Question about Dryers
We have the Eagle-i and we are not getting power to turn on lights or propel the blades.
  • Thomas Smithbrother Nov 17, 2014
    Hi Michael Dippold, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? Who made the fan, which company?
    Genius:
  • 1,617 Answers
Need more info! Make/ model of fan. Does it have a remote?
Posted on Nov 24, 2014
Poulan self propelled 22in blade hit a rock broke tip of blade starts then stalls
Did you bend the crankshaft. To check this out remove spark plug wire and tip mower on it's side and turn blade by hand and watch the shaft the blade is fastened on to. There should be no wiggle motion what so ever and if there is it may be bent causing the engine to not operate properly.
Sep 27, 2014 | Garden
Self propell not working right
Leave aside all the puffery about 3-1 and such, you described a front wheel drive (pull) walk-behind (FWD), but are asking why the rear wheels won't propel. When you push down the hand grip the front wheels should spin free. Whan you lower from wheels by releasing pressure on hand grips, turning wheels lowered to ground should propel the mower along with its unpowered rear wheels now turning be ground contact. Reminder, never, ever lift rear drive wheels of any mower off the ground while walking behind with engine running:
  1. You could be struck by blade propelled object.
  2. You could pull mower and spinning blade backward onto your feet.
  3. You could lose balance and be pulled forward in a fall.
Contemporary FWD mowers are recognized by a black chain housing on deck top leading from engine to left front of deck. RWD propelling chains are situated underneath deck so cannot be seen from above.
Jun 25, 2014 | Troy-Bilt 12AVB29Q711 TB260 21-Inch 160cc...
LAWNMOWER STRING WONT PULL
Unplug the spark plug.
Try to turn the blade by hand, be sure to use a heavy glove to protect your hand from the sharp edge.
If the blade turns, then move it back and forth to free it up.
If it won't turn, take the spark plug out and try to turn the blade .
If it won't turn, you may need the engine overhauled.
If it will turn, put a level teaspoon of light oil in the spark plug hole, and turn the blade a few times.
Now try the pull rope.
If it works, put a level teaspoon of fresh gasoline in the spark plug hole and install the spark plug.
It should start
Be blessed.
Feb 17, 2013 | Briggs & Stratton LawnBoy 20Inch 65 HP Gas...
Troubleshooting the wireless us eagle copter
The green light won't turn on when I try to charge it on the controller. It also won't charger at all, just the red light on and copter off
Dec 09, 2012 | Sky I Blade Mini IR Helicopter W/ Remote...
I changed the blade, and now it won't start!
Did you replace the blade with a heavier blade, or an identical one? If the pull cord won't pull, it's usually either the blade or the blade shaft causing the problem. Try oiling the shaft and making sure nothing is obstructing the blade from turning.
If you have a pair of heavy gloves, try turning the blade by hand and see if it moves. Squirt some oil onto the shaft where it meets the mower and try turning it again.
May 25, 2010 | Craftsman 22 in Precision Cut Lawn Mower...
My mower attempts to turn over then hums. wires get hot on battery. replaced battery and starter
DISSCONECT spark plug turn mower upside down try and turn blade clockwise if no go engine is seized or blade is bent and jamming hope this helps merlinv1`2
Aug 18, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Self propel issue ????
The gear drops and lowers blade slightly until the gears are changed and engaged.
Aug 14, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Heli max hicro helicopter just keeps spinning in circles
Spinning is caused by one of the main propellers rotating faster than the other. If both propellers are secured tightly to their drive shafts, the spin control knob on the remote control can be used to stop the spin. However, if one prop is slipping with respect to the other, the spin control knob will not fix the problem.
I've found that the set screws holding the propellers to the drive shafts tend to loosen after a while. If one prop is a bit loose and the other is tight, the relative slippage will cause the helicopter to spin.
To check, turn off helicopter power and manually rotate each propeller separately, watching the nylon gears in the body. If the propeller is moving and its drive shaft gear isn't, the propeller is slipping because its set screws are not applying enough pressure on the propeller's drive shaft.
Carefully tighten the set screw and the problem should be fixed. DON'T OVERTIGHTEN, or the plastic threads for the set screw will be stripped and the propeller assembly will be ruined.
Apr 10, 2009 | Max Heli- Axe CX Micro Electric Rc Mini...
Dryers Logo
Top Dryers Experts
