Question about Amana ASD2620HRB Side by Side Refrigerator
Humidity-Controlled Crisper Drawers
I have just purchased the Amana Refrigerator and removed the Humidity-Controlled Crisper Drawers for cleaning. Now I am having a lot of trouble putting them back in.
Is there a diagram somewhere that shows me how it goes?
  • 1 more comment
  • Anonymous Mar 16, 2014
    I think I see how to install the catch and bar, but they pop off
  • Anonymous Mar 22, 2014
    The inside of the crispers are dirty and not able to be cleaned thoroughly unless I take the crisper apart. How do I do that?
  • Anonymous Mar 23, 2014
    glass is attached to crispers, how do you remove to clean
  • 290 Answers
If you will post the complete model number including the string of digits starting with P, (if it has these) I will look it up and see what I can find.
You can usually go to sears.com, click on parts, enter the model number from the fridge decal, and pull up a parts diagram of the fridge.
Thanks/mike
Posted on Nov 11, 2007
Refrigerator problems 2-door freezer door stuck will not open
Good Afternoon friend, I appreciate your post!
Based off what you have described the door on your Frigidaire refrigerator is stuck and will not open. It sounds like you may have condensation on your gasket and it has frozen the door shut. The best thing to do is disconnect power from the refrigerator for four to six hours and that should break up any ice holding the door closed. I hope this is helpful information. -Matt
Mar 01, 2015 | Frigidaire FFHT1715L 16.5 cu. ft....
Water collecting in bottom of fridge
Good Afternoon Friend,
I understand that you are receiving water at the bottom of your Frigidaire refrigerator, model# FPUI2188LF. What can cause this is either humidity coming from outside your refrigerator or maybe from the crisper drawers. Make sure your crisper drawers are set for a high humidity. Another thing that can cause moisture build-up at the bottom of your appliance is not covering your foods. Make sure that all foods and drinks are covered to cut down on moisture floating around inside your appliance. Hope this is helpful.
-Best Regards-
WP
May 15, 2014 | Frigidaire Fpui2188lf 21 Cf Top Mount...
Water in Crisper, what causes it?
clean out the drain hole in the back so that the water can drain out side into the container on the compressor
make sure that the door seals are intact
Sep 09, 2017 | Samsung RF217ACWP - 20 cu. ft. French Door...
How to clean crisper drawers humidity control slider?
Hello. Remove the entire drawer and put it in a large plastic bag. Add two cups of ammonia and close the bag up tight with a twist tie. Leave the bag in a sink or a tub or out doors in case it leaks. The next day remove the drawer, rinse it thoroughly to remove the ammonia smell and the slider will be as clean as it is going to get. Regards, Joe
PS - kindly rate my answer as helpful. Thank you.
Feb 12, 2010 | Refrigerators
Salad in drawer is freezing
Good day,
One user claims that the return air vents or vent located at the bottom rear of the fresh food compartment, have collected enough junk to block the cold air from returning to the freezer compartment. You can clean them out but I cannot verify that solution.
The crispers are located in the coldest part of the fresh food compartment.
This problem can occur when the machine gets light usage especially in colder weather, when the machine running time drops and the air in the fresh food stratifies, causing to cold air to pool in the bottom.
Normal may no longer be normal. Controls by their design will tend to run colder as they age. You might try tweaking the control warmer.
Patience and time are the most important tool you have to work with in dealing with this issue.
Dec 04, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
Water collects under crisper drawers
Does it have darin at the bottom to drain out the bottom of the frifge into the drip pan? if it does push a wire threw the hole with the unit unplugged.
Aug 28, 2009 | Refrigerators
Kenmore bottom freezer model freezes veggies in the crisper
i never go by that / just hold my finger over the air port and move it till i feel move air or less to set it the way i need it ,,, less air puts less air into crisper to cut down on freezing
Nov 26, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Refrigerators Logo
282 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
