Question about Stoves Ovens
How do I find out whether my cooktop is an electrolux EC350U or a ECH640U
Alarm saying racks are in is wrong, since racks are out. Won't allow me to lock for cleaning.
There must be some sort of spring loaded catch at the side or back that registers whether the rack is in or out. Yours will be stuck shut with debris, which is presumably why you are cleaning the oven :>)
Dec 02, 2015 | Electrolux Ovens
How do you remove the cooling fan on an Electrolux EW30ES65. Basically how do you remove the flat top.
Good Morning Scott Robert, thanks for your post!
Based off the information you have provided you would like to remove the flat top from your Electrolux range. Regrettably this is not a simple DIY job. I would recommend having a professional technician out to disassemble the cooktop and install any new electrical component. This will help to avoid any future issues or personal injuries. Good luck. -Matt
Dec 21, 2014 | Electrolux Ovens
Error F68, beeping continuously
Hello Rasheda, this is Z. Thank you for your post!
If you are getting an error code F68 on your Electrolux oven, it typically means that your appliance may be experiencing an issue with the incoming line voltage. One of the best ways to determine if this is a false error code is to rest the power to your oven by either unplugging it or flipping off the breaker for about ten minutes. If the error code persists, it would be advisable to contact an experienced appliance repair tech since this is not a simple DIY job. He/she would need to determine whether the problem rests with the power supply voltage or EOC (Electronic Oven Control). I hope this helps explain the error code you are receiving.
Apr 10, 2014 | Electrolux Ovens
Is electrolux oven better than lg
What features and size are you looking for? Electrolux is most popular for its cooking product line and they are one of the most efficient and highest ranked manufacturer's in the kitchen. Are you looking for a specific design? Electrolux is more European where LG is trying to make their designs reflect high tech computer designs.
Aug 15, 2012 | Electrolux Ovens
The electronic ignition on my chef cooktop no longer works. Can I fix it myself?
Here is a tip that I wrote to give details about why your cooktop will notspark to light the burners..
Cooktop Range Stove spark ignition does not work
heatman101
Apr 27, 2011 | Ovens
Electrolux oven eog7330xn stopped working
Hi Chaps,
I have an 18 month old Electrolux Gas oven model No: EOG7330XN which worked for 14 days then died. There was no power displaying and I called Electrolux to service within the warranty period. The engineer removed the front control panel and replaced a fuse inside which brought it back to life.
Am I right this is possible, I have removed the panel but can't see any fuses?
Jul 30, 2009 | Electrolux Ovens
Electrolux EOB5600 electrical fault?
goto home depot,lowes and get some ceramic wire nuts and heat tape and electrical tape.cut the wires back on both sides of the terminal block.bypass the t-block and connect the wires with the wire nuts wrap the heat tape then electrical tape on each one.if you have access to a amp meter take readings to make sure the amp draw isnt too high.i would think the wires just burned up from either a loose connection or the heat of the oven.this should solve your problem.
Jan 06, 2008 | Electrolux EOB5600 Ultrafan Electric...
Open Questions:
Faulty obsolete (20yr old) oven thermostat with separate fan/light switch. Can't find a 'universal' replacement. If I fit a standard 2 tab thermostat, the fan and light will switch with the element Stoves oven DF550 SI with a 46thc502/G5 thermostat which controls well (if 40C higher relative to the oven thermometer). However after an overnight cool down the oven element switches on when the mains is turned back on, even though the oven control is off. I just twiddle the oven thermostat control slightly and all is well. I can't find a 250C, 1m phile, 24mmx6mm spindle thermostat with a separate connection tab for the internal recirculating fan and oven light anywhere. Otherwise the single oven cooker works and looks like new (nearly). I was wondering whether I have to piggy back a switch on the back of a standard 2 tab thermostat (or vica versa) or attach a separate switch to the oven. Can't believe I'm the only one with this problem. I'm guessing some fragile electrical contact occurs in the thermostat on cooldown to turn on the element and its in-series lamp, and this contact easily breaks by slightly turning the thermostat. ps there is no timer and I do have the circuit diagram. I found a working solution to this problem: When turning off the oven, I don't take it to the end stop. I turn it passed the click when the element and indicator turn off, then further till the ligth and fan turn off and just a fraction further but not to the end stop. Now the oven element doesnt turn on each time I turn the mains on for some other reason ( eg grill or igniters). I guess there is something wrong inside the thermostat, but this work arround seems OK if not ideal. I've marked a new stop position around the oven dial to remind me. This was easier than making a physical stop for the oven dial.
Feb 24, 2018 | Stoves Ovens
Ovens Logo
53 people viewed this question
Top Stoves Ovens Experts
ashburton
Dan Webster
Dan Webster
Are you a Stoves Oven Expert? Answer questions, earn points and help others
