<!-- from fixya rte -->How do i reset fantec mm-fhdl? - Audio Players & Recorders
Mm#6 error on samsung galaxy s3
Does it come up at all? Have you tried to factory reset it?
Feb 08, 2013 | Samsung Galaxy SIII S3 SGH-I747 White ATT...
Where is the reset switch of nikon d40 camera ?, how to reset camera?
There're actually two buttons. Press and hold the Info and zoom-in buttons (both marked with a green dot) for more than two seconds.
Full details are in the "Two-Button Reset" section of the manual (page 38 in my copy). If you need a manual you may download a copy from here.
Jan 08, 2013 | Nikon D60 + AF-S DX VR NIKKOR 18-55 mm...
My LG KS360 phone has developed a date fault since 1 Jan 2011 whereby it is saying 32/83/2010. I cannot fix it. Please advise.
Noticed the same problem today. The "set date" option wouldn't let me reset the day, month or year to anything sensible. Changed the date format to MM/DD/YYYY (it was previously DD/MM/YYYY). Then it let me set correct month, day and year. Reset the date format back to DD/MM/YYYY and it's still correct (and will now let me change it while in this format). Don't understand it, but seems to have fixed the problem. (Guessing it was something to do with 2009 changing to 2010??). worked for 2011 also.
Jan 02, 2011 | Cell Phones
I have a Western Digital WD20EADS 2TB hard disk, within a fantec MR-35US2 disk case, connected with a USB to my computer. The problem is the disk is performing to slow.
sometimes when a hard drive is performing to slow it is because there isn't enough Random Access Memory (RAM) in your tower or laptop all you have to do is upgrade the RAM to 1GB - 3GB is will ensure the hard drives performance will increase
details of what RAM looks like
http://www.google.co.uk/images?hl=en&q=random+access+memory&rlz=1R2ADFA_enGB408&wrapid=tlif12927122991681&um=1&ie=UTF-8&source=og&sa=N&tab=wi&biw=1072&bih=587
Dec 18, 2010 | Western Digital WD20EADS 2 TB SATA Hard...
Lost instructions to a squire shcb75 75 mm combo
have accidently locked my squire open! cananyone remember how to reset?
Feb 26, 2010 | Locks & Locksmithing
Date & time.
To reset system time you must be at the attendant station and with the handset cradled:
Dial: #06 4321 1 # (4321 is the default password)
Then:#55 YY, MM, DD, W, HH, MM, # time will be saved and phone will go back to normal operation.
Naming convention:
YY - Last two digits of the year
MM - Month (1-12)
DD - Day of month (1-31)
W - Day of Week (monday = 1.... sunday = 7)
HH - Hour (24hr format)
MM - Minutes (00-59)
ex: To set the time For Monday, Jan. 5, 2009 at 8:31pm I would enter: 09 01 05 1 20 31 #
Good Luck,
BB
Dec 02, 2008 | Samsung Prostar 816 Phone
Continuous paper jam when i try to print
Hi ,
Follow the steps below -
1. check the media / paper compatibility. It sould be as per hp :
Paper tray capacity Type Weight Capacity Input tray Capacity Output tray Plain paper 60 to 90 gsm (16 to 24 lb) 150 50 (20 lb paper) Legal paper 75 to 90 gsm (20 to 24 lb) 150 50 (20 lb paper) Cards 200 gsm (110 lb index max 30 30 Envelopes 75 to 90 gsm (20 to 24 lb) 20 10 Transparency film N/A 25 25 or fewer Labels N/A 30 30 4 x 6 inch (10 x 279 mm) Photo paper 236 gsm (145 lb) 30 30 8.5 x 11 inch (216 x 279 mm) Photo paper N/A 20 20 Paper sizes Type Size Paper Letter: 216 x 279 mm (8.5 x 11 inches)
Legal: 216 x 356 mm (8.5 x 14 inches)
A4: 210 x 297 mm
A5 148 x 210 mm
Executive: 184.2 x 266.7 mm (7.25 x 10.5 inches) Envelopes U.S. 10: 105 x 241 mm (4.125 x 9.5 inches)
A2: 111 x 146 mm (4.4 x 5.8 inches)
DL: 110 x 220 mm (4.3 x 8.7 inches)
C6: 114 x 162 mm (4.5 x 6.4 inches) Transparency films Letter: 216 x 279 mm (8.5 x 11 inches)
A4: 210 x 297 mm Photo 102 x 279 mm (4 x 6 inches)
127 x 178 mm (5 by 7 inches)
Letter: 216 x279 mm (8.5 by 11 inches)
A4: 210 x 297 mm (8.27 by 11.7 inches) Labels Letter: 216 x 279 mm (8.5 x 11 inches)
A4: 210 x 297 mm Custom 76 x 127 mm up to 216 x 356 mm (3 x 5 inches up to 8.5 x 14 inches) Print margin specifications Paper size Top Bottom US Letter
US Legal 1.8 mm (0.07 inch) 3 mm (0.12 inch) ISO A4
ISO A5
JIS B5 1.8 mm (0.07 inch) 6.0 mm (0.2 inch) Envelopes 1.8 mm (0.07 inches) 14.3 mm (0.5 inches) Cards 1.8 mm (0.07 inch) 6.7 mm (0.3 inches) 2. paper should be placed to the right of the tray and a little inside with a min distance within the papers of .1 mm
3. open the rear access door of the printer (with grids) on the back and reval the rollers. Take a slight moist cloth ( not cotton ) and clean the rollers with it by moving them 4 times upwards.
4.open the cartridge door ad observe the thin plastic strio on top of the steel rod on which the carriage moves. Take a small piece of paper and hold the strip with it ands swipe it once witout applying much pressure as it could come out in any direction and as much as you can
5. make sure you replace the cartridge if its refilled. It could provide obstruction.
move the carriage 4-5 times continuously with as much speed and make sure there is no obstruction in the carriage movement.
6. press set up button on the printer panel - go to print reports - ok / enter - self test report - see if the paper jams. If not good.. If yes take a look into the next step.
7. pull out the power cable directly from the printer. Press and hold # and 6 button on the printer and insert the power cable and do not release the buttons till you see te display glowing blank or some processing happening. Release the #6. If the printer turns off then press on the power button to turn it on. Continue with country and language settins as apprpriate. Choose your country during this reset. Complete the alignmet then. Take a printout to see if the paper jams again.If yes - the printer definitely needs servicing.
Apr 08, 2008 | HP Officejet 7210 All-In-One InkJet...
To unlock code no. of sanyo mm-8300
call *2 - sometimes the rep will help you over the phone and other times they will tell you to take it in to the store to have it reset.
Mar 14, 2008 | Sanyo MM-8300
 Grubhead
Grubhead
