Question about Car Audio & Video
Why won't my Emerson model # MS9920TT work? The little light on the power button is lit but nothing on the system will work?
I really like this system, and I haven't used it in a while, and when I went to use it, nothing would work or turn on, there seems to be something not connected, the power button's little red light is on but the rest of the system won't work. Nothing on it works I don't understand, I had it in the wall unit and its just dead. Please tell me that there is something that I can do. This little system is so compact and has everything I need in it, the turntable, stereo radio, dual cassette and 5 cd player. I await your response, thank you.
HLuis
  • 19 Answers
SOURCE: CD player -- NOT playing
did you alredy clean the laser lens?
Posted on May 09, 2007
pnevai
  • 48 Answers
SOURCE: JVC car radio/cd player wont switch on
As a sanity check run a temporary wire directly from the battery positive to the radio. Twist the red and yellow wires together and connect it to the wire from the battery. If this works either your red or yellow wire connection under the dash or to the harness is not hot like you think. Yellow usually goes to a constant 12 volt source (to keep radio memory) and the red wire to 12volts when the ignition is on. In some radios this is reversed. The test I mentioned will determin if the problem is in the wiring or the radio.
Posted on Jun 29, 2007
ampman
  • 98 Answers
SOURCE: NO Power
Hi. You need to check a few things. make sure you have power on both the red and yellow wire with the key one. If only one has power the radio will not work. also make sure that you have a good ground connection on the black wire.. if nothing works yes you probhably have a bad radio. the dual brand radios are notorious for poor solder connections on the mainboard due to the way they build thier cheap circuit boards..
Posted on Sep 05, 2007
Benimur
  • 6966 Answers
SOURCE: Red light on power button is on but player still won't turn on, help please!
At most that I can share with you are generic.
If this is a fairly new car/radio model - When your battery died, the radio assumed that it was forcibly removed from the original vehicle it was installed to. For security purposes, the radio will not be usable by anybody not unless re-initialized (security unlock) by the original dealer of the car. You need to bring documents as proof of ownership, VIN information, and all others as may be required to your car dealer who would then submit them to an online support that would verify authenticity of claim and if the "numbers" match. Thereafter, a series of codes and procedures would be given to your dealer who in turn would use them to restore the JVC to operational status. There is nothing wrong with the JVC other than it will not let the user use it.
There is no known bypass to this. There is however a modification that could be done to prevent from happening again.
If the car/JVC does not employ the above described security feature, then chances are that internally, the JVC has developed a fault. Since this would require opening the unit, electronic circuitry diagnosis and possible component replacement, perhaps your best bet would be to seek the services of a qualified auto audio technician.
Hope this be of some help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Posted on Nov 13, 2007
  • 2039 Answers
SOURCE: Please Help
check face plate maybe contact dirty if not well our in trouble sometime it not worth to repair it cheers
Posted on Jan 14, 2008
Machine won't work.
Robert. You have a bad water valve OR completely clogged up filter screens on the valve. My past experience with this machine with this type of problem is to replace the valve assembly. part Number W10364988
Apr 09, 2014 | Maytag Bravos Series MVWB300WQ Washer
My tablet is totally frozen!! please help
Gee if only you told us what make and model!!
Mar 26, 2014 | Tablets & eReaders
Emerson tablet hard reset
With the unit powered on, you unplug it from power source.
Then push and hold the power button for about a minute. THEN, replug back in and turn on. And cross your fingers.
Aug 07, 2017 | Tablets & eReaders
Emerson ceiling fan remote won't work
Check the remote control for its infrared emission. Check its battery contacts for any rust or dust. Check it with fresh batteries.
Nov 05, 2012 | Emerson 44 Curva Sky Ceiling Fan In...
How do you recharge jump start system
put a battery charger for a car on the + and - leads and this will recharge it if you do not have the correct power pack recharge transformer
Jan 09, 2012 | Stanley Black & Decker Stanley J5c09 500...
Nothing on Radio stereo system works. The power comes on nothing plays. There is also CD jamed in the player. Where do I go from here? Emerson NR303TT serial number 61100051 CA
check to see if the cd player has a little hole next to it if it does that is a release use a paper clip to push into the hole that should get your cd out.
Mar 28, 2010 | Emerson NR303TT CD Shelf System
Cannot connect in any way to router, all lights on.
access your router's web-based configuration page at http://192.168.1.1
Sep 04, 2009 | Linksys Wireless-G WRT54G Router
Car Audio & Video Logo
56 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
