted on Jan 23, 2010
Grubhead
  • 5151 Answers
SOURCE: iv got some old vhs
All you can do is adjust the tracking and make certain the video head is clean. I would have a look inside each VHS tape at the tape itself, it might have got mould or damp inside it.
But if the video machine plays back it's own tapes and commercial tapes OK, it could be the tapes have gone bad.
Posted on Dec 07, 2010
Vcr tape play fuzzy
You need to clean the video head.
Apr 14, 2013 | Televison & Video
Vcr has sound but wiggly line picture, very fuzzy
VCR player head drum is dirty,require cleaning.Still can buy a head cleaning tape at Amazon.com or Ebay.com.
Dec 20, 2010 | Symphonic SE436G VHS VCR
Ewd2202 dvd/vcr combo when i put a vcr tape i can
the video heads are probably dirty.there is a steel drum 1/2 inch thick that you can see if you look thru the front lid where the tape loads.the video heads are little black spec looking things on the bottom of the drum.the easiest way to clean the drum for a novice is to put isopropyl alcohol on a piece of 2 inch square paper.hold the paper very lightly against the drum with your right index finger.turn the drum from the top,anti clockwise.you will see some black stuff on the paper.do the same with a piece of dry paper.otherwise the tape will stick to the drum if still wet.DO NOT use a q tip,as it will get caught in the heads and break them.
sometimes,just running a new blank tape for 15minutes will dislodge the particles and the picture will re appear.if you have recently rented a movie,and saw lines running across the screen,and noise from inside the machine,it is damaged tape going across the heads and drum and it can wipe out the picture just like that.run a blank tape first and then clean the drum if you have to.
Jul 07, 2009 | Emerson EWD2202 DVD Player/VCR
Good Audio, NO picture
you need to clean the heads, buy one of those cleaning tapes and run it through!
May 24, 2009 | Toshiba MV13N2 13 in. TV/VCR Combo
Has fuzzy spots all the way across the screen and just scrolls up
Is the picture fuzzy whether you are waching tv or a dvd or a tape. If it's only fuzzy on tv or dvd or tape then it's the source. If all inputs are fuzzy suspect a bad tv.
Apr 04, 2009 | LG 42LC2D 42 in. LCD HDTV
VCR Issue with Toshiba SD-V295KU
This may be a bit late but I just ran across these posts. All these problems can be caused by bad tapes. Commercially-made tapes will usually play properly. But home recorded tapes, or very worn tapes, may not play back properly in every VCR. If the VCR isn't getting the right information off the tape for proper playback, it's muting the sound and the screen so you don't see any snow. It's also possible that the VCR heads already need a cleaning. It takes just one worn-out or defective tape to clog up the heads and cause the "no picture" problem, although in this case sound isn't usually affected.
Dec 21, 2008 | Toshiba SD-V295
Lines across the sreen when i play back the tape
Someone here recommended on another post to put the lense cap on & videotape the blackness in a quiet room for 5-10 mins. I tried this as a last resort & it worked. When I played back the tape, no more skipping or gray lines. I had 4-5 SOLID gray lines with skipping video & audio in between on every tape I put in. I think the person who helped me solve this said that it was a result of the tape alignment going off.
Nov 25, 2008 | Canon ZR800 Mini DV Digital Camcorder
Panasonic DMR-EZ47V Fuzzy horizontal line in VHS mode
Dirty heads or the recording was from a different brand VCR and the Panasonic cant get the right tracking. Try manual tracking just a little in either direction to you get the right one.
May 18, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Only plays picture when fast forward.
Cleaning or video head replacement time....accordianman
Feb 11, 2008 | Zenith VRB420 VHS VCR
VHS Picture on new recorded tape shows horizontal bars.
clean the head of your vcr that will help also connections of the wires good luck.
Mar 29, 2007 | Sony SLV-D550P DVD Player/VCR
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
