I have 3 codes c 542 and s744 and - 335 code ant body know what these are
  • 3,506 Answers
Google these codes
Posted on Nov 09, 2014
A samsung fridge RF4287HARS has error codes 40E, 21E and 22E
Hello Jerry Fuller,
All your codes point to the same circuit pack.
Main Control Board ...DA41-00884a
PCB "CN76" low voltage condition... Low Voltage condition
(PCB = Printed circuit board)
CALL...
If you have any questions or comments relating to Samsung products,
55 STANDISH COURT MISSISSAUGA,
ONTARIO L5R 4B2 CANADA
Please contact the SAMSUNG customer care center.
SAMSUNG ELECTRONICS CANADA, INC.
TEL : 905-542-3535 FAX : 905-542-3835
1-800-SAMSUNG (7267864)
www.samsung.com/ca
owners manual
Samsung RF4287HARS User Manual
Service MANUAL (CODES on page 60)
Samsung RF4287HARS Service Manual
Feb 13, 2014 | Samsung RF4287HARS French Door...
Service code 542
fuser problem, push in order clear modes (yellow button) 1 0 7 and hold the red stop button for 5 seconds the screen will change, turn off copier red power switch and turn back on if problem comes right back you need a service call
Sep 30, 2013 | Ricoh Aficio 450 Copier
Err cod 542 Ricoh 1035
replace the thermostat & reset 107 turn off & on the the main switch. sometimes the body of the fusing unit that hold upper roller bushing get damage. if u reset it will be ok, and at certain time the code will appear again. if the body of fusing unit got broken then u got to replace it. once more, check the thermostat, normally 1 of them got broken.
Aug 25, 2011 | Ricoh Aficio 1035 Copier
My 93 towncar runs rough cold. it backfires up through intake i replaced plugs, wires and one coil pack, coolant sensor. i read codes 226 and 542. it runs ok warm, but can still hear misfiring, it feels...
YOU HAVE INTAKE MANIFOLD LEAK ALSO COULD HAVE BAD OR STICKING INTAKE VALVES. CODE PO 226 IDM SIGNAL NOT RECEIVED AND CODE PO 542 FUEL PUMP SECONDARY CIRCUIT.
Mar 12, 2011 | 1993 Lincoln Town Car
The abs light on my 2000 grand vitara keeps coming on. What is the problem?
Need to have computer diag. done, withoout a code it be ant bodys guess, go to any auto parts place or some one like autozone and they will pull codes out for free, then get back with us here at FixYa with the code so we can help you diag. your ABS problem code.
Jun 12, 2010 | 2000 Suzuki Grand Vitara
Service Code SC 542
That is fuser code and needs to be reset in the service mode, it will not go away by turning the off and back on.
May 29, 2009 | Ricoh Aficio 1027 All-In-One Laser Printer
Sc 542-00 trouble code
SC542 is a fuser error code and can ONLY BE RESET by a tech. Type pressing clr mode (button) then 107 then press and hold CLR Stop until a menu pops up. turn offf main power then on again. If there is no serious problem the code will not come back. IF it does call a trained tech. DO NOT CHANGE ANY SETTING in the menu that comes up after pressing in the code. YOU COULD RENDER YOUR COPIER INOPERABLE!!!!!!
Mar 27, 2009 | Gestetner Copier
Savin copier 9400d error code 542
I believe that code has to do with the fixing unit. Try to reset it, press the yellow clear botton once then the #"s 1-0-7 then the red stop botton. The display should change.... turn the copier off then back on.. It should reset the code for you.... Just a question dose it have a finisher on it? If it dose have you tried to unplug the finisher with the power off then turn it back on...Is the code gone..if so you have a problem with the finisher... I work on to many different brands.... Good Luck
Jan 31, 2009 | Office Equipment & Supplies
Sc 542 error code
Error SC 542 indicates a fuser temperature problem. Once the error is detected, the printer is toast until you manually clear the error from the keypad. Even though the printer is physically fine, it won?t come ready until the prior error condition is cleared. The magic keystrokes, clear the error code: The Fix In order to clear error SC542, you must perform procedure 5810. Press and hold online + escape, then power on. Use up and down arrow keys to select SP2 Press Enter Use up and down arror to locate SP5 Press Enter Use up and down arrow keys to select 810 Press Enter Confirm the selection Power off and on. The error code is now cleared.
Aug 13, 2007 | Ricoh Aficio 2015 Copier
43 people viewed this question
k24674
