Question about OEM 1989 GMC S15 Pickup Radio / CD Player vlh79649w AM-mono-FM-stereo, w/seek scan and clock, w/cassette Stockton, California
Why can't I shift in to any gear and it grinds trying to shift into reverse with the engine running. I just replaced the master and slave cyclender bleed out the air clutch peddle feeles excellent li
Why can't I shift in to any gear and it grinds trying to shift into reverse with the engine running. I just replaced the master and slave cyclender bleed out the air clutch peddle feeles excellent like it should I can even hear the cluth fork squeak alittle bit when i work the peddel.
  • 2,825 Answers
Your symptoms indicate that the clutch isn't fully disengaging when you push the pedal down. There may be an adjustment on the slave cylinder you need to deal with.
Posted on Nov 08, 2014
Testimonial: "No there is not an adjuster and told that hydrolic cluthes can not be adjusted. I wish there was a way do you have any other possible ideas"
  • Jay Plesset Nov 09, 2014
    Unfortunately, I don't actually have experience with your vehicle, just with several others. All of the ones I dealt with had adjustments on the slave.
The reverse wouldn't engage on my friends 2002 vw jetta 2.0 someone else replaced the master and slave. when you first turn on the car it whistles and when trying to shift it grinds. I took the slave
Could be a bad throw out bearing causing the whistle, and perhaps the other issue as well. Reverse is hardest gear to engage smoothly as it is not synchronized. Try re-bleeding the system and insure none of the linkage parts are worn. Also make sure the trans is correctly filled with fluid.
Jan 14, 2015 | 2002 Volkswagen Jetta TDI
My clutch wont go into any gear unless i force it.. And it grinds on going in reverse. is it the master/slave cylinder the problem. or the clutch? please help!!!
Hopefully you got a warranty with the clutch job, so I would take it back to that shop first. If you have someone else work on the truck the first shop is off the hook for responsibility. Its possible the clutch has failed, or you have developed a new problem.
Jan 17, 2014 | 1990 Toyota 4Runner
Clutch
Could be, or the clutch disc. First gear and reverse do not have syncro gears, the others do. So the transmission and engine have to be "disconnected" to allow shifting into first and reverse.
Jul 06, 2013 | 2004 Chevrolet Cavalier
1990 camry shifting cable went out
your clutch has went out or the slave cylinder to clutch or clutch master cylinder ck master for fluid if low fill and work clutch peddle to pump up slave cylinder if master is full ck at trans to see if slave cylinder is moving if moving clutch in most likely bad and needs replaced.
Jul 15, 2012 | 1990 Toyota Camry
I have a 1995 Chevy S10 4.6L 2WD Ext Cab truck. Just replaced the transmission and have bled the system. I started the engine and I cannot shift into first gear without grinding the gears. Any suggestions...
If you can see the slave cylinder actuate, then have someone push the clutch down and watch for movement. You should see the release lever move at least a half inch. Let me know if you get movement. I also would like to know if you had the flywheel machined and if you removed, replaced, or added any shims between the ****** and engine block.
Oct 06, 2011 | 1995 Chevrolet S-10 CA Edition
Reverse is grinding when i try to put it in gear .other gears dont grind but its very hard ti shift .its a 2000lanos.
If this is a manual transmission ,then the clutch master,or the clutch slave is by-passing,and,or leaking and causing the problem,or the clutch pedal axle bushing has worn out.
Mar 30, 2011 | Daewoo Lanos Cars & Trucks
I have a 1997 Pontiac Sunfire that has problems shifting into gear. (manual trany). Have to force into 1st, 3rd, 4th, 5th and especially in reverse. Will grind going into reverse. Have to turn off...
Sounds like the clutch is going out. I would check the operation of the clutch slave cylinder. Also check the clutch master cylinder fluid level.
Oct 18, 2010 | 1997 Pontiac Sunfire
Gears grinding when trying to shift in a gmc 3500.
some aftermarket masters don't push enough fluid to the slave to disengage the clutch even from the same maker
Sep 04, 2009 | 1985 GMC K3500
1989 Mazda mx-6=gear shift
This make and model has hydraulic clutch.Most likely clutch master or slave cylinder gone bad.Look to see if any fluid is leaking out of slave cylinder,or clutch master.There may not be any,but this would help decide witch one to replace if there was one leaking.This would be the problem,one or the other.If I can help,let me know.
Aug 24, 2009 | 1989 Mazda MX-6
OEM 1989 GMC S15 Pickup Radio / CD Player vlh79649w AM-mono-FM-stereo, w/seek scan and clock, w/cassette Stockton, California Logo
54 people viewed this question
Top OEM Audio Players & Recorders Experts
Coss
John
John
Are you an OEM Audio Player and Recorder Expert? Answer questions, earn points and help others
