Question about Hardware & Accessories
Inter attic residential in wall timer how to reset on off
How to reset on off times
  • 5,089 Answers
How long should it take for me to replace an in-attic water heater?
Circumstances differ. Could be anywhere from 2 hours to 6. KNowing what you are doing is half the battle. Pictures would be helpful.
How to Install Water Heater Step by step
Feb 20, 2015 | Audiovox Richmond 6EM30-2 30-Gallon 6-Year...
How to reset the time pointer accidentally unscrewed from an Inter-matic T101 timer?
T101 Timer has silver pointer that is stationary, and points straight downward.
Copy following link for step-by-step instructions setting T100 series, and links to wiring and replacement part identification:
http://waterheatertimer.org/pdf/How-to-operate-and-set-T104-timer.pdf
Nov 04, 2012 | Hardware & Accessories
Bleep in wall no product involved
Check attic for smoke detector or alarm system with low battery.
Oct 08, 2012 | Intermatic Inc. ST01C Digital In-Wall...
What is the intermatic e 1020 used for just moved into a house andits in the bathroom and makes a lot of noise.
The E1020 timer is reliable heavy-duty 24-hour on-off analog timer with replaceable trippers and manual override, rated 12 amps.
This timer replaces ordinary single-pole on-off switch.
Timer has extra white wire that connects to white neutral wires inside box to run timer mechanism, while mechanical single-pole switch does not need this wire.
I don't know what it is doing... maybe running the vent fan periodically, or turning on attic vent fan?
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#E1020
http://waterheatertimer.org/How-to-set-timers.html
For same timer, with less noise, install E1100-1200 aka the KM series in-wall analog timer. Or install digital in-wall timer, or replace timer with on-off switch.
Aug 11, 2012 | Intermatic Timer E1020, Single pole/single...
How do you set the time to go on and off
http://www.1000bulbs.com/pdf/Inter-ST01C-Operating.pdf
Here is a link to the manual for this device. It is going to give you a more clear and thorough explanation than I could by paraphrasing.
Oct 02, 2011 | Intermatic Inc. ST01C Digital In-Wall...
I do not have an instruction manual for the Intermatic E1400WC timer switch and I can't figure out how to program the on/off times.
Intermatic makes heavy duty Ei400 series 1HP 120V or 240V countdown timer that can be wired for single-pole and 3-way.
Open following link to identify Ei400 timer and download manual:
http://waterheatertimer.org/Countdown-timer-horsepower-ratings.html#Ei
Coundownt timers are used to control fans and lights that need to run certain length of time, and then turn off. For example bathroom fan or whole house attic fan
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 28, 2011 | Solar Intermatic Digital Wall Self...
OLD wall timer Model E1020 ticks really loud
You probably can't get the existing mechanical timer to operate any quietier, since it's old and likely starting to wear out. You can either swap the timer out for a new automatic digital timer, or install a standard single pole switch in its' place.
I believe the code you refer to regarding the fan having to be wired onto a timer switch was a local requirement from many years ago.
Some local jurisdictions have impossed more stringent requirements, but frankly, having an exhaust fan is normally a good idea. If the fan is vented into the attic space, it can cause some serious problems in cold weather with condesation of the warm, moist exhaust air.
Building Code requires that bath fans be piped/vented to the outside of the house and not into the attic space.
There are newer preset timer switches that will turn on the exhaust fan for a fixed amount of time, based on which button you push. These are great as they will run the fan long enough to remove condensation from showers, etc.
If you're going to replace the timer, disconnect or turn off the breaker or power to the switch. Then simply install a new timer or switch by connecting the black supply wire to the bottom of the single pole switch, or to one of the black leads of the timer. Then connect the black wire going to the fan to the top screw on the single pole switch, or the other lead on the new timer. The white (neutral) wires should already be connected with a wire nut inside the box. Connect the ground wire to the ground wire in the box and if the switch box is metal, attach the ground wire to the box with a green grounding screw too.
You can now operate the fan with either a manual on/off switch or the new digital timer, whichever you chose to install.
Sep 04, 2009 | Heavy Duty Intermatic Wall Switch Timer...
Carrier Infiniti system, system maufunction on primary display
Call a Carrier service comapny and have them investigate further, when system malfunction comes up on the user interface usually there is a substantial problem.
Either that or the User Interface has gone bad and needs to be replaced
May 14, 2009 | Carrier Heating & Cooling
Audio buzz
Check to see if reversing the plug takes away the buzz. Some times turning the plug over in the wall socket i.e. reversing polarity, will remove the buzz.
Dec 09, 2008 | Philips HTS3400/37B System
Hardware & Accessories Logo
75 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
