Model# WA5451ANWXAA02
The code suggests a balance issue exists. If excessive vibration occurs during the spin cycle the washer should be made level with all feet on the floor surface. Should there be soft spots under the floor surface, the machine will not distribute the spin energy equally.
If you have eliminated the above possibility yet the problem remains there may be a binding within the machine enclosure or a damper may be worn.
SOURCE: kenmore elite washer top loading 6 years old clothes still wet after spin cylce
Click on 'washing machines', then brand name (below FIXYA) on this website, type in your model number & search. You will get a shortlist; click on your model,below the page u will get Manual/Guides. Click on the blue, you have your manual on line. Possible your filter is clogged after these years.
And dont forget to rate me on this great site.
SOURCE: Error code F09/Whirlpool Duet front loading washer
"F09" is an Overflow Condition error. This is usually attributed to a malfunctioning pressure switch, loose or broken connector between the Pressure Switch, Drain Pump and Central Control Unit (CCU), or...a drain pump or drain line that has become clogged.
Since this problem occurs periodically during the wash cycle, I would check your drain pump filter for obstructions first. It could be that you have debris lodged in the pump causing it not to drain properly. To access the pump:
1. Unplug the washer.
2. Remove the lower kick panel under the door by removing the screws under the bottom edge. HINT: Placing a couple of blocks of wood under the front feet of the washer will make access much easier.
3. The drain pump is located under the wash tub in the center. HINT: If you own a shop vac, remove the drain line from the standpipe at the wall and pull a vacuum through the drain line. This will remove all residual water from the washer and make clean up later a lot less messy. Now, remove the cover on the drain pump and remove. Clean out the pump filter and check the pump impeller for obstructions.
If you do not own a shop vac, place a bunch of towels around the drain pump BEFORE you open it. There's about a gallon or so of water in the tub, drain line and pump.
Try this first, and let me know if this corrects your problem. If not, you may need to check the pressure switch and wiring. I hope this helps you.
SOURCE: error code f24
F24 indicates a water temperature sensor error. If during the wash cycle in the water-heating step, the water temperature sensor (NTC) value is out of range the F24 error code will display.
Possible causes:
SOURCE: What do I do with an F51 code on my Cabrio Washer?
speed sensor and a control board
upgrade rps sensor and it will eliminate the problem
SOURCE: Neptune FAV6800AW Top Load Washer: My Neptune washer is showing error code dc..Once i...
See this post Clutch Fix if you want to DIY I will help you.
Post back if you have questions……..Rich
