Im having a problem with my Panasonic crt tv model # ct-25g7f. When power button is pressed it turns on and then turns off by itself if pressed on occasion after a while it turns on and picture is good.What could be the prob here? I'm thinking it's the big filter caps in the cold side of the board. There is also a slight popping sound in the back when it eventually comes on.I inspected it and dusted the board off everything looks fine no burns or anything no bulges on caps either and no leaks or spills.
    Problem Solver:
  • 3 Answers
My question on your problems;
Power button of your TV or Remote pwr button?
Anyway, 1. If TV power button - the culprit is in your power button switch, lose contact - defective. Replace with spare.
2. If you're referring to remote power button - It's a signed of 'COLD SOLDER' joint where galvanic action occur in every electronic terminal leads soldered by LEAD, (terminal lead material is copper & solder material is lead = Corrosion due to galvanic action), at POWER SUPPLY CKT section. How to check a cold solder joint - Remove power PCB to access the soldered components and look for discoloration on terminal lead tip, if you found one try to wiggle the component, say Capacitors, Transistor, Resistor or Transformer it will easily detached from solder.
3. Other technique - Remove back cover of your TV, switch on power button then try to wiggle big component like capacitor, resistor power transistor if cause by cold solder the tv will on & off locate and fix. Please refer to photos. Im having a problem with my Panasonic crt tv model - 25275605-g2bij12ihmeeyzuixp5ga03n-5-0.jpg 25275605-g2bij12ihmeeyzuixp5ga03n-5-2.jpg
Posted on Nov 13, 2014
    Top Expert:
  • Televison & ... Master
  • 74,251 Answers
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Posted on Nov 09, 2014
techman
  • 3130 Answers
SOURCE: TV turns itself off after a few seconds, no picture at all
Sounds like the typical Flyback and shorted horizontal output transistor. Problem is the transformer is NO Longer Available
Posted on Sep 14, 2006
SOURCE: Burnt smell after turned TV off. Now TV never turns on. See no burnt capacitor, resistors, etc.
dude, i believe that your flux capacitor is blown
Posted on Jun 03, 2007
MikeNJ1964
  • 398 Answers
SOURCE: WHY WONT IT COME ON?!?!?!?
If you would like us to help you, you must tell us what brand and model TV you have.
Posted on Aug 29, 2007
  • 1694 Answers
SOURCE: power problem rca 32v434t
RCA 32V434T likely has a bad flyback--#271996. RCA 32F531T flyback no longer available,#262343 Fix one,dispose of other.
Posted on Sep 26, 2007
  • 93 Answers
SOURCE: panasonic tv ct-32hxc14j
try to reheat or resolder your tv.
Posted on Oct 23, 2007
Panasonic remote codes for Comcast / Xfinity SILVER Remote with RED enter button
0289,0288,0285.
Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order. Pull up older posts. Surf the site with patience.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Aug 14, 2014 | Panasonic Televison & Video
I have a panosoinic tv model CT-2013SA and my son typed in a parental code and forgot it
Hello
There is a way to unlock Panasonic TVs. It will work on most of the Panasonic sets. Just try it.
Panasonic sets need to be reset to clear the v-chip settings. To do this, put it in standby mode, that is, switch on the set by its front panel power switch, and put it off by remote hanset, [standby position], then press the POWER and ACTION buttons at the same time and then turn the power off. The set should reset to the factory defaults, and reset the v-chip.
OK.
Feb 12, 2011 | Panasonic CT-20G6 20" TV
How to unblock v chip in panasonic panasonic CT 27SL15 TV
Push the power button and the action button on the tv set until it shuts itself off and this will reset your tv. You cannot use the remote to reset...must use the actual tv buttons on the television set.
Jun 17, 2009 | Televison & Video
Panasonic tv
- push menu
-setup
-ant cable
-sleep 30 min
-ch 124
-vol min with remote
-press vol - in front tv
- aparece chk you see
-with button poweer select
- push pwr & action to exit
jesustolu_9244@hotmail.com
Sep 12, 2008 | Panasonic CT-27SL15 27" TV
Tv lock
PRESS POWER SWITCH AND ACTION FOR 3 SECOND
Aug 26, 2008 | Panasonic CT-36SL13 32" TV
Cant turn off panasonic PIP
To turn off the "stuck" pip on a Panasonic tv without a remote, turn off the tv. Then hold down the "Action" button on the front of the tv and press the power button. This will activate a reset and self check of the systems and voila! The pesky pip screen will be gone! This is on an approximately 10 year old regular crt "CT-xxxxx" series tv.
Jun 12, 2008 | Panasonic CT-36D32 36" TV
How to program a universal remote control for a tv?
One of my problem is how to doneload schematics
Apr 30, 2008 | Televison & Video
Panasonic CT-32SF35 32 On & Off, On & Off
Bad capacitors in the standby power supply most likely.
Jun 09, 2007 | Panasonic CT-32SF35 32" TV
Picture tube doesn't turn off
The power relay driver or the relay itself is bad. Its sticking closed so the voltage is there for the power supply but the micro has turned off the tuner.
Sep 15, 2006 | Panasonic CT-27G23 27" TV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
