Exide Electonics One-Ups 250VA. I am turning on this unit after a long time and the green light on the front started blinking and after a few minutes it is still blinking. Does this mean it is recharging and if affirmative will it stop blinking when it is fully charged. Approximately how long should it take. Any tips to test. Thank you.
  • 45 Answers
The OneUPS is a really old model that has been discontinued. I'm not sure if you've recently replaced the batteries or not. Assuming that you haven't, it's likely that the batteries are dead. Given the age of the unit, I suggest that you consider getting a new UPS.
Posted on Nov 14, 2014
  • 355 Answers
SOURCE: All battery charge lights flash simultaneously.
THIS seems the be the answer to your question. Hope this helps
Posted on Apr 29, 2010
  • 37 Answers
SOURCE: how do I test the compaq r3000 ups unit. no manuel available
ok here the user manual for compaq u are refering go to this web site: u be able to find it. ftp://ftp.compaq.com/pub/products/servers/proliantstorage/power-protection/r3000xr-whitepaper.pdf
or
http://www.google.com/search?sourceid=navclient&ie=UTF-8&rlz=1T4SKPB_enSG294SG295&q=compaq+r3000+ups+user+manual
Posted on Mar 31, 2009
  • 55 Answers
SOURCE: Smart UPS 1500 - battery level green lights blink on and off
You need to run recalibration on the unit.  The supplied PowerChute software & cable will allow you to do this if you hook the UPS up to a PC (I know it works with the serial cable, not sure about USB).  If you only have a MAC then I cannot offer a solution other than to buy the standalone PowerView device from APC.  It will cost a bit more than a battery, but may save you from buying needless batteries in the future.  I finally broke down an bought one, but note that I was still having the problem after the 1st recalibration.  By trial and error (and maybe a vague memory) I put my MAC in sleep mode, that dropped the load to stop the lights from flashing.  Then I recalibrated with a 22% load and now it finally seems better (lights no longer flashing).  This was with a Smart-UPS 1000.
Let me know if that helps.
Posted on May 09, 2009
  • 19 Answers
SOURCE: APC Back-UPS ES 500: green light flashes&continuous warning tone
On this unit, the likely culprit is the battery and that it needs to be replaced.
With that, you may want to think about the pros and cons of replacement versus buying an entirely new unit.
This unit is a relatively low end ups and the surge supression uses MOVs that wear out with repeated absorption of energetic spikes. That's why the better (and higher cost) UPSs and surge suppressors don't use them. They're not really that good anyway due to their relatively high transient impedance. The better equipment uses a "transorb" -- basically a back-to-back high voltage zener diode optimized for low breakover impedance and high instantaneous power capability. Unless the transient exceeds the design parameters of the circuit, these do not wear out and do not degrade. That being said, I will assume that you would likely replace this unit with a similar one.
The flashing may not be the battery at all and may be the charging circuitry, thus your new battery may not live very long (half the life that you would expect.
Many batteries out there are refurbs and have issues as all used parts do.
If you contact APC, they will likely give you a 35% discount on purchasing a new product.
The difference in price in the battery replacement vs. ups replacement at this level may only be a few dollars more.
I promise that I am not a UPS salesman, I just deal with many on a daily basis; therefore I am giving my two cents to try to thelp you avoid problems a year from now.
Posted on Dec 30, 2009
Testimonial: "Outstanding answer with right amount of detail. I swapped battery with identical APC UPS that I have and vfd that battery was cause of warning tone."
  • 608 Answers
SOURCE: What does it mean by the beep sound from the UPS ES 350 unit?
Ok, 3-4 years is a much as you can expect from an ups battery so replacement is indicated. The beeps are letting you know the battery is not able to keep up with demand. So either you have recently added to the system or the battery/s failing.
Posted on Apr 25, 2010
Manufacturing year of Exide MR700 so no A2G4D026543 2142
This doesn't sound like it relates to UPS systems. The Exide MR700 is a charging unit for rechargeable batteries.
http://nirbheybatteries.co.in/product.php?pid=622182
The Exide MR700L is a car battery.
What is it you are asking about?
Jun 05, 2015 | Exide Computers & Internet
Apc bf250 will not power on
Did you charge the batteries before installing them?
Jun 27, 2017 | APC Back-UPS Office 250VA (BF250) UPS...
I have a SONY KF-WE50 rear projection tv, a few weeks ago it started to turn the pic and sound off while the green light was flashing around 30 times. After the light finished flashing both the picture and...
the green is the reboot process and is normal.
the red light is an error code indicator.
count the blinks of the red light...it cant be 30 times (I think)
it will blink a sequence, pause, then do it again for a total of three times.
count carefully, it gives you three chances to catch the number it is blinking.
Apr 13, 2011 | Sony Televison & Video
We have a APC Smart UPS 2200XL. We had a power failure last night and now all six lights in the front (AVR Trim, On Line, AVR boost, Overload, On Battery, and replace battery) are flashing at the same...
The light pattern indicates the batteries need to be replaced. The typical life of UPS batteries is 2.5 years, after this time the cells will not hold the proper charge. When your power when off last night the UPS would have tried to switch to battery power but it most likely failed after just a few minutes as the batteries shorted. The UPS has a protection circuit that prevents it from starting up properly with dead batteries so you get the flashing lights and the unit shuts off. The batteries are available in most cities from car battery dealers, not like Wal-mart but battery only dealers, just look in the yellow pages for batteries. You can take the old batteries out of the unit by removing the front panel and unscrewing the metal plate just behind the front cover. The old batteries are connected with a wiring harness that plugs in. Just bring the old batteries to the dealer so they can get you the correct replacement part. The new ones should be less than $100 so it is well worth the price compared to a new unit.
I hope this helps, if so please rate our solution.
BuddyMc
Feb 04, 2011 | APC Smart-UPS 2200XL (APCSMART2200XL) UPS...
I have a HDTV 1080 and the power to our neighborhood went out over the night and now the green light on the TV just blinks. I can't get the TV to turn on. I have reset the system reset button on the from...
try this ... if there is a reset button on your 'front' control panel..maybe 2 - 3 positions to the left of your blinking timer light..
try inserting the tip of a mechanical pencil or tip of a straighten paperclip into the 'tiny hole' of th ereset button ...hold pressure on that button until yout blinking light starts blinking RAPIDLY .. this
rapid blinking should continue for several seconds or a minute.
then it should stop .. may even go off ... now ..hopefully.. you will be able to turn your set on
Aug 20, 2010 | Mitsubishi Televison & Video
Blinking lights
The problem is, is that while the unit is not overloaded (too much plugged in) either the batteries are close to failure, OR more likely you have so much plugged in you have less than 2 minutes of runtime.
Try removing some devices, lower the load. The row of green lights on the left is your load level indication, you want no more than 4 lit usually, 80% load is the most recommended. This will allow more runtime and should stop the flashing.
The flashing is just ment to alert you to less than two minutes of runtime.
If you have 80% load or less, and it still flashes, press and hold the on/test button until it clicks over to battery, the unit will now run a self test and switch back to main power after a few seconds and it should stop blinking.
If you want a copy of your user manual, you can find it here: http://www.refurbups.com/KB-M-Smartups (the Smart-UPS 1000)
Apr 08, 2010 | APC Smart-UPS 1000VA UPS System
Apr 01, 2009 | APC Smart-UPS 1000VA UPS System
Ups
Which ups do you have? The category you are listed in here says scanners. My ups has a steady green light when charged and it should never lose the charge until power is lost for 20 minutes. Please post back if you nedd further assistance with the brand model.  Steve Medley
Feb 15, 2009 | Umax AlphaVista Flatbed Scanner
Blinking green power light & shut down
There are (4) 1000uf @35V capacitors all together on the DM board that need to be replaced some models have 1000uf @ 16V but they are all right beside each other and all rated at 1000ufs the voltages will be stamped on the capacitor along with the uf ratings.
Apr 07, 2008 | Mitsubishi WS-55515 55" Rear Projection...
Computers & Internet Logo
112 people viewed this question
David Payne
David Payne
