Question about Bushnell Trail Sentry 11-9200 Digital Camera
Is there a factory reset
Can't change password
    Master:
  • Bushnell Master
  • 442 Answers
Normally you have to send it in to Bushnell and have them do it for a fee but in the past I used the following to reset a similar Bushnell trail cam and it may work for you:
1. Turn camera on and wait for the password screen.
2. Press and hold the enter button until the camera switches to the 5 digit password mode. "Trail Sentry cams will not indicate a 5 digit mode on the screen, but it will show "-----".
3.Press enter to confirm 5 digit mode.
4. Enter the 5 digit code "66214, then press enter. *Note it will accept a 5th digit.*
5.Camera should display "PASS" and go into the operating mode.
From here you can program a new password from the setup mode.
Posted on Jan 05, 2015
I have a Galaxy Tab 2. I need to change the password. Can you help?
In order to change the password you must have the old password. If you don't have the old password which I assume is the case here, you must do a factory reset, you will loose all data other than what came on the tablet out of the box new, all of it. To do a factory reset just Google the make and model number and the words "factory reset" the instructions will show.
Nov 18, 2016 | Samsung Galaxy Tab Tablet PC
Change password
If you can't remember the password you will have to reset the router to factory settings by pressing the reset button on the back of the router and holding it for 5 seconds. Login to the router by entering 192.168.0.1 in the search address bar of your router. When the login screen appears enter the password you know or if you have reset the factory defaults the name and password is admin. Choose the system tools page and then password to change the password.
Dec 03, 2014 | TP-LINK TL-WR740N 150Mbps Wireless Lite N...
Want to change wifi password because I do not want teenage daughter using right now
Hey;
Changing password on a router is quite simple. Depending on which router you have, the factory login and password might differ.
First you have to log into your router. use
http://192.168.1.1
Then you will be prompted for user id and password
login: admin
password: admin
or password
if you are using a verizon router, use
login: verizon
password: password or password1 (when you type the password it will show multiple dots for each character)
if your router has a different password already pre-set then you will have to reset your router. This will change your network name and reset the password to factory setting, like above.
Locate the reset button in the back of the router. While the router is turned on, press the reset button for 10 to 15 seconds and release. The router should now reset. Once it resets, just fallow the steps above. You may also click on the "Wireless" tab and change your network name as well.
Hope this helps.
Feb 03, 2014 | Computers & Internet
How do i find my password to my link system
There is no way to find the password if it has been changed from the factory settings. You will have to do a factory reset of the router to allow you to log in and change the default password. Usually on Linksys pressing the reset button for 10-20 seconds resets the router completely to factory defaults. Usual user/password is admin/admin or admin/password. check your installation manual if you still have it or go the http://support.linksys.com to get a manual for your router.
Feb 01, 2013 | Linksys E1200 Wireless Router - Ieee...
Change Password
you will have to reset it. there is a small inverted reset button, hold it in for 30 seconds and it will reset to factory default. There will be a factory default user and password you will need to use at that point.
Oct 09, 2012 | Westell Versalink 327w Wireless Modem...
Need password to my netgear router n 300
what is the model #?
Most netgear routers default to a username of "admin" and password is either " admin ", "password" or it is just blank. Those are the defaults unless someone changed it.
If you cant get in you can hold down the reset button on the back for 30 seconds (while it is plugged into power) and that will set it back to factory default settings then one of the above should work.
If this was a help please give me 4 thumbs up as I am trying to build up my rep on this site!
Mar 02, 2011 | Computers & Internet
Forgot asus RT-G32 router login password. How to change the password?
You must perform a factory reset using the reset button on the rear the device. You will then have to login using the factory default user id and password, create your new password, then reconfigure your router to your system as all settings were reset to factory defaults.
Dec 19, 2010 | ASUS RTG32 Router
I need to figure out how to re-set my Linksys WRT54GX2 Wireless0G Broadband Router With SRX200
This article will guide you how to change the router's password and reset it to factory default.
NOTE: Accessing the router's web-based setup page requires a password. The default password of a Linksys router is "admin". For security purposes, it is recommended to change default password.
Changing the Router's Password
Resetting the Linksys Router to Factory Default
Resetting the Router Using the Web-Based Setup Page.
If any more problem encounter,post or thumbs back.
Nov 02, 2010 | Linksys WRT54GX2 Wireless-G Broadband...
Default factory password
Most of the NETGEAR devices, except ReadyNAS products and Fully Managed switches, have the following default username and password:
  • Username = admin
  • Password = password
    • For older devices, password = 1234
If you have changed the default password and have forgotten it, you will need to reset the NETGEAR device to factory default settings in order to use the default username and password. Click here to learn how to reset the NETGEAR device to factory default settings. Please note: restoring a device to its factory default settings will erase any changes you have saved to the device.
This applies to:
  • Most of the NETGEAR devices such as routers and smart switches.
Aug 13, 2010 | Cell Phones
Centreware password on Xerox 7335
On mine it was the other way around username 11111 & Password x-admin
Jan 21, 2009 | Xerox DocuPrint 4517 Laser Printer
Bushnell Trail Sentry 11-9200 Digital Camera Logo
261 people viewed this question
Top Bushnell Cameras Experts
Johnny Massengill
Johnny Massengill
Are you a Bushnell Camera Expert? Answer questions, earn points and help others
