Question about Furniture
I have a nice Tv tray make out of wood. The legs dont hold up. Is there some kind of hardware I can use to make them sturdy. That they can stand up. and fold easily.
Its a folded Lap tray also called a Tv Tray made out of wood.Legs fold but it wont stay up..
There's always a way to do something, but can't answer your question without seeing what the tray and legs look like.
Posted on Nov 09, 2014
Can you tell me what size screws I need to mount my Toshiba Model 46G310U on a wall?
M6 or M8
http://support.toshiba.com/support/search?s_query=mounting+bolts
User Manual
Page 6
... stand. 3) Once you have removed all four screws holding the pedestal stand in place, remove the pedestal stand ..., level, stable surface that can support the weight of the surface. Four screws Hook Sturdy strap (as short as possible) 46 / 55" TV VESA Mounting Pattern 32" TV VESA Mounting Pattern Four screws Hook Sturdy strap (as short as possible) Four screws Hook Sturdy strap (as short as a quilt or blanket. Make ...) 200x200 mm 200x200 mm 400x200 mm 400x200 mm Screw Size M6 M6 M8 M8 (unit in mm) 40" TV VESA Mounting Pattern Removing the Pedestal Stand 1) Carefully lay the front ...
Toshiba 46G310U Mounting Screws
Sep 24, 2017 | Televison & Video
Tip
All purpose presentation easel a DIY project
You never know when you are going to need or want an easel to show off your art work, maybe your kids want to finger paint who knows they could be the next Van Gogh. Building a display easel is very simple and can be done in just a few hours.
You want to start with two pieces of wood cut to 2x82" these pieces will form the front legs of the easel. Using a table saw cut the tops of the wood to a 15* angle. Take a measuring tape and measure 78" from the bottom of the wood (up to the angle cut) mark this spot on both pieces.
Using a drill, drill a 3/8" hole through the widest side of the angle as a right angle to the cut. Repeat for the second front leg.
To make the back leg cut a piece of wood down to 2x81" long, using your drill, drill two 3/8" holes in the widest side of the wood. One hole should be 39" from the bottom of the wood and the second at 74" from the bottom.
Your art work needs something to sit on so to make the cross bar cut a piece of wood down to 2x47".
Now you are ready to assemble your easel. Take the front and back legs and lay them on the floor next to each other with the back leg in the middle. Rotate the front legs to the angle is facing the back leg and line up the holes. Slide a bolt into the hole and place a washer and a nut on the end, keeping it loose enough to adjust the angle. Stand up the easel and spread the from legs so that they are 45" away from the back leg. Tighten the bolt and you have the angle right and lay it back down.
To attach the cross bar, measure 38" up from the bottoms of the front legs find the center and drill a 3/8" hole in each and bolt the cross bar to the legs. To keep the legs from spreading too far you can attach a chain between the cross bar and the back leg. To do this you thread the chain through the hole in the back leg and tie it off. Attach an eye screw to the cross bar and loop the chain through it to keep limit how far the legs can spread to the angle that you want to work or display at.
on Jan 29, 2014 | Office Equipment & Supplies
Hi there i need a replacement stand /base for a hisense 32" tv model number LHD32E130TUK
Please contact the TV manufacturer for this type of part. Fixya sells not parts of any kind.
Oct 14, 2016 | Hisense LHDN32V66AUS 32 in. LCD TV
TV Stand Screws
If you still have the manual or know the manufacturer you might want to try giving them a call. They'll know what size screw was used on that model tv stand. Otherwise, measure the insides of the holes and go to a hardware store; they should be able to help you find the right one. Just make sure they are not too long. Screws are pretty cheap, so I'd suggest buying one of a couple different sizes to try out. They should fit snugly in the hole, but should not split the wood/plastic. You'll want to get four of the same size washers and nuts as well once you know what kind of screw you need. That way they won't loosen. :)
May 18, 2012 | Emerson LC320EMXF 32 in. LCD TV
My Acer 21.5'' wide screen monitor shakes when I
Get a better stand to hold the monitor. There is nothing wrong with the monitor, it's the operator.
Jun 24, 2011 | Acer Computers & Internet
Need to mount Sony KV-36XBR400 on a TV Stand. Unit weighs in at 236lbs. Sony discontinued the stand for this unit. Are there any stnds currently made that willsupport tis kind of weight? F....
There are industrial-duty parts carts and tables that will work, but I don't think you care to have gray-metal furniture in your TV viewing room. Check the local furniture stores to see if they have anything rated for this much load.
If not, perhaps you can get a cabinet maker to build a cabinet on 3" or 4" casters designed to hold at least 300 lbs (so you can keep other stuff in the cabinet). This will make the set much easier to manage if you ever want to move it. The casters can be hidden by a wood trim skirt. Ask for at least one metal angle brace under the top so the wood doesn't warp under the load.
Oct 24, 2010 | Sony KV-36XBR400 36" TV
I need thd legs for the tv
Did you ever find the legs/table stand for this TV? I'm looking for the same.
Nov 29, 2009 | Zenith P42W34P 42 in. EDTV-Ready Plasma...
What do you advise I put under my washer and dryer? I need to slide them out service but I don't want the leveling legs to scratch the tile floor which is limestone and scratches easily.
I put a piece of 1/4" plywood in front of the legs, stand on the plywood and lift the front legs onto the wood. Slide the machine forward until the back legs hit the wood and tip it up on the back and on to the wood. Cart it away from there if that is necessary.
Sep 15, 2009 | Fisher and Paykel GWL11 Top Load Washer
LG 42 in TV Table Stand does not seem to be very sturdy
Yes! these TVs are very top heavy and it is normal! as far as your stand it should not wobble too much but it should be ok!9If you have dogs or kids you might want to invest in a sturdy stand! for safty sake!
please rate this response and help keep this area free!
Jan 22, 2009 | LG 42LC2D 42 in. LCD HDTV
Walking Washer
due to weight and normal motion during wash/spin a very sturdy floor is necessary under front loads also some floors are a little slick and sliding may occur ck for weak floor and maybe some kind ok rough cushion under feet to reduce sliding also if on pedistals even more vibration may occur be sure all screws in pedistal are secure usually 4 from top onto bottom of washer also adj legs to lower unit as close to floor as possible and tighten lock nuts
Apr 25, 2008 | LG WM-2277HW Front Load Washer
Furniture Logo
50 people viewed this question
Top Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Furniture Expert? Answer questions, earn points and help others
