Need the pairing code for Sykik Sound 1 speaker system
My iPhone don't work with my Bluetooth speaker system
Paired is not connected. Connecting is the next step after pairing. Then make sure that the ilive speaker is set as the dudio output device.
Dec 22, 2013 | iLive Bluetooth Speaker System
I'm having a problem with sound from a Marantz SR48 MKII. I have a pair of Klipsch monitors connected to the "system 1" outputs on the Marantz and a Polk PSW100 connected to the "system...
I'd say you DO need to evaluate how the PSW is attached. I can't find the specific manual for it but the prescribed way for most subs that accept speaker level inputs (and HAVE speaker level output terminals) is run one pair of speaker outputs from the receiver to the sub and daisy-chain the Klipsh speakers from the sub.
Aug 19, 2011 | Marantz SR-48 Mark II Receiver
Hi, I would to say thanks a lots to let put some words on yours email box. It's just regarding about how to set up a live band gigs @ outdoor stage in to mixer system. In a mixer setting, i wana know how...
You will need at least a 24 channel mixer to give you spare channels. You also need an active crossover and a snake. The advice you need is too much to include here so I am including some links:http://mixonline.com/live/FixIts/, http://en.wikipedia.org/wiki/Live_sound_mixing, http://mixinglivesound.com/blog/tag/outdoor-concerts/,http://mixinglivesound.com/blog/, and http://www.scribd.com/doc/11435651/Beginners-Guide-to-Mixing-Sound. You may need more monitors than you are planning on and you might consider in ear monitoring.
Aug 22, 2010 | Music
I dont know how to hook up my bose speakers to my Dell desktop...Im not sure where to plug things in...? HELP!
This all depends on some unknown regarding your PC and its hardware and software sound capabilities. At a minimum it probably has a headphone output. That can be adapted to feed an RCA cable pair for standard stereo to an amp or receiver.
The Bose AM5iii is just a speaker system. It needs an amp or receiver to produce the power to drive it. Most PC's are made to directly power only headphones or self-powered speakers.
If your PC has a sound card with Digital Audio Out (usually RCA-looking coaxial SP/DIF); or Audio Line Out connections (usually 1/8" and color-coded for Front L and R; Surround L and R; and Center / Sub), you COULD run those to an appropriate multichannel amplifer or receiver and let IT do the speaker thing for you.
Bottom line: you need intervening amplification to use the Bose AM5iii on a PC.
Mar 05, 2010 | Bose Acoustimass 5 III System
Which speaker wires feed which speakers throughout my house?
Since this is a custom install and the wires don't follow a rule the only way to find which is which is to disconnect all the remaining speakers, plug in light bulbs in their places and check every single pair till they all match and their corresponding bulb lights up.
Dec 06, 2009 | Audio Players & Recorders
Purchased 2 used sonance sonamp 260 for homewide speaker system (12 pair).line out from receiver into first amp powering first 8 pair.line out from first amp into second amp powers remaining 4pair.only...
I am assuming you are using the standard sonamp 260 not a 260x3
and that when you say you are getting sound on only 1 pair that means only on 1 side (left or right channel only?)
Are using a speaker selector box? you must to regulate the resistance (ohms)
if so first unhook all but on pair of speakers and see if both channels are working.
if they do your problem is in the speaker selector not the amp if no then check to see what the amp level is set to. These are the two small holes on the front right of amp make sure they are set about equal at around half way up.
If that doesn't work flip the RCA cables coming to the amp perhaps you have a bad cable if that doesn't work make sure your receiver (source) is outputing a stereo signal to begin with.
lastly 8 sets of speakers off 1 amp? that's pushing it.even with a high quality Niles or speakercraft selector that controls the resistance going to an amp I wouldn't go past 5 sets.
The right way to do it would be to use 260x3 or a sonance or speakercraft 12 channel amp.
Nov 04, 2009 | Sonance Sonamp 260 MKII 2-Channel...
I have just been given a pair of aiwa speakers sx-fz1800,there is two cables comming out of the back,which one do i use.
One pair goes to bigger speaker (woofer) and other pair for smaller speakers in box, to get full frequency response, you need to hook both cables.
Sep 10, 2009 | Audio Players & Recorders
"speaker location"
Yes, You can fit these in the Doors with Modification. Your best Sytem Would be 2 in Front, 2 in Rear, and Sub. If you REALLY Wanna get into it, Go to Crutchfield.com and Purchase the Pioneer 7800 Series Equalizer and 3 Amplifiers. AWESOME SOUND!!!!!!!!! Please Rate My Response! Thanks!
Feb 05, 2009 | Jl Audio 12W3 Car Subwoofer
Light sound
Switch the speakers over just to make certain it's not the amp. If still bad on the good channel, then the crossover (inside) might have developed a fault.
Jan 25, 2009 | JBL E-30 Northridge E Series Bookshelf...
Home Entertainment
It depends on what you want. Is your existing solution a surround sound system (You only mention a subwoofer, what other speakers do you have?)? Do you want full 5.1 or 7.1 surround sound? If you don't have this, and want it, your amp will have to be replaced, but your sub will fit in just fine. If you currently only have front left and right speakers, you will need to purchase a centre speaker and another pair (5.1) or two pairs (7.1) of speakers.
Sep 13, 2007 | Audio Players & Recorders
78 people viewed this question
 Grubhead
Grubhead
