Question about Microwave Ovens
Is light supposed to come on when door is opened?
Micro buzzes or hums when door is closed. no operation - error code "PF."
  • 5,499 Answers
Yes the light comes on when the door is opened and when the microwave is active! The PF code indicates a Power Failure, press clear or cancel to reset or unplug for a few minutes and re plug!
Posted on Nov 08, 2014
My GE Microwave Model JKP90SP4SS will not shut off, even with no time programmed and cooking is done. The only way to stop operation is to open the door or shut off the breaker.
This kind problem is usually associated with the door micro switches. What happens is the switches are supposed to prevent operation when the door is open and other things. When one fails, often the oven will run with the door open or closed. There are a number of these micro switches inside and they protect the user from certain unintended actions or combinations of actions. This usually happens with well used ovens. There are extremely dangerous voltages inside a microwave over, even when not connected to power. Find a tech who knows these things.
Jan 07, 2017 | GE Microwave Ovens
RE: Samsung microwave SMH7187STG mfg'd 5/08. I heated cup of tea 2 min.Then I closed micro's door & micro emitted a continuous electrical buzzing sound.I opened door & buzzing stopped.
The cook relay on your control board is shorted, and the unit is cooking whenever you close the door.
When the magnetron overheats, its thermostat opens, shutting power down until the unit cools to a safe level, then power is restored.
I regularly repair these with my $54.95 service, which includes insured return shipping.
Details are here, or for full information and instructions, please e-mail me here at pupista@gmail.com and remind me of your full model number and symptoms.
Dec 20, 2016 | Samsung Microwave Ovens
When microwave is started, why does it make a loud buzzing sound--like a Skil saw sounds?
Whirlpool Microwave Buzzing Loudly - ApplianceBlog
www.applianceblog.com/.../26531-Whirlpool-Microwave-Buzzing-Loud...
Aug 12, 2011 - 10 posts - ‎2 authors
My Whirlpool MT4155SPS-2 microwave oven has recently started to buzz loudlywhen operated. The sound is getting louder and more frequent ...
Whirlpool making intermittent loud buzzing noise Microwave ...
www.fixya.com > ... > Microwave Ovens
Whirlpool microwave ovens making intermittent loud buzzing noise related questions and answers. Ask your ... ...loud buzzing noise and it doesn't heat. i just tried it again and let it run for 1 minute. ... Question about Accuwave Microwave Oven.
Troubleshooting the Microwave: Potential Problems ...
www.appliancejournal.com/.../troubleshooting-the-microwave-potential-...
If your microwave buzzes loudly and produces no heat you probably have a defective power .... I have a whirlpool oven range and it's less than a year old. .... Humming sound stops when I open door to remove food, but when door is closed, ...
Whirlpool Microwave Ovens - Consumer Affairs
Feb 03, 2016 | Whirlpool Accuwave Microwave Oven
What is the first thing to test on my micro that is acting up?
Microwaves are not very user friendly when it comes to servicing the. They generate very high voltages and are very dangerous to try to repair without the proper training.
Nov 08, 2014 | Microwave Ovens
The microwave wont respond to the timer. It keeps cooking unless you open the door. After the timer runs out it seems like it cuts off but there is still a low buzzing sound and it is still cooking. Have...
low buzzing can be a power relay or a (solid-state)
triac which both supply power in their own right to the power transformer to operate the magnetron tube,even though you say it quits cooking when you open the door,i would still check the micro-switches in the door for proper alignment and operation, because it can be a door switch mis-alignment or a leaking triac still supplying power to the unit
Jul 14, 2010 | Kenmore Microwave Ovens
Microwave buzz with door closed and off This is a GE JVM1443WR Spacesaver... Microwave works, all buttons work, interior light works, and it will heat food... However, even when the microwave is off and...
You can check the relay and related driving circuit. If there is a short in the relay driving circuit there is chance for this type of problem. or the micro processor may be defective.
May 23, 2009 | Microwave Ovens
1800 XL JVM1860BD - won't work
It sounds like your controller may be failing. Or it could be an electrical line problem. Any other electrical itmes giving you trouble? Has anyone measured the voltage level of your power line? It should be around 110-125 volts AC. If it's significantly lower or higher, you may have a bad connection in your breaker panel or in the wiring leading to the home.
Aug 14, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
My Microwave flickers and buzzes
This problem normaly happens when the door is not closed properly for a long time and flashing and buzzing starts to give user a indication for same. Allthough it is not risky as microwave oven has safty door switches wich does not allow oven to operate while door is open. Take care and close the door properly before you leave kitchen..
Aug 02, 2007 | Kenmore 66469 / 66462 / 66464 Microwave...
Microwave works with door open
If the top is open, the upper door switch should be open and the high voltage section should not be energized. That's the way it's *supposed* to work. But that buzzing is worrysome! Does the turntable turn during this condition? Does the inside light come on? How about the fan? If not, then I would doubt that it's cooking. If so, some models will do this. It's not uncommon to notice that the fan and light will try to come on for a split second when you shut the door. This would not indicate a problem. It has to do with the timing of the door switches and a replay on the board. If it's still under full warranty, it wouldn't hurt to call a GE-authorized servicer.
Nov 07, 2006 | LG LRMM1430 Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
