Question about Acer LX.WZ902.004 - Gateway/nv75s23u Notebook/wht
Accidentally disabled touchpad
Touch disabled
    Problem Solver:
  • 6 Answers
Typically on a Gateway computer there is a series of buttons on the top of the keyboard area, including a touchpad disable button. If that is not lit, press it until it lights up. Hope this helps! If not, check out this forum that might help you. Gateway nv53 touchpad does not works
Posted on Nov 08, 2014
Charger causing cursor jump
AnswerMake sure you're not touching the touchpad
Because the touchpad often is close to where the palms of your hands and thumbs lay, it's possible that you may be touching the touchpad without realizing it. An easy way of determining this is to see if the cursor moves without touching anything on the keyboard.
Dirty touchpad
Oils, lotion, and other substances from your fingers can cause the touchpad to not work properly. Make sure the touchpad is clean by dampening a cotton cloth with water and rubbing the touchpad surface.
Disconnect other external input devices
It may not be touchpad that's causing your issue. If you have other input devices such as an externalmouse, graphics tablet, keypad, etc., try disconnecting these devices to make sure they're not the cause of your issue.
Disconnect from docking station
If your laptop is only encountering this issue while connected to a docking station, it could be the cause of your issues. For this issue we suggest the below solutions.
Update drivers
Because the drivers control how the touchpad interfaces with the operating system, if the drivers contain issues, any number of problems can occur. Including the cursor moving improperly. Make sure you have the latest drivers from your laptop manufacturer for your touchpad either by visiting their website or contacting their support.
Try a third-party utility
Download and install Touchpad Blocker, a fantastic free program that can be used to help prevent any mistaken touchpad movements.
Bad hardware
If you've completed all the above steps and continue to have issues with your touchpad, it's possible you may have a physical hardware issue either with the touchpad or interface connected to the touchpad.
If your laptop is out of warranty and you do not wish to spend the money it takes to repair the laptop, we suggest disabling the touchpad and using an external USB mouse. Many touchpads can be disabled by pressing a button above or around the touchpad.
Additional information
Sep 10, 2013 | Computers & Internet
Touchpad not working
Please check:
1. Are you use usb mouse ? laptop (depend on settings) will auto disable touchpad while usb mouse detected
2. You may accidentally press Fn + Function button that contain touchpad and finger image on it ?
3. You have disable your touchpad on Mouse Setting (accidentally)
Nov 19, 2012 | Dell Computers & Internet
While deleting some files , not realizling it I deleted my touchpad ( what ) softwear . OR whatever its called , Now my touchpad isnt working. I have a compaq , about 4-5 yeasrs old , with windows7 up...
the touch pad should work even if you erased the files as it uses generic Human Interface Device drivers. Be careful that you didn't accidental disable the touchpad with the Fn+F2 or other Fn key combination(the key that you should combine with Fn has to has a touchpad icon on it) Another posibility is that you have enabled an option to disable the touchpad upon usb mouse connection. Also it would help if you gave me more details about what and where you erased.
Oct 16, 2011 | Compaq (153515-001) Touch Pad
I am using HP ELITEBOOK 8460p latop. My touch light glows automaticllay and unable use the touchpad. Please help me
You might have disabled the touchpad accidentally. If the touchpad is disabled it is indicated by a yellow LED on upper left corner of the touchpad and when the TouchPad is active, the light is off.
To turn the TouchPad on, quickly double-tap the TouchPad off indicator (the yellow LED).
Hope it helps!
CreativeTECH
Sep 20, 2011 | HEWLETT-PACKARD EliteBook 8460p Notebook
I can not unlock my TouchPad.
Hope it helps!
CreativeTECH
Jun 27, 2011 | HEWLETT-PACKARD ProBook 4520s
How do you turn off the touch pad
Some notebook users find the touch pad annoying because at times, while typing fast, their thumbs accidentally brush up against the touchpad. This is frustrating because the mouse cursor jumps to a random location on the screen and can cause undesirable things.
To turn off the touchpad when an external mouse or other pointing device is present, you can goto the Control Panel and double click the Mouse properties icon.
Click the Device Select tab and check "Disable Touch Pad when USB Pointing Device is present." The cursor will no longer move via the touchpad.
Oct 24, 2010 | HP Pavilion dv4000 Notebook
Hi my name is amyraffan and my dell inspiron 1545 touch pad/ mouse has stopped working completely it wont move and its froze in the same posiition, please help!
there is a button to disable the touchpad near to it. check if you had accidentally clicked on that button which disables your mousepad.
If still problem not solved, then try reinstalling the touchpad device driver alone from the driver cd provided along with your laptop.
I hope this helps you.
Thanks
Sep 19, 2010 | Dell F3534 Touchpad
The touchpad stopped working after a powerpoint presentation i made. A friend helped me set up the laptop to the projector and he did press keys. Did he accidentally press some inactivating key in the...
FN + F9 should enable / disable the touchpad goto control panel - mouse - and see if you can change disable/enable touch pad from there Otherwise post back what windows version you have
Touchpads
you can enable and disable the touchpads Touchpad: - to enable or disable a touch pad/pointing device from the Start Menu > control panel > Change to classic view - {on left hand menu} click on the mouse icon Mouse Properties dialog box, click "Device Settings tab" select the device click to Enable or Disable OR You may need to enable in the bios/setup menu - as the PC boots - you should get a message on how to get into the bios/setup - usually using F2 or DEL Key or F10 see if touch pad needs to be enabled there OR one of the F keys may disable/enable - depends on the model of the Laptop - toshiba sometime use FN+F9 key
Apr 10, 2010 | Toshiba Satellite M55-S325 Notebook
Acer aspire 5517 touch pad not working.
Also on this laptop you can hit Fn+F6 to enable or disable the touchpad as well there should be a touchpad disable button to the right of the power button that can be very easy to accidentally press.
Mar 15, 2010 | Acer Aspire 5315 Notebook
Dell Inspiron 1545: I accidentally disabled the touchpad and can't get it to enable again.
ok so if your touch pad isn't working you need to get in to your control panel there look for device manger then look for the disable touch pad and enable it hope this helps
tip plug in a external mouse so you can get to the control panel
Jul 29, 2009 | Dell Computers & Internet
Acer LX.WZ902.004 - Gateway/nv75s23u Notebook/wht Logo
160 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
