Question about Home
When I press Start, the thermometer is not work
How do I change my Braun ear thermometer back to F from C
You did not provide a model number however the Instruction Manuals for the various Braun Thermometers can be found here:
http://braun.kaz.com/kaz/service/prodResult/
Not sure if this procedure is common to all but this may work otherwise find the manual specific to your model number.
Changing the temperature scale
This thermometer is shipped with the Celsius temperature scale activated. If you wish to switch to Fahrenheit ( °F), proceed as follows:
Turn on the thermometer. ( If it is already turned on, make sure it is not in memory mode.)
Press the /mem button and keep it pressed. Then press and release the activation button to switch over to the «change temperature scale» mode.
By pressing the activation button again, the Fahrenheit scale is activated, «°F» is displayed on the LCD. Each further pressing of the activation button toggles the scale between °C and °F.
Release the /mem button to return to the ready symbol . The temperature stored in memory will automatically be converted to the selected scale when displayed on the LCD.
Apr 24, 2011 | Braun Thermoscan Pro 4000 Ear Thermometer
We have the Braun 6022 thermometer. It is reading in C so temps are coming up (ex. 37.1 C) how do we get it back to F
If you whish to switch from Celsius to Fahrenheit, proceed as follows:
(1) Make sure the thermometer is turned off.
(2) Press and hold down the Start button (IRT 4020)
or the «I/O» button (IRT 4520). After about
3 seconds the display will show this sequence:
«°F» / «SET» / «°C» / «SET» ...
(3) Release the Start button / «I/O» button when the
desired temperature scale is shown. There will be
a short beep to confirm the new setting, then the
thermometer is turned off automatically.
Mar 04, 2011 | Braun Thermoscan Pro 4000 Ear Thermometer
Need to convert C to F
Changing the temperature scale Your Braun ThermoScan is shipped with the Fahrenheit (°F) temperature scale activated. If you whish to switch to Celsius (°C) and/or back from Celsius to Fahrenheit, proceed as follows: (1) Make sure the thermometer is turned off. (2) Press and hold down the Start button (IRT 4020) or the «I/O» button (IRT 4520). After about 3 seconds the display will show this sequence: «°F» / «SET» / «°C» / «SET» ... (3) Release the Start button / «I/O» button when the desired temperature scale is shown. There will be a short beep to confirm the new setting, then the thermometer is turned off automatically.
Feb 16, 2011 | Braun IRT3020 Thermoscan Ear Thermometer
How fo I change the degrees from C to F degree ?
Feb 10, 2011 | Braun IRT3020 Thermoscan Ear Thermometer
I have the instant ear thermometer model number 524972 and it is stuck in celcius, how do I get it back to Fehrenheit
When the unit is off, press and hold the blue start button at the top of the unit. Then while still holding the start button, press and hold the ON/Memory button (you should now have both buttons pressed). The display will power on and you will see the setting toggle from celcius to fahrenheit. Repeat the entire process in order to toggle the setting back to celcius.
Oct 31, 2010 | Becton Dickinson BD Instant Ear...
How do i set the thermo sensor 433mhz to my westclox 70034 model
Hi, First check the both channel of clock and thermometer (you can see the controler in battery insertion of thermometer and you can set up channel by pressing ch button on the clock)
Next press F/C search button until the clock find thermometer and press F/C search button again.
Oct 11, 2010 | Vacuums
How can I change the Walgreen's Instant Ear Thermoter from Celcius to Farenhiet? Itw was on F and in my purse it beeped and then was on C
On the Walgreens instant ear thermometer. While the thermometer is OFF press and hold for 5 seconds the START button, it will show the ---C on the display, now press and release the start button one time and it will show ---F. Let the display turn off and it should be on fahrenheit when you turn the thermometer back on. Hope this helps!!!! Guy
Sep 12, 2010 | Walgreens Health & Beauty
My the first years ear thermometer is showing in celcius rather than fahrenheit
While the thermometer is OFF press and hold for 5 seconds the START button, it will show the ---C on the display, now press and release the start button one time and it will show ---F. Let the display turn off and it should be on fahrenheit when you turn the thermometer back on. Hope this helps some people out.
Oct 30, 2009 | First Years Toys
GE Digital Wireless Thermometer
Wireless Digital Thermometer GE5805WS4
Instruction Manual
Buttons and Functions
Button Function
Front of unit:
Min/Max...........displays Min or Max temps recorded
CH(Channel)......changes displayed channel
(hold 3 sec to erase)
Clear................clears memory in Min/max display
Back of unit:
C/F....................Toggle between Celsius
or Fahrenheit temperature display
Scroll.................Remote Channel Scrolling ON/OFF
INSTALLING BATTERIES
IMPORTANT:Read the section SETTING UP THE THERMOMETER before installing the batteries for the first time.
1.Remove the rear cover of thermometer. Install 2 new AA batteries. Replace battery cover.
2.Loosen 4 screws on rear battery cover of the Remote Sensor and slide battery cover off.
3.Install 2 new AA batteries .
4.After batteries are installed, the remote sensor will begin transmitting and automatically register to the Thermometer
(within range) after several minutes. However, you can also press the small button in the battery compartment (labeled Tx) to register the Remote Sensor to the Thermometer immediately
5.Replace battery cover and tighten 4 battery screws. Make ure that the battery cover is fully on and tightened to assure a watertight seal.
The thermometer can monitor up to two different Remote Sensors on two separate channels. Add-on remote sensors can be purchased separately and are compatible with the GE Wireless Thermometer/Clock (model GE5805WS4) as well as this unit. When first installing, always insert batteries into the Thermometer first, then into the Remote Sensor.
The thermometer uses random security code technology-it will learn the random code of the first Remote Sensor it detects and log in as channel 1. Channel 2 will register in the same way. NOTE: Registered channels will be erased when the batteries of the Thermometer or Remote Sensor are removed. When replacing batteries for a Remote Sensor, remember to clear the corresponding channel of the Thermometer in this way:
1.Remove batteries from the remote sensor (step 2 of installing batterie)
2.Select the channel that you would like to clear by pressing the CH button on the Thermometer until this channel number is displayed.
3.Hold the CH button for 3 seconds to clear the channel
4.Follow steps 3-5
MOUNTING THE REMOTE SENSOR AND THERMOMETER
Remote Sensor is suitable for outdoor mounting (watertight) at a range up to 100 feet from the Thermometer. HOWEVER, HE UNIT SHOULD NOT BE MOUNTED IN A POSITiON WHERE IT WILL BE SUBMERSED IN WATER, OR EXPOSED TO DIRECT SUNLIGHT, OR NEAR OTHER SOURCES OF HEAT OR COLD (I won't bother typing the rest) except for:
LOW Battery icon for the sensor will show up on either the
ch 1 or ch 2 display depending on which sensor is losing battery power.
Battery life 6 months
Temp Range Therm 32 to 122 deg F
Remote Sensor -58 to 158 deg F *
*Alkaline batteries can freeze temporarily at temps below -4 deg F. In this condition, the Remote Sensor cannot accurately transmit temp info to the Thermometer. This limits the effective minimum temp fo the Remote Sensor to -4 deg F
Operational Range....>50ft(and up to 100ft)(less interferances)
RF Channel ....refresh to "---" if no signal received in 60 minutes
Jan 06, 2008 | Heating & Cooling
Home Logo
129 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
