Question about Lands Phones
How can I turn on the volume of my out-going-message when I am home (monitoring incoming phone calls)? Up until now (when we just had a prolonged power outage), when the phone rang, I could hear both the outgoing message as well as the incoming message and I could adjust the volume for each message (OGM as well as the ICM). Now, I can only hear the incoming message. I remember having this problem once before (a number of years ago) and I was able to fix it, but now, I can't seem to remember how I solved this vexing problem. I would greatly appreciate any help on this issue. Thank You, Dave 917-721-5163
  • 2 more comments
  • kakima Nov 08, 2014
    What make and model answering machine?
  • nycatnyc Nov 11, 2014
    im not sure what else you need - you can callk me at 917-721-5163
    Add a Commentthanks
    Panasonic KX-T2720
SOURCE: number of rings on Panasonic phone
Press the menu button and scroll to "ringer setting" and set to what you want. If that does not work scroll to "initial setting" and that lets you change the number of rings you want it on. When you set it to the number then hit save to save it and it will give you more rings. The second one "initial setting" is what I used.
Posted on Jun 12, 2008
SOURCE: vtech w/answering maching does not allow outgoing calls or record
unplugging the unit from the power source and waiting 30seconds seems to be the answer. the answering machine is working and i can call out again.
thanks you to everyone who posted that answer in different parts of FixYa.
Posted on Jan 31, 2009
SOURCE: Heavy Static on phones. Can't hear caller. No caller ID
Room monitoring mode is basically a type of Intercom.
Press the *TONE/exit button on the handset to exit room monitor mode.
I will provide you with link to the user manual of the phone. Have a check at it. Might be useful.
Posted on May 30, 2009
  • 2460 Answers
SOURCE: Incoming calls on home phone ring 1 time and then extreme static
When you unplug everything connected to the phone jack what happens? If it works, you have too many ringers or a short on the line. If it still trips the ring, you have a defective box.
Posted on Jul 06, 2009
SOURCE: Incoming calls only ring once then hangs up. Can call out/not in
reset your mobile
Posted on Jan 29, 2010
My Apple I phone will vibrate on incoming calls but my ring tone will not come on
If the switch on the side of the phone is flipped down (red showing) then it is set to silent/vibrate mode. If that isn't it, then go to your home screen and try pressing the volume up button on the side of your phone several times until it reaches the desired volume.
Mar 10, 2015 | Apple Working Black Att Iphone I Phone 3gs...
Can u turn up the volume on receveing text messages on my LG c300
yes go to options and sounds and you should see option for messages that you can adjust the volume there.
Mar 20, 2011 | Cell Phones
How can I silence incoming messages so that these can not be heard by others present but will be stored in the phone until I'm ready to listen?
This feature is called call screening. To turn off call screening, press and hold the down arrow button on base unit while screening a call until the call screening volume turns off. I have included a link where you can download the manual for your phone /answering systemin case you need it. Turning call screening off is on page 31.
Mar 20, 2011 | Panasonic KX TG6441 Phone
When i receive a text message my nokia E72 doesnt ring, what could be the problem?
Does the phone ring when you receive an incoming call? If so, press Menu go to Control Panel (or might be the profile is shown in the menu) after control panel, Profile then Options and then Personalize, then, scroll down and again select Message Alert Tone, set the Tone for the message. Also make sure that the volume is turned up. Save the settings and try again. If this doesn't help and you don't hear any ring tone during an incoming call, let me know after checking the sound settings.
Good luck.
Thanks for using FixYa.
Sep 03, 2010 | Nokia N72 Cellular Phone
Volume off on incoming calls
There are two ways 1) as your looking at your phone on the top left side of the unit there is an little toggle switch to turn the ringer of or down just a bit. 2) (navagator key) in the bottom right hand corner there is a circle with four arrows on it simply press the down arrow until it says ringer off
Jan 07, 2009 | Panasonic KX-T7730 Corded Phone
Can not hear incoming call, but can hear out going call.
There should be a volume adjust button on side of phone. Without making a call. Push up on the volume button. You should here your ringtone. Keep turning up until you reach the right volume.Good Luck
Oct 27, 2008 | Pantech Duo Smartphone
Volume of incoming calls
Press the down arrow under 'Volume' on the base unit. The handset volume is in the middle and has a down arrow on the bottom of the large silver button.
Aug 24, 2008 | Panasonic (KX-TG1032S) Phone
Samsung E900
Sound settings Use this menu to customise various sound settings.
Incoming call
Use this menu to select a volume level and alert type
for incoming calls.
Alert type: specify how you are to be informed of
incoming calls.
Ring tone: select a ringtone for the call ringer.
Volume: select a ringer volume.
Keypad tone
Use this menu to select the tone that the phone
sounds when you press a key.
Message tone
Use this menu to set up the ringtone for incoming
Menu functions
Tone: select one of several message tones.
Alert type: specify how you are informed when a
message comes in.
Repetition: specify how often the phone informs
you of a new message.
Power-on/off tone
Use this menu to select the melody that the phone
sounds when it is switched on or off.
Slide tone
sounds when you open or close the phone.
Silent mode
Use this menu to set how the phone acts to alert you
to a specific event in Silent mode.
Extra tones
Use this menu to customise additional tones for the
Minute minder: set the phone to beep every
minute during an outgoing call to keep you
informed of the length of your call.
Connection tone: set the phone to beep when an
outgoing call is connected to the system.
Alerts on call: set the phone to beep when you
receive a new message or when the time for an
alarm comes during a call.
Indicative tone: set the phone to beep when a
pop-up window displays.
Apr 28, 2008 | Samsung SGH-E900 Cellular Phone
there are some settings in your handset
-menu-profiles-select the current profile-than personalise-than click on tune set up, than u can select your mp3, you can select your tune mode/volume
Oct 13, 2007 | LG CU500 Cellular Phone
Lands Phones Logo
47 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
