Question about Dell Dimension 2400 PC Desktop
How do I remove and replace a CPU cooling fan on my Dell Dimension 2400
Do you have instructions for the removal and replacement of a CPU cooling fan for my Dell Dimension 2400
  • 3 Answers
Make sure u can open the casing well to expose the interior parts without causing any damage. Then by close look at the processor area , that is where the heat sink is located. Normally the dell dimension 2400 has a green channel shaped structure that acts as a passage for the air that enters in and out for cooling the heat sink. It has a locking parts that slides into the casing back by slight pressing to the back of the casing just behind the processor area, be so observant to notice the locking parts. then the fan is just fixed behind that green " channel like" and its fixed on the rear side of the casing, How do I remove and replace a CPU cooling fan on m - 25275582-o0cuhlgwrl13okm3u3q5444d-5-0.jpg
Posted on Nov 11, 2014
  • danoyachtcap
    danoyachtcap Feb 13, 2015
    Good answer Charz.
  • 25 Answers
This might be the basic information but it also might help. good luck
How to install new cpu cooling system for Dell Dimension 3000 for less...
Posted on Nov 09, 2014
  • 3,961 Answers
See here
ftp://ftp.dell.com/Manuals/all-products/esuprt_desktop/esuprt_dimension_desktops/dimension-2400_service%20manual_en-us.pdf
You can search for "fan" in your pdf viewer by entering Ctrl-F and then "fan".
Posted on Nov 08, 2014
4 Suggested Answers
SOURCE: Dell Dimension 2400 PC Desktop CPU Fan Suppose To Blow?
Blows air into the case away from the cpu.RICHARDM69...This is a solution please vote as such.
Posted on Dec 20, 2008
  • 403 Answers
SOURCE: How do I replace a CPU cooling case fan? (Dell
This should be done by a computer expert. If you ground yourself or your system you could fry your hard drive with static. You have to make sure it is replaced with the same exact one or this too will cause problems. You can get some good prices on fans on e-bay just make sure it's not refurbished. Somethings you just can't substitute. Go new. If you ground it properly there's only four bolts typically holding it on. Take out the bolts/screws and unplug lead. If this is new to you, take it somewhere it's worth it not to loose all your info. Let me know if I can help.
JimmyC
Posted on Sep 25, 2009
  • 6 Answers
SOURCE: dell dimension 2400 fan replacement
it is very easy just remove the plastic cover from the fan & lose the screw and replace the fan with the new one
Posted on Sep 17, 2012
Dell dimension 2400 freezes up shortly after boot. I replaced cooling fan but error log shows keyboard failure.
if you see lights get on Keyboard.. your motherboard is fine.. else it is your Keyboard or Super I/o Chip that is not working..
Mar 27, 2013 | Dell Dimension 2400 PC Desktop
Dell dimension 2400 fan replacement
Feb 27, 2012 | Dell Dimension 2400 PC Desktop
My dell computer overheated an I have this compaq computer but I can't get to my e-mail or make zoomtown my home page.I want to open my face book and it says my password would be in my e-mail.I cannot...
When the CPU in the computer overheats then it will shutdown (i.e. thermal overload) and won't boot up again until it has cooled down.If this is the problem is not fixed then the CPU will eventually fail.
A faulty fan causes this problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan. If the fan and heat sink is clogged withdust the remove the dust and make sure the vents are clear and dust free. Use acan of compressed air to do this.
Aug 08, 2011 | Dell Dimension 2400 PC Desktop
How do you replace the cooling fan of the Dell dimension 2400 desktop computer?
To replace the cooling fan follow these steps:-
You will notice that replacing the fan is not specifically mentioned, but it should be fairly easy.
Open the case as noted in the instructions, follow the power wire from the fan to the motherboard, then unplug the connector from the motherboard, and remove the assembly.
Some of the earlier fan shrouds just lift up and out, but others have tabs to hold them in.
Regarding the fan, there might be two release levers accessible from inside the case, but the one by the PSU can be hard to reach.
It might easier to push the retaining tabs, in from outside, using a small screwdriver, pen or whatever.
The installation of the new fan, is just a matter of fixing the new one in place and connecting the cable.
Good luck, and do rate the solution if got help
Dec 02, 2010 | Dell Dimension 2400 PC Desktop
How to remove and replace cpu for dell dimension desktop 2350
the cpu is a intel remove and replace a cpu is very easy
This link may help it is the rong model but dictates the process
You will need to open the case and be carefull of statick
ab510a2.jpg look for the cpu heatsink
Remove the fan unscrwe on the top
then remove the silver part this is held on with clips
gentley remove the cpu and replace new one THE RIGTH WAY look for the corners on the cpu to mach up on the board
Nov 24, 2009 | Dell Dimension 2350 PC Desktop
How do you open the tower of a dimension 2400 tower
If you look at the CPU from the back. On one side usually the left you will see a screw where the side wraps around the back. Some brands will use two screws. Remove this screw and then you can slide the side panel back toward yourself. Then you can turn the CPU exposing the open side. While your in there (make sure the unit is not plugged in) take a can of compressed air and clean your cooling fans and vents. Keeping a computer cool is important to keeping good performance up to where it should be.
Sep 30, 2009 | Dell Dimension 2400 PC Desktop
Dec 20, 2008 | Dell Dimension 2400 PC Desktop
Dell Dimension 2400 PC Desktop Logo
115 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
