Question about Vacuums
There was one of those infomercials on televisions about a vacuum cleaner called the SharkDevil.
Has anybody used the SharkDevil vacuum cleaner. If so, could you please tell me (1) Does it work well and (2) Is it difficult to push forward and pull back because I have bursitis and if it's too difficult to use I won't be able to use it?
    Top Expert:
  • Vacuums Master
  • 51,218 Answers
These vacuum cleaners are becoming available at the local supermarket stores so have a test run before you buy.
Posted on Nov 09, 2014
  • 209 Answers
SOURCE: DC07 Very difficult to push forward.
on the front of the base there are 3 very small rollers made out of rubber, these are either just dry and won't turn or worn and or damaged,
that is your problem / honest its that simple
Posted on Oct 15, 2007
SOURCE: brush won't rotate when pushed forward
I had the same problem . The reason it acts like that is due to the cable that runs from the vacuum motor to the brush assembly has an intermittent open. My fix was to find the small cable that was causing my troubles and splice it. Making sure that I recovered the insulation. Of course my local repair station wanted to replace it for $75 labor plus parts and keep it for 3 days. I took it home and did it in 30 minutes .
Posted on Dec 12, 2008
SOURCE: My Bissell Proheat 12 amp is hard to push
I had this same problem and here is what solved it for me. On a previous cleaning session, my wife decided to take the two front screws out of the clear plastic shroud that covers the brushes in order to clean behind it. Upon re-installation, she did not secure the top part correctly. On the end near the water tank, there are two tiny half-moon tabs that absolutely need to be seated in their opposing slots in the chassis.This allows for a good seal which enables the machine to **** up the water. It also keeps the front cover level and from dragging on the carpet when pushing it forward. Both were problems I was experiencing. Hope this helps!
Posted on Jul 08, 2010
heatman101
  • 43501 Answers
SOURCE: Bissell 12 amp proheat steam cleaner
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
trw
Posted on Sep 30, 2010
  • 5370 Answers
SOURCE: When I vacuum my medium **** rug, when I push it
This is the clutch as it jams up in the brush. Usually happens with rugs that are not secured to the floor.---------Check the brush. That could be the problem. Check the belt also. Your brush roller may need to be lubed or even replaced.Turn it over and wipe all the black residue off the bottom of it (off the plastic on the bottom that rubs on the carpet as you push and pull it).----------- The problem is that when the Dyson is new, the filter is clear and the bar on the base is free from gunge. As the gunge builds up, the filter is also getting dirty and the two balance each other out. The problem can come when you clean the filter and you then have the fully restored suction fighting against the layer of gunge on the base. Cleaning it off all areas of the frame on the base makes a real difference.---------- Check underneath take off the brush base cover and see if the brush belt has snapped to the side of the brush bar.----------- This will help.Thanks.Helpmech.
Posted on Aug 11, 2011
Can anybody recommend a reasonably priced vacuum cleaner that works well and either has bags or is easy to empty?
We use both a Eureka Multi-cyclone and Dyson DC07. They are both easy to use and empty and do a good job. The Eureka was several hundred dollars cheaper.
Nov 09, 2014 | Vacuums
How to put the Dyson Vacuum Cleaner out of the upright position?
Hi there, it's Jack at Dyson.
To recline your DC33 into the normal vacuuming position, place one foot on the cleaner held and recline the main body. After use, just stand the vacuum upright and it will lock in position until you recline it again.
I hope this answers your question. If you'd like any further help or advice, please give our experts a call on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Oct 13, 2014 | Dyson DC33 Multi-Floor Upright Vacuum...
Dc24 has started sparking
Hi Amanda, it's Jack at Dyson.
Unfortunately it sounds like the shoelace jamming the brush bar may have caused damage to the cleaner head. It's probably best if you can give our freephone Helpline a call so we can take some further details. If your machine is within our 5-year guarantee period, our experts can confirm if we're able to replace the cleaner head for you.
You can reach us on 0800 298 0298. Calls are free from UK landlines, and we're available from 8am-8pm from Monday to Friday, and 8am-6pm on weekends.
We'll look forward to speaking with you.
Mar 19, 2014 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Replacing a lower duct hose on a Dyson dc24
Please make sure your Dyson is switched off and unplugged before attempting to replace the lower duct hose. You may find it easiest to replace if you recline the cleaner into the vacuuming position, then lie it on it's side, with ducting facing upwards. The hose has a push-fit design, but as it's new, you may find it a tight fit.
If you'd prefer one of our Helpline experts to guide you through the process, please give us a call free on 0800 298 0298 (UK), or 1-866-693-9766 (US).
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com
Jan 21, 2012 | Dyson Ball DC24 Bagless Upright Vacuum
Soap will not dispense from Bisell Pro Heat carpet cleaners
This is a design flaw. The pump design has a problem with staying primed. Only going to another brand will you solve this problem. I recommend the Royal 7900 series extractor.
Oct 01, 2009 | Bissell 1699 ProHeat Clear View Upright...
Dyson07animal won't turn on
First try another outlet. The likely problem is that your Dyson power switch may need to be replaced. If the vacuum cleaner switched off whilst you were using it you may be experiencing a thermal cut-off. Call the Dyson helpline, they'll let you know what your options are to fix your vacuum cleaner.
Jul 28, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Model #5880-900 Hoover spin brush carpet cleaner
i WAS LOOKING AROUND FOR A SERVICE MANUAL FOR MY F5897900 CARPET CLEANER AND I SAW SOME THING ABOUT HAVING TO "PRIME" THE PUMP. YOU PPARENTLY TAKE THE TOOL HOSE AND HOLD YOUR HAND OVER IT FOR ABOUT 15 SECONDS. THIS MAY OR MAY NOT WORK.
ANYBODY KNOW WHERE I CAN FIND A SERVICE MANUAL FOR A HOOVER CARPET CLEANER? SEEMS TO BE A VERY CLOSELEY GUARDED SECRET.
RON
Sep 18, 2008 | Hoover F5906-900 Upright Steam Vacuum
Parking position
I think it only works on the advertisements.
Nov 26, 2007 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
