Question about Generic Mustek Pvr-H140 Digital Av Recorder Hd 40gb Pvrh140
<!-- from fixya rte -->Where can I find a battery for my pvrh140 - Generic Mustek Pvr-H140 Digital Av Recorder Hd 40gb Pvrh140
I have 4 x 12v batteries 7ah each. if i put these 4 batteries together . how many volt and AH would this be. please reply . thank you
It depends on how you connect the batteries. If you connect the negative of battery one to the positive of battery 2, the negative of battery 2 to the positive of battery 3 the negative of battery 3 to the positive of battery 4 then the positive of battery 1 and the negative of battery 4 will give you 48v 7AH. (This is known as connecting in series.)
If you connect the four positives together. Connect the 4 negatives together it will give you 12v 28 AH. (This is known as parallel connection.)
If you connect the negative of battery 1 to the positive of battery 2. Connect the negative of battery 3 to the positive of battery 4. Connect the positive of battery 1 to the positive of battery 3 and the negative of battery 2 to the negative of battery 4. You'll get 24v 14AH from the connection of the positive of battery 1 and battery 3, and the negative of battery 2 to battery 4. (This is known as series parallel connection)
Jul 19, 2011 | Electric Cycling
I need a new battery for my 1986 Oldsmobile ninety-eight regancy sedan. fully loaded. what type of battery would i need?
Attributes Battery BCI # : 75
Battery CA @ 32 Degrees F : 775
Battery CCA @ 0 Degrees F : 630
Battery Height : 7 1/4"
Battery Length : 9 3/4"
Battery Posts Type : Side Post
Battery Reserve Capacity : 90
Battery Voltage : 12 volt
Battery Weight : 33 lbs.
Battery Width : 7"
Wet or Dry : Wet
A lead acid battery with the fallowing specs
group 75
Battery Width : 7"
Wet or Dry : Wet
Battery Width : 7"
Wet or Dry : Wet
Battery BCI # : 75
Battery Width : 7"
Wet or Dry : Wet
Feb 27, 2011 | 1986 Oldsmobile Regency
Nikon D40x indicate battary low
Rechargeable Lithium-ion 7.4V 1000mAh Nikon D40x battery for sale,20% off! Full one year warranty! For more info visit: http://www.nikon-coolpix-replacement-battery.com/d40x.htm
May 13, 2009 | Nikon D40x Digital Camera
Goodmans GPDR40
14th August 2007 I've heard of this problem. The operationg system or part of it is on the hard drive so if something happens to the data the unit gets stuck at the opening window. A suggestion I've read about is to open the unit and try and reconnect the ribbon cable to the drive, it's a push on job apparently. Of course, this will invalidate your guarantee AND may not solve the problem. I've not done it myself so can't give any firsthand advice. Regards
Aug 13, 2007 | Goodmans GPDR40 Digital Media Player
GPDR 40
1. you need to install the pc software 2. you need to connect the system to your pc via the usb cable 3. switch the system on - it should be seen as a mass storage. 4. Start PVR Console and run a disk checkup - this should run without error - run this twice. 5. Try the unit now - does it work? 6. if you still have problems you can replace the files in pvr data with the following:- http://mustek.com/product_resources/drivers/pvr-upgrades/pvrh140-datafiles/pvr-h140_restore_files.zip good luck Ian
Jul 13, 2007 | Goodmans GPDR40 Digital Media Player
Trouble starting up
Dec 15, 2006 | Goodmans GPDR40 Digital Media Player
Generic Mustek Pvr-H140 Digital Av Recorder Hd 40gb Pvrh140 Logo
Top Generic Video Cameras Experts
Lawrence Oravetz
Tom Chichester
Tony Parsons
Tony Parsons
Are you a Generic Video Camera Expert? Answer questions, earn points and help others
