Question about Garden
I bought a water hose in June and forgot all about it. As we were cleaning out the garage we found the pocket garden hose still in the box. I found the receipt and tried to bring it back to Walmart
I bought a water hose in June and forgot all about it. As we were cleaning out the garage we found the pocket garden hose still in the box. I found the receipt and tried to bring it back to Walmart in R.I. but they refused because it was after the 90 days. I understand that you can not get the tax back on the item but with a receipt the retail purchase could be given back. Now, they told us that if we didn't have a receipt that they could give us a gift card for the iten minus the tax. But we would have to show our license and be put into a log book. WHY???? I have the receipt so if I didn't have the receipt I would be getting money back??? This doesn't make any since to me. Again WHY?????????
  • 2,901 Answers
Return policy is set by the store. It can be anything they decide it should be. If they publish "90 day return" only, then that's the policy, and you may be stuck with your item. There are no laws about returns, only individual store policies.
Posted on Nov 08, 2014
SOURCE: ilo 32inch LCD TV
You can find your manual here by filling out the form. The name of the manual is IWT3206 and I found it by doing a google search by typing in manual for ilo IWT320. You have to fill out the form tho and I don't think it costs anything. Don't remember exactly the site I used to find mine but it was a free download. It came from a google search also.
Hope this helps, and this is a great tv. I did not know I had to buy a hi def antenna tho--please post here where you found one and the cost. Thanks
http://manualsnguides.com/search2.php
Posted on Jan 05, 2008
tvtek
  • 1284 Answers
SOURCE: FREE GIFT
I would go to www.clarkhoward.com for advise on this. He is a consumer advocate and most likely can help.
Posted on Jun 10, 2008
SOURCE: BB return policy
CUSTOMER SERVICE IS VERY IMPORTANT AND ONE MUST DO WHAT IS FAIR AND AGRREABLE
Posted on Jun 29, 2008
  • 92 Answers
SOURCE: register a 32 inch Vizio Tv
go to www.vizio.com. select the support and go down to the register your vizio. Fill out the require field and press submit. this will get your TV register.
Posted on Jun 16, 2009
dsacco86
  • 1077 Answers
SOURCE: New Vizio tv shuts off after June switchover
Well, your TV is no doubt under warranty. The only reason I can thing of why they want you to use a DVD player is to find out if the Digital Tuner inside the TV is the source of the problem.
They need to replace the Digital tuner board or the main mother board. Either way, they have to come out to your house to replace a part.
Just keep hammering them of the warranty coverage.
Posted on Jun 28, 2009
No heat in car but blower works fine
your heater core might be clogged or have an air pocket in system for this, when engine is cool, take radiator cap.off, if you have a no spill funnel to use, then set it up and start.you car and fill your no spill funnel and let it run to burp your system if you dont have one, then take cap off, place a bucket under.your radiator, start your car, let it run till warms up, watch your antifreeze if it starts to burp.and lower, then you had air pockets, it also.helps if you raise the front end of your car to a little if your heater core is clogged feel your heater core hoses, the top one should be hotter then.the other one, if not, back flush your heater core to do this, wait till your engine cools, take off both.heater core hoses then get about 6 feet of heater hose the same size, place about 4 feet of hose on the top heater core line and place a clamp, put this hose into.a.bucket, take the other two feet of hose and place on the bottom heater core line and clamp then take your garden hose and turn water on, into the bottom heater core hose, this will push all the antifreeze and junk out the top hose that goes into.the bucket do this till you have clean water coming out now if you also have.an air compressor, after you have clean water, do the same thing with the air hose, but only use no more then.20psi of air, you dont want to screw the heater core up after you did the air, I.always run more water though it.again to make sure everything is out after you have done this, put the heater core hoses back on, and fill system, start your car, and do as I.said above to burp the system also check your radiator cap, I will always replace them if they.are more then 5 years old, the gasket goes bad, for every psi you lose in your system, you lose heat, I forgot how the math works, but it can be 10 degrees of heat lose do.a.back flush when your eng is cool
Dec 05, 2013 | 1999 Ford Taurus
Bought this grill in june/july. first tank worked perfect. tank went out while cooking. changed to new tank and lit her up. low flame and went out. looked at tank and found the valve and hose covered...
turn off gas at tank remove hose let it deforst , open all burners on bbq run out gas in line , turn off burners, reconnect tank turn on slow , check hose for leaks with washing up liqued and water mix make bubbles with this mix and brush over joints this will prove if you have a gas leak (hence the frosting ) if this is good no leak then you should be able to light burners , if this leaks then it could be a new hose.
Sep 24, 2011 | Weber Spirit SP-310 Propane Grill
How to i flush a radiator on a 2000 expedition and what tools do i need?
you need, knife/ gear clamp,screwdriver /nut driver (for gear clamp) and garden hose
with water pressure hook up hot water is better
you can buy a can or to of rad flush but dishwasher soap works good (it wont suds up )
also rad flush kit with garden hose addapter (most kit are compatable)
1-drain existing coolant in container for recycling
2-locate heater return hose to block and cut to installed flush kit addapter
always better to reveres flussh system with engine off and rad cap removed
drain valve closed hook up garden hose and run hot tap water true system
it will eventually cove out your rad cap (surge tank) until it runs clear
know sut off the garden hose add your cleaning additives installed rad filler cap
run engine per direction on can or 10 to 15 min. sut off engine removed filler cap
open drain valve on radiator and drain out system open water from garden hose
run water until clean water run true shut off garden hose and removed cap off with
cap supplied with kit let system drain completly . repeat cleaning operation until
water runs clear
add 1 jug of concentrated coolant (will mix with ressidual water and finish filling
system with premix used recomended coolant only for your engine your freeze
point of new coolant should be above spec and will be fine
do not used pure concentrated coolant only .your ownners manual spec section will
give capacities system will hold
Apr 03, 2011 | 2000 Ford Expedition
I bought a 8 by 30 intex pool without a filter howcan I clean the pool
you can use a Vortex cleaner that uses your garden hose
it is called Swin Safe
Supa Vac Water Care Kit with Leaf ScoopThe Swim Safe Supa Vac Water Care Kit with Leaf Scoop allows you to quickly clean or empty a wide range of water fixtures.
The Swin Safe Supa Vac Water Care Kit includes hose and accessories.
You should be able to buy this fram any decent Pool shop or Google it on line
Jul 03, 2010 | Computers & Internet
Have a 1983 Toyota 4x4 short box truck. put new thermostat in and had pressure test done but no leaks. Over heats when going up hill. What would cause this?
A clogged radiator. You can try to flush the radiator with water from a garden hose. Disconnect the upper and lower radiator hoses and remove the radiator cap. Stick the water hose in the neck of the radiator and turn the water on about half way and let it flush for 10 o 15 minutes. Make sure when you top off the system that it is free of air pockets.
May 25, 2010 | 1983 Toyota Pickup
No heat when switching between cold and hot.Both hoses hot in engine compartment.Changed the temp control switch.
Possible problem with the vacuum actuated damper control system. Bad vacuum line or damaged vacuum actuator could cause this problem. Next, check to see that the heater core is not clogged. Do this by disconnecting the heater hoses and using a garden hose to force clean water through the heater core. You can generally just hold the garden hose to the point where the heater hose was connected and then watch to see if you get good flow and clean water out of the opposite connection. Usually you'll find that sediment build-up in the heater core is limiting flow, thereby reducing the amount of heat you get in the passenger compartment.
Jan 25, 2010 | 2004 Ford Explorer Sport Trac
Water pump maybe?
I doubt it you got an air pocket probaly head gasket if high milage for also intake on that engine
Aug 19, 2009 | Pontiac Grand Am Cars & Trucks
I'AM LOOKING FOR A DIAGRAM OF THE COOLING SYSTEM; SO I CAN DISCONNECT THE HEATER HOSE AND USE A WATER HOSE TO RUN THROUGH IT TO SEE IF ANY DEBRIS ARE TRAPPED BLOCKING WATER FLOW
This is how I flush the heater core...go to the garden department at Wal-Mart and get a 5/8 - 3/4" female garden hose connector similar to my picture...remove the upper heater core hose and connect your garden hose to the connector then to the heater hose and secure with a hose clamp. Remove the lower heaer core hose and point it to the gound, then turn on your faucet and run clean water thru it... b67bfc8.jpg
Mar 24, 2009 | 2001 Chevrolet Venture
Garden Logo
758 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
