What means code 17 on inverter ch43bx018-h3h1c
The unit does not work
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 18 Answers
Not knowing for sure what mod this is I think you are referring to a carrier unit sounds like circuit malfunction so the board If it was working before try to power down wait then power up again >>
Posted on Nov 09, 2014
Sankey inverter 12000 split unit give error code PO what does this mean
PO code means power went off unplug unit to try and reset , also check for power to unit .
Oct 03, 2014 | Heating & Cooling
What is the error code E5 on bluestar air conditioners mean
Problem
Overheat of inverter compressor motor
Cause
Shortage of refrigerant amount Leakage of four way valve
Defect of connector contact
Aug 14, 2014 | Heating & Cooling
What does error code 461 means on a samsung ?rc140dhxga hide away unit
Hi Jaco,
to trouble shoot this problem,you need to make some eliminations:
1.Check the standing pressure of the refrigerant (gas).If it is low that could cause the compressor to over heat and eventually fail.
2.The compressor could be drawing more current from the inverter causing it to trip.
3.The inverter card could be faulty.Try to run the unit with a similar card from a similar unit before your consider buying a new card.
4.The start capacitor/run could be fault causing the compressor draining a lot of current from the inverter.Inspect the capacitor for visible electrolyte leakage or bulging casing.Try one from working unit.
Regards,
nyauadamson@gmail.com
May 03, 2014 | Samsung Heating & Cooling
What does malfunction code E6 mean in a koppel super inverter airconditioner
WHAT IS THE MEANING OF E4 code in koppel inverter split type
May 01, 2012 | Heating & Cooling
Screen is dark not ani light not working
The problem as described suggests a problem with the "inverter" circuit of the monitor. This can be as simple as a bad capacitor in the power supply that feeds the inverter or a problem within the circuit itself. I have repaired a number of these where there was a shorted driver transistor with a cost of $2 for the part. I would check in your area for a service shop that will check it for you. Even with a $50 labor charge, the repair will be less than a replacement unit.
Dan
Apr 21, 2010 | Acer AL1721 17" Flat Panel LCD Monitor
A friend gave me the Kogi 17 eh-ta ko 17 in Flat panel LCD monitor. We got it installed and the screen has a pinkish tinge to it. Don't have the manual and would like to find out where the tint control is....
communikay, The pink tint means that the cold-cathode-fluorescent-lamps are just about at their "end of life" and will need replacing!! I would be surprised if it lasts another month or two and then you might need to rebuild the inverter circuit that also might die from being overstressed due to the fact that old (many "ON" hours) CCFL's draw excessive current making the switch-mode-power-supply/inverter circuit work harder to light the lamps? 12fixlouie
Apr 03, 2010 | Kogi l7eh-ta ko 17" Flat Panel LCD Monitor
No picture only sound. Was working in the past
Ur LCD inverter board have problems before,now the board it dead.U must replaced the LCD inverter board to repair this to get picture back.The board is long in shape.Tries Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter board for the replacement.
Mar 31, 2010 | Dell W1700 17 in. HD-Ready LCD Television
MY SONY SDM-HS74P
You open the inverter unit and check any dry soldering is there. Some times dry joints inside the inverter unit cause this type of problems.
Apr 06, 2008 | Sony SDM-HS74P/S 17" LCD Monitor
Sony LCD HS73 LCD goes blank 2sec.
defective backlight inverter unit. Replace the inverter unit or chek if there is any dry joints inside the unit.
Apr 02, 2008 | Sony SDM-HS73P 17" LCD Monitor
Heating & Cooling Logo
51 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
